#26 | |
Re: Leaking Fuel Pump Diaphragm?
Wiring that stuff up under the dash was another adventure. ![]() Love it LockDoc, I'll look into the heavy duty version. ![]() My Sister got me one of those flashlights that clip to the bill of a baseball cap and I don't know how I ever lived without one. The bill kept bumping into everything though so I broke out the scissors.
#27 |
![]() Join Date: Apr 2016
The carb does not get flooded with an electric fuel pump or mechanical fuel pump because the carburetor has a float in a bowl connected to a needle and seat valve that shuts off the incoming supply of fuel. Pretty much just like a toilet tank shuts off incoming water when the tank is full. If that piece is working correctly, the carburetor only lets in enough gas to fill the internal bowl. The needle and seat and sometimes the float are some of the items typically replaced during a carburetor rebuild.
#28 | |
![]() Join Date: Jan 2025
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
#29 |
#30 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
It's entirely possible for the scenario you asked about to happen. The fuel just doesn't come through the carburetor- and is actually a worse situation. It is unbelievably rare, but I've seen it...and in the case of a bad needle and seat or float, much less of a problem, unless someone just leaves the engine running. I've seen crankcase oil dilution from that, too.
#31 |
That's exactly what I was looking at.
Years ago I had a really nice '69 Nova with the deluxe trim and the wrong year rally wheels. One day I noticed fuel dripping out of a bad mechanical fuel pump through a weep hole in the pump and of course replaced it. That tank is located way in the back under the trunk and under the frame and who knows if any fuel flowed into the crankcase before I caught it, didn't know enough to check the dipstick level. Now picture a 20 gallon gas tank essentially turned sideways behind you up in the cab, well above the frame and a leaking fuel pump with open access to your engine crankcase and your garage floor. |
#32 |
Getting ready to try to figure out the fuel line routing to my electric pump.
Thought it might be too close to the transmission crossmember but a short piece of rubber fuel hose will slide right over the top of the crossmember to meet a hard line. ...so far so good. ![]() Pinched the short rubber fuel line from the tank to the beginning of the hard line with vicegrips and cut the line. Fuel started pouring all over me and the floor?!? Thought it was just residual fuel in the line from the mechanical pump up front so I allowed it to drain out...but it continued. ![]() Turns out I cut the fuel line on the wrong side of the vicegrips and the tank was draining out all over me. Decided right there and then that I don't want a woodstove in the garage for heat and I'm done tinkering for tonight.
#33 |
Active Member
![]() Join Date: Feb 2009
I put a carter fuel pump on my big block with quadrajet and the pressure was too much and caused it to flood out. Put a 3# pressure rgulator on it and it works fine.
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
#34 | |
The Carter P4070 is supposedly putting out between 4-8 psi and will be feeding a Edelbrock 600 cfm model 1405 (I think) so it might or might not need a regulator in the end. Should be interesting if I get my lazy tail up to the garage and continue installing the dang pump.
#35 |
My 72 has a mechanical pump with a return line. If I put a pressure regulator on the feed line to the carb will the pump handle the "back pressure" or do I need to plumb in a return T from the carb supply line to the pump return line and put a check valve in there too. I think my return is 3/8
#36 |
Went to remove the hard line that goes from the tank to the mechanical fuel pump that runs along inside the frame, and all went well except for that last clip which of course is hidden in the most inaccessible place on the truck.
There probably is a simple technique for removing that clip but I don't know what it is. Spent about 2 hours fighting with that stupid thing with every feasible tool I could come up with in my toolbox until finally it broke free from the frame. I'm taking the rest of the evening off.
#37 |
The Older Generation
Not only is it hard to get to but you can't see in there either....
#38 |
I figured if you replied at all it would go something like: "You big dummy, all you gotta do is...
![]() I appreciate the sympathy and understanding, that thing was a nightmare!
#39 |
Ok, I really am in the market for one of these babies!
#40 | |
Really not that bad if you consider the fact that some people pay good money for a noisy Pete Jackson gear drive. ![]() Much more leak testing and cleanup before I take a test drive to determine if I need a regulator or not but I think I'm going to be happy with it in the end.
#41 |
Bzzzzzzzzz
Bzzzzzzzzzzzzzzzzzz Bz |
#42 |
Has anyone thought about a small box with a fan to mount a pump in. I have a pelican case type cigar box that would be perfect size and could maybe be adapted.
I really wish someone would come up with an in-tank high flow pump that would mount onto the factory flange on an in-cab tank.
#43 |
![]() Join Date: May 2006
Looks good except for the clamps I hate worm drive not only will they slice a finger open. They will not stay tight as the rubber deteriorates I prefer a good spring clamp
Someone said that glass fuel filters burn down more houses than ex wives
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#44 | |
![]() Join Date: Jun 2022
I replaced every damn one with an Adel clamp
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
#45 |
I'd give you the flipping the bird icon but I'm more mature than that...maybe not.
![]() Yeah I'll keep an eye on them from time to time but I don't trust the spring clamps myself. I'm most impressed with the fact that I was able to bend the original line over the top of the transmission crossmember, that is a right-handed tube bender and I'm left-handed, I kept bending the tube in the wrong direction. ![]() It should make rubber fuel line replacement at the pump easier in the future though.
#46 |
Maybe unwelcome advice, but...
I would not put a plastic filter under the car. Anything hanging off a line should at least have an Adel clamp on it. I'd take a hard look at minimizing rubber hose use where you can by using hard lines and unions. I kinda cringe at that many clamps in that short of a run. I'm not suggesting you have to do AN stuff, but even brake-type fittings would maybe be a better choice... |
#47 | |
I could probably squeeze a 3/8" metal filter in there...maybe. I've never tried using anything other than rubber hose connections ever so I'm hesitant to experiment with anything else. I might regret that hesitation eventually though. ![]() Yours looks like a nice setup!
#48 |
Changed over to a metal filter and decided to give those spring clamps one more try, now I know why I hate them.
![]() Using conventional pliers I managed to launch a clamp across the garage and into another dimension, fortunately I had spares. Anyway it's not leaking so I consider the whole experience a step in the right direction.
#49 |
That’s sure a bunch of clamps.
Did you at least single flare the metal lines? |
#50 |
No, but that is a good idea, checking out the tools on Amazon.
ETA: Does anyone even make a relatively inexpensive flaring tool for steel lines? Last edited by BRL; 03-13-2025 at 02:35 AM. |
| Bookmarks |
