Old 06-21-2024, 12:18 PM   #26
JDarby
JDarby's Avatar
Re: C4 Vette sub frame & running 4 of the same wheel?
Originally Posted by fauXGT View Post
WheelSmith wheels. They will build to your request. And they have new style mounts for stock looking caps. Caps were from Speedway...I think. Been 2+ years.
I have been talking with Terry at Wheel Smith, a very knowledgable guy about my situation. All in All I have decided to go with the stock C4 front brakes!
This eliminates a lot worry about steering problems, opens up my wheel selection and I can run all 4 the same!
1955.1 GMC 100 RestOMod
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
JDarby is offline   Reply With Quote
Old 06-28-2024, 09:03 PM   #27
JDarby
JDarby's Avatar
16 x 8 smoothies with stock style caps
Chip,
Before I order any rim I want to make sure I understand what you are saying you ordered for your C4 on four corners rims?
16 X 8 rear with 4.75 backspace?
16 X 7 front with 4.75 backspace?
I have decided to go with stock C4 on all four corners considering that both vehicles weigh in at about GMC 3150LB curb / Corvett 3293 curb
close enough for horse shoes or dancing
And it open up my wheel selection wide open!!!!
Have you mounted the rims yet, checked them for fitment?
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 06-28-2024, 11:53 PM   #28
fauXGT
fauXGT's Avatar
Are you an earlier or later gen C4?
Mine is an first gen 84, which stock has the exact wheel on all 4 corners.
If you are looking at the later gen, stock might have been different size front to rear with different offsets. I don't know what year your Vette suspension is from. The only reason I went to 16 x 8 with the 4.25 backspacing as my rollers are 6.5 wide with plenty of space, and the widest others have put under these trucks with these suspensions was noted as 8". I may have gone too wide, but all the wheels are identical to keep the footprint equal.
With medical issues happening, the only thing I've done is dry fitted the wheel alone on the rear with the fender hanging on the bed last fall. Talked to my tire guy today to say I'll be down in a couple of months with one wheel and a list of tire sizes to keep height required. I might have to order new narrower wheels if they are too wide.
Chip
'51 Chevy 3600 5 window
C4 Vette front/rear suspension & drive train
full Rusto-Mod
'92 GMC Sonoma GT VIN #0015
'91 GMC Sonoma GT extended cab 1 of 1
fauXGT is offline   Reply With Quote
Old 06-29-2024, 01:20 PM   #29
JDarby
JDarby's Avatar
My research shows me all C4 84-87 ALL wore the same size wheels front and rear
which is what my choice was from the oneset to go with the 84-87 suspensions.
I may just go with 16" x 7" on all four corners and run my spare!
I want to thank all for getting me back on point when it comes to steering
geometries!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 06-30-2024, 12:01 AM   #30
fauXGT
fauXGT's Avatar
If when I assemble all body parts and I'm too tight in spots, that's probably what I'll have to back size to....16 x 7.
I shoulda gotten one of those wheel offset and size measuring tool that some have been talking about lately.
Chip
full Rusto-Mod
Old 06-30-2024, 04:35 PM   #31
JDarby
JDarby's Avatar
I returned mine and got my $ back from Speedway!
Did not care for it!
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
Old 07-27-2024, 01:31 PM   #32
JDarby
JDarby's Avatar
Ordered a test wheel from Wheel Smith, should be here any day now!
I went back to stock C4 front calipers and rotors with the hopes of running all 4 wheels the same size.
Will Post up an update after I test fit the rim and if that go's well, I'll
figure out what tires to run on my 16' X 6" rims
1972 T120RV
1967 C200 Trail 90
2014 TRD Quad CAB
