Old 10-15-2025, 01:07 PM   #26
53Charlie
Re: First build, 1953 pickup
Thank you NVRDONE. I recall in the suggestions and recommendations that came with the Fatman Fabrications MII kit, keeping it simple, regular (no vacuum assist) brakes and manual steering. I should have listened! It took several weeks and three different attempts to finally have a steering high-pressure hose that would fit and would not leak
53Charlie is offline   Reply With Quote
Old 10-21-2025, 11:58 PM   #27
53Charlie
Making some progress, I was able to grind a little clearance in the lower part of the motor mount, now the shaft and the joint turn freely. I used the “homemade double-D machine” to make the slightly longer shaft
Old 11-10-2025, 07:41 PM   #28
53Charlie
Allrighty, the suspension is all in and the lower A arms almost, almost horizontal. I am going to leave it there for a few days to see if it settles down.
Old 11-10-2025, 07:58 PM   #29
53Charlie
I like the original gauges, and have modified the case to use the gauge mechanisms from a late 80’s Camaro. I drilled the button in the middle to add the Check Engine light. I made overlays based on the restauration decals commercially available.
Old 11-10-2025, 11:33 PM   #30
dsraven
nice.
all that little stuff taks forever to get done right, but it's good when it's finished.
Old 12-22-2025, 05:25 PM   #31
53Charlie
I mentioned earlier I am using a 1992 S10 Blazer tank. The tank itself is a new replacement, but the fuel gauge / fuel pump structure is original 1992. I checked the fuel gauge sender when I added the Walbro 255 pump, everything worked ok. A couple of weeks ago I went to crank the engine and immediately noticed the whirrrr sound from the fuel pump was gone. I was bummed that the Walbro had crapped out with less than one hour running time, but the pump was fine, it was the corrosion in the pins of this little connector on top of the tank. The ground wire showed completely open, no conductivity whatsoever. A good cleaning and she is back running good.
Old 12-22-2025, 10:59 PM   #32
dsraven
good troubleshooting to find that issue. thanks for the pics too.
I remember doing a fuel pump on a grand prix. the fella limped in after it wouldn't start. when he phones I told him to whack the tank a few times with a broom handle or a stick, to set up some vibrations, then try again, it worked and i advised him to keep it running till it was inside my shop.
long story short, i got the old pump out of the tank and found the wires inside the tank, from the inside connection point down to the fuel pump, were actually fried and the insulation was cooked right off. bare wires with a burnt pvc coating. that would have caused a little excitement had anything gone sideways
I have also found quite a few GM fuel pumps with a bad ground wire where it connects to the truck frame or car unibody. sometimes fixing that has saved me draining and dopping the full tank (they're always full when the in -tank pump quits, lol)
Old 02-05-2026, 08:36 PM   #33
53Charlie
I try to figure ways to save money on my build. I am retired and do not have unlimited resources. So, allow me to introduce my eBay score, a $10 electronic speedometer. It appears it was never installed, but it had no instructions whatsoever, and although the brand sounds well known, there is absolutely no information anywhere on the web about how to install it, or how to calibrate it.
Old 02-05-2026, 08:45 PM   #34
53Charlie
So I spent $60 having the Speedo checked by a specialized shop in California. They told me the speedo works, and told me what wire was 12v, what was ground and what goes to the VSS. There are two other wires I have no idea what they are for. But the speedo was very easy to adapt to the trim rings in the truck, and miraculously, it works, and it appears the calibration is almost right on the money. Sorry for the tilted pictures, I have no idea why they get tilted when I upload them
Old 02-05-2026, 10:20 PM   #35
dsraven
Good chance one is a power for back light and other is a ground for back light? No other functions on the gauge, right?
Old 02-05-2026, 10:22 PM   #36
dsraven
Sorry, there is a highball indicator there too. Disregard the ground circuit cuz it already covered or other stuff wouldn't work.
Old 02-06-2026, 12:49 AM   #37
53Charlie
Hi dsraven, thank you for the input. There are two holes in back for lights, and one hole for the hi-beam indicator in the middle. So I don’t think the extra wires are for lighting.
It appears this speedo was made for large trucks, so maybe those extra wires could be for some function depending on speed? Or, you know how some of those trucks had a two-speed rear axle, so maybe some correction for that? In any case, it appears I do not need those extra wires, the speedo and the odometer are working. There are 10 dip switches in the back, I will figure how to use those to adjust if needed
I know most aftermarket speedos go to 160 mph or more! I don’t expect I will ever go past 85 mph so I’m good 😊
Old 03-02-2026, 11:09 PM   #38
53Charlie
Progress report, I connected the speedo according to the instructions from the speedometer shop, amazingly, it worked, and it even appears to be pretty close to calibration!
Old 03-02-2026, 11:19 PM   #39
53Charlie
A little info on lighting; the two bulbs in the back of the quad gauge just did not provide adequate light. I painted the inside of the box silver, and I found a 12V LED “tape” which I glued to the perimeter.
Old 03-02-2026, 11:27 PM   #40
53Charlie
I had to put a 100 ohm resistor in the LED feed line because it was too bright. I am pleased with the result!
Old 03-04-2026, 10:17 AM   #41
dsraven
cool idea. it's well lit now for sure
Old 03-08-2026, 04:51 PM   #42
53Charlie
Working on adapting the steering wheel. I am using a shortened 1975 Chevy Van tilt column, and a mid 60’s Chevrolet steering wheel. The splines match, but the hole for the horn contact is in the wrong place (2:00 position). For the horn and the turn signal cancel to work, the horn contact hole needs to be at the 10:30 position. I had to drill the hole a little “earlier” (maybe 10:00?) because it would have eaten one of the three holes where the horn attaches, but it will work.
Old 03-27-2026, 11:41 PM   #43
53Charlie
Steering wheel in place, gives it the “old time” look I was after. Slowly cleaning all the mess of wires hanging under the dash
Old 03-30-2026, 03:05 AM   #44
Blackie
Blackie's Avatar
That does look good mate - nice choice
It always seems impossible until it's done
Blackie is offline   Reply With Quote
Old 03-30-2026, 05:05 PM   #45
daveshilling
daveshilling's Avatar
That looks great! I'll have to drill the same hole sometime if I want my horn back
daveshilling is offline   Reply With Quote
