Old 08-06-2024, 07:10 PM   #26
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: voltage reg problem
Originally Posted by MS66 View Post
Same here. I replaced the original over charging VR in my '68 with the D635 solid state VR, idle voltage was near full output. Much better electrics now.
The alternator is all original, nothing changed or replaced in it. 60k miles in 56 years.
Who sells the D635 and what's the price?
Old 08-06-2024, 07:20 PM   #27
MS66
MS66's Avatar
Man, I couldn't tell you, I stole it off of my now not running '66(going through changes) a few months back. If I'm not mistaken, it was on there when I bought it 25 years ago. Sorry bud.
MS66 is offline   Reply With Quote
Old 08-06-2024, 08:27 PM   #28
Accelo
Accelo's Avatar
You can find NOS ones on eBay. The cost seems to be between $175 and $400. Lots of them are labeled NOS but are "new old stock" from aftermarket vendors.
I think the NOS usage in this manner is bad advertising.
I had mine rebuilt but an individual who specializes in this service. Did an amazing job and ran them at temperature to confirm everything is correct. I have had zero issues with his rebuilt regulators. I wasn't able to find the vendor quickly but will look it up if anyone is interested. The Delco regulators are also date-coded if that is important to you. The date is why I had mine rebuilt.
Cheers
Accelo is offline   Reply With Quote
Old 08-06-2024, 10:04 PM   #29
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Originally Posted by RustyPile View Post
This procedure was for polarizing a generator.. Back in the days, some car manufacturers had positive ground systems, others had negative ground systems.. Polarization procedures are not necessary for alternators.
MacataQ, now is your chance to upgrade your charging system. Unless you just want to keep things exactly original, you can install an internally regulated alternator.. Minor wiring modifications and you're in business.. How to do this simple procedure is all over the internet, including our own ELECTRICAL forum.
Thank You. Now I really feel Old. LOL
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 08-06-2024, 10:45 PM   #30
BROWN 70
BROWN 70's Avatar
Wink Re: voltage reg problem
my 70 GMC has an external vr. a friend gave me a nos 68 Chevy vr and it was over charging. if you take them apart. there is a spring that can be adjusted or bend the locaters for the spring. worked for me. BROWN 70
BROWN 70 is offline   Reply With Quote
Old 08-07-2024, 12:51 AM   #31
'68OrangeSunshine
Yeah, I remember a GM circular or illustration in an Overhaul Manual, Showing a Technician's long necktie getting caught up in the fan/fanbelt during testing. Another one for the [then] young Hippy Generation showed a Dude getting his long hair caught. Now I see a lotta guys who are skinheads without identifying with the whole Nazi Punk vibe.
They used to train techs to adjust the VRs. Now they just throw a new part at it. The problem is the new parts are duds.
I heard an anecdote, that a Chinese factory was detailed to copy a part for replacement. They had a defective unit for their model. Ergo they produced perfect copies of defective parts...
Old 08-07-2024, 12:59 AM   #32
'68OrangeSunshine
Cheers
Well, I stated above that I upgraded to a 12SI w/ internal regulator on my '71 GMC Jimmy [V8 350] and was lucky to be able to cannibalize a good [1998] VR off my '67 K/10 Suburban for my '68 C/10 Stepside [L6 292]. When it comes time to rebuild the Sub, ''White Fang,'' I'll probably go 12SI again. I do have a box of cast off VRs, including at least one DelcoRemy embossed black cover, but I've never been obsessed enough to be a
numbers-matching guy.
[Asking for a friend, how much did your specialist charge you for rebuilding a DelcoRemy VR?]
Old 08-07-2024, 01:06 AM   #33
'68OrangeSunshine
No worries...
