Old 02-19-2026, 11:28 PM   #26
Getter-Done
Getter-Done's Avatar
Re: 1972 K30 Custom Camper Duramax/ZF6 Highlander
I really like that crossmember.
I would have probably kept the tube Thick and used DOM tubing for the bolt locations, but I like the way you recessed it and used shorter bolts.
The early bird gets the worm,
85 Chevy K-20
Old 03-02-2026, 09:49 AM   #27
ShortbedClayton
Motor is mounted. Finished up inner mounts this weekend. Fabbed an outer crossmember for the engine to tie the frame rails together. Integrated a Panhard bar. All 1/4” players on mounts. 0.25” wall DOM for Panhard bar. 3/8” adapter plates on the engine and using stock 1972 3 bolt motor mounts. Finished up my passenger side frame notch and gussets as well. Got to do drivers side and clean up some welds.
ShortbedClayton is offline   Reply With Quote
Old 03-02-2026, 09:51 AM   #28
ShortbedClayton
Couple more progress pictures
