Old 10-25-2024, 09:22 AM   #26
72c20customcamper
72c20customcamper's Avatar
Re: Inexpensive Radiator I Need One.
Originally Posted by Loose Screw View Post
Ok so I'm going to be using that built in automatic transmission tank that's built into my New radiator instead of that add on one that was held on with some sort of long plastic push pins that came on my FrankenTruck.
So what do I somehow cap off the bottom port and fill that tank up thru the top port and then real quick connect the bottom port into the trans?
What's that funky Lokar dipstick reading going to look like....
tia
I’ve never prefilled the oil cooler . Hook up the lines start the truck put in drive and reverse check oil level . The cooler doesn’t hold that much oil in the first place
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 10-25-2024, 10:13 AM   #27
Loose Screw
Loose Screw's Avatar
Thanks Amigo!
Loose Screw is offline   Reply With Quote
Old 10-25-2024, 04:07 PM   #28
MikeB
MikeB's Avatar
I wouldn't worry about filling up the trans fluid tubes in the radiator. Just start the engine, check the fluid level, and add whatever is required. I'd guess it's less than one pint.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 10-29-2024, 02:24 PM   #29
Loose Screw
Ok, I got my $160 total (coolant, hoses, clamps, fittings, Rad etc etc) Chinese set up in.....
The slushbox cooling lines are connected into the Radiator. I got that separate trans cooler bolted onto the radiator support, about 3 inches off the radiator I'll probably splice that into one of the radiator cooling lines. I have all the parts to install it, better than just having them in a box somewhere Right?
Thanks Guys, Stay Cool!
Old 10-29-2024, 09:55 PM   #30
MikeB
MikeB's Avatar
That looks like a serious aux cooler for towing. It should serve you well.
Here's my small B&M stacked plate cooler. It's been on the truck for around 20 years. The TH350 trans was rebuilt in 1990 and got a TransGo kit around 10-12 years later. Those TH350s are tough!
Mike
