#26 |
Cadillac power
My Jacob's ignition kit came with a built in anti-theft product. A micro switch interrupts the ground to the computer and must be reset within 8 seconds of every start. I've hidden the switch quite well and have (on a few occasions) missed the switch after I get the truck started. It also has a "valet setting" which allows two minutes of operation and then interrupts the ground.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style. --Scott Adams author of Dilbert |
#27 |
I use a brakelock. Turn the key, hit the pedal. If you want it, you have to drag it. It isn't going to roll anywhere.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
#28 |
i have a 3 speed on the tree coil cut of and a club my trcuk has been broken in to 5 times and never stolen i am knocking on wood right now
i do not have a cd player and kept nothing in my truck of any importance and i leave my door unlocked so if they want in my trcuk they dont have to break in to look and see that there is nothing there i no longer live at the place where i was geting looked into and now i dont have to worrier about it ps my room mate back then hade his explore broke in to 3 time and they smashed a window every time.
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers Last edited by bad 71 chevy; 01-13-2004 at 08:53 PM. |
#29 |
my current idea (still in planning stage) is to hook a taser gun (with the 15 foot leads and the prongs) up to a circut on the door. probably a magnet setup where the 2 magnets are pulled apart the circut breaks. have two tasers aimed across the cab so it will shock the hell out of the person who broke in to the car.
![]() another idea is a spring loaded steel bar under the cab that will swing out breaking the persons legs. this idea originates form south africa where carjackings are a massive problem and many people equip their cars with these and a lever in the passenger compartment to release the steel bar when the carjacker comes up next to the car. ![]() ![]()
1990 subaru legcy (daily driver) 1987 Toyota 4runner (weekend toy) 1968 ![]() 1970 ![]() 1976 Dodge Dart 1963 Dodge Dart ![]() |
#30 |
Wiseass secured himself a BAN
A sledge hammer and a case of Krylon paint of your choice. Take the hammer and put dents all through out the hood, cab, doors and bed. Next take the Krylon paint and color in the dents (brighter the color the better theft deterent). After you get done no one will want it. Just a suggestion.
#31 |
![]() Join Date: Jan 2004
FUEL SWITCH
MY TRUCK HAS THE BEHIND THE TANK SEAT AND TWO SADDLE TANKS UNDER THE BED...NEXT TO THE DRIVERS SEAT IT HAS A FUEL LINE SELECTOR SWITH FOR THE CAB TANK, RIGHT SADDLE TANK, LEFT SADDLE TANK, AND "OFF" ...I JUST SWITCH IT TO OFF !!!! ITS TOTALLY OUT OF SIGHT !!!
#32 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Battery disconnect with a key...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#33 |
my truck is pretty ugly so i'm sure no one would want to steal it. however, i do have a cd player and cd's inside, so i lock my doors. if i have to park it in a questionable area for a long time (haven't had to yet) i will remove the cd player faceplate, the cd's, lock my doors, and leave my transfer case shifter in neutral. that way unless they know the rockwell's shift pattern, they won't be able to figure it out for a few seconds at least.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#34 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: cheap theft deterrent
