#26 |
![]() Join Date: Mar 2011
Re: Back to the basics...My 1966 C30 to C10 project.
Great project you've got going. What are you going to do with the C30 frame?
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
#27 | |
otherwise, looking great!
John 3:16 - Saved me... God Bless |
#28 |
Hello
I am converting a 65 C30 to a C10 and I am having problems finding a heater core for the recirculating heater. The blower and heater core are located inside the cab. I have seen some info on this type of heater but every part I did find is for the heater located in the engine compartment. Does anyone have any info on the recirculating heater? Thank-you |
#29 |
subscribed!!
1966 C10 "Mary" 1967 C10 Custom "Ole Blue" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" C10 Club Texas -HMIC |
#30 |
Update.
Got the motor and trans psi sprayed. Will reseal and paint engine. Also got front 15x6's 5 lug wheels that match the rear 15x8's.
I LOVE BURNOUTS ![]() :metalNO BOZO's Last edited by hardwaa; 04-05-2025 at 03:10 PM. Reason: Typo |
#31 |
Updates...
Engine and trans pressure washed. (March 24th) Bought front 5 lug wheels 6" wide to match the rear 8" (April 3rd) Rear 5" drop springs installed. (May 4th) Assembled and installed front end lowered parts (May 22nd)
I LOVE BURNOUTS ![]() :metalNO BOZO's |
#32 |
May 24th new front tires.
Last Saturday I got the rear wheels painted on back and primed on face, and the tires mounted. (Need to paint back of fronts and all wheel faces still)
#33 |
Last Saturday and Sunday I got the engine resealed and painted also sand blasted and painted engine parts.
Painted the engine "283" grey. Going with semi gloss black contrast parts.
#34 |
These parts will help with the "283" look...
#35 |
Yesterday was transport day...
Pulled front clip to make it easier for engine trans install and brake plumbing.
#36 |
Change in plans. Going 3 on the tree in the 66 not automatic trans.
#37 |
![]() Join Date: Jun 2002
Nice work so far. What's your plan for pcv and oil fill on the engine?
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#38 |
Sweet, three pedals for the win. I always liked the 3 on the tree for a driver.
#39 |
SUBSCRIBED. I miss build threads.
#40 |
Looks great. I plan to do the grey with black pulleys, etc on my build too. What grey paint did you use? Looks a little lighter then others, but that could be the light. My camera never takes good pics of colors.
Rob |
#41 |
Update.
The heaters are so bulky on these trucks. Clean up firewall. Heater is not going back on. Will make block off plates eventually. Had to use my 59 to power the diesel pump to fill the hot water heater on the psi sprayer so I could clean more Chevy parts....the transmission for the 66.
#42 |
Painted the bell housing same color as the engine. Painted the trans a charcoal hammer tone. Quick and easy.
Engine color is ford gray. In some pics it look lighter than it really is due to shop LED lights.
#43 |
Ordered some Napa parts.
Flywheel and bolts , clutch kit Master cylinder front and rear brake hoses, front calipers and pads, rear wheel cylinders and hardware. Will match rear shoes when I pull them off.
#44 |
Also ordered Napa parts for points style distributor , cap rotor, vacuum advance, truck will get pertronix and coil.
Fam belt was wrong. Will post picks of correct 1.
#45 |
Is the Napa MC for a power brake application or manual? I thought the bigger pot was supposed to be in the front? I have been reading all I can regarding disc/drum non power set ups and have read many people using different MC. Just wondering which one is correct.
#46 |
Larger pot is the front brake reservoir but it is the back one on the master, you just plumb the front brake line to it.
#47 |
nice parts going on there... looking good!!
#48 |
Correct. Disc brakes need more fluid than the drum brakes. That's how I remember it.
#49 |
The new NEW intake showed up today. Excited to get it painted and installed...
After I decided last week to make the truck a three on the tree, I knew I had to order the Early style intake. In the past, I've had a motor that I had to pull the valve cover off to add oil not the end of the world, but I definitely think the breather on the intake adds to the vintage look.
#50 |
Are you going to drill the intake to install a pcv valve?
I like the look of the 283's, very clean.
| Bookmarks |
