09-11-2024, 11:01 AM | #26 | |
Re: Gauge Cluster Restoration
I have this voltmeter from American Autowire in my truck. https://www.summitracing.com/parts/a...RoCi-4QAvD_BwE |
09-27-2024, 03:26 AM | #27 |
Hi PJ, I looked for the saved gauges I had stored in my Walrus Hut. I found the box, an old carton, my Weiand 8004 V8 manifold came in, 25 years ago. The only gauge in there was an Autometer Vacuum gauge.
The digital voltage indicator, Oil Pressure gauge, and Tachometer were not present. Mystery. Maybe I located the project somewhere else, and got stalled...? IDK. This is not a high grift area. And why only those items? In other news, by tightening up the Gss Line connection behind the seat in the Orange Stepside, I got rid of excess fuel vapors.
09-27-2024, 10:33 AM | #28 | |
09-27-2024, 09:23 PM | #29 |
I just used the mounting from Autometer and clamped the Tach on the column at a 1 - O'Clock position with a 3'' hose clamp. [But your machining skills are impressive.
In these shots, I was changing out the T/S Switch. Tach is dangling by its wiring. Oh yeah. The hose clamp was a Rolls Royce part. ''acquired'' from the Harrier parts bin. Knee Screaper Gauge brace holds Oil Pressure/ Vacuum/ Water Temperature. The GPS [Magellen] rests on the Ash Tray, it's top stuck to a Radio Delete Plate with a tootsie roll of green gaffer's tape. Since adding a gear correction box to the tranny output before the Speedometer Cable, the MPH reads right with 235/85/R16s. I check speed against the GPS read, and it's within 2 - 3 MPH of ''Indicated'' speed. Quite used to the Old Schhol set up.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-27-2024 at 10:44 PM. |
09-29-2024, 09:51 PM | #30 |
I used the good reproduction bezel and it looks as good or better than OEM. The tach is a reproduction but all the other gauges are originals. I also put in LEDs for much better illumination (except for the one that also lights up the gear selector, LED just wouldn't light up the gear selector worth a darn).
I experimented with green, white and red LEDs. I stuck with the green. If I could find a nice OEM clock for one of the small pods I'd gladly use it to replace the vacuum gauge. I also need to find a better temp sending unit that is more compatible with the temp gauge. The sending unit I have barely gets the needle above the C range on the left when the engine is fully warmed up.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings Last edited by Rich69shortfleet; 09-29-2024 at 10:04 PM. |
09-29-2024, 10:32 PM | #31 | |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
10-01-2024, 08:55 PM | #32 |
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
10-05-2024, 08:11 AM | #33 |
Interesting. I went hunting for a partial dash to repair a cut guage back plate.
How do I open the metal plate to view vacuum guage? Is their a die available? Scored this at Carlisle $20. |
10-05-2024, 09:16 AM | #34 |
Here's a video that shows how I add a vacuum gauge.
https://youtube.com/shorts/W6D0dcKrsCc?feature=shared Member 70shortfleet offers a tin modification service for adding a vacuum or tach. https://67-72chevytrucks.com/vboard/...d.php?t=792563 I have vacuum lens decals for sale. https://67-72chevytrucks.com/vboard/...d.php?t=848683 Last edited by pjmoreland; 10-05-2024 at 09:28 AM. |
10-05-2024, 05:31 PM | #35 | |
10-05-2024, 06:03 PM | #36 |
It's not something you can buy. I designed mine and 3D-printed it.
