Old 07-02-2024, 04:14 PM   #26
Wrenchbender Ret
Re: 68-72 rear end issue
Classic Parts of America has conversion axles that would probably solve the problem.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-02-2024, 10:53 PM   #27
dmjlambert
dmjlambert's Avatar
So 40 thou is thinner than a dime, is that what we're talking about here?
dmjlambert is offline   Reply With Quote
Old 07-03-2024, 02:04 PM   #28
Jd63
Thank You for clarifying my mistake that I made.
The axle play is .040 thou not .40
It seems like that would be to much movement on those c clips. Ultimately you would have your rear end axles able to move .080 thou on you
Jd63 is offline   Reply With Quote
Old 07-03-2024, 02:56 PM   #29
LNP
Originally Posted by Accelo View Post
So you know their is no way to re-drill a 6 lug for a 5 unless you weld up one hole on the axle flange.
I realize that most shops that redrill axle bolt patterns will cover that prior to drilling
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-03-2024, 02:57 PM   #30
LNP
Food for thought, you could go with c-clip eliminators
Harley
Old 07-12-2024, 04:11 PM   #31
Jd63
What kind of job is it to do the c clip eliminator kit, I haven’t had any experience with that
Old 07-12-2024, 04:22 PM   #32
57taskforce
All about them K’s
57taskforce's Avatar
Originally Posted by LNP View Post
Just out of curiousity whats the difference between the 68 & 72 axles themselves?
The 72’s are longer than the 68’s as well. The over all width of the housings changed in or around ‘70.
Tyler
57taskforce is offline   Reply With Quote
Old 07-12-2024, 04:44 PM   #33
LNP
This video goes over doing it
https://www.youtube.com/watch?v=6-LaC7cs_FQ
Harley
