![]() ![]() Join Date: Feb 2009
Parts Lot, Primarily 1971-ish Truck Stuff
Everything here is sold, even if it doesn't read so. The only exceptions are the jack assembly, and the rear license plate lamp. I'll put those on a new thread. Thanks a bunch.
NOS Stuff NOS rear license plate lamp, $75 NOS Outer roll-up window sweeps, $150 SOLD NOS Vent Window Channels, for the roll up window's front. I can unwrap them for a picture if you like. I've seen them before, they're perfect, including the chrome strips. Maybe you've seen these before, they're basically GM replacements. The tops aren't quite like original but they work. They do not come with brackets to mount it to the doors, nor the holes for the brackets, they'll have to be drilled, $125. SOLD NOS interior door handles, $100 SOLD NOS replacement rear lenses. These have some of the same markings as GUIDEX lenses, the appearance too, and they're at least as heavy as original. These are better quality than today’s replacements, and are very clean, $20. NOS hose breather Assm., 10118694, probably not for trucks - if you recognize it $2, I think the old pinch clamps are worth that☺ NOS crankcase hose pipe, PCV, adapter, 3856955. Looks like some 66-67s take it, for example, $5 NOS crankcase fire arrestor. I don’t know the application short the fittings are BIG, $25. Nice score if a guy needs it. Okay, $20, no, $15☺, no, $8. NOS emblem paint syringes - apparently. I'll just keep them. NOS vintage radiator hose clamps for couldn’t tell you. If you like them $5. Let me know if you need measurements, they're pretty cool. OEM Stuff OEM lug jack, handle and lug wrench. Works, the metal excellent and real nice finish $120. Two nice C10 hub caps. One never painted and the stainless is perfect. The other was painted and polished, but has a few small dings that are an easy fix, described the arrows in the image. Can’t imagine why someone painted and polished it so nice, dings included. These are not a matching pair, while it's not easy to distinguish, GM installed many varieties of these stainless caps, the differences are primarily at the ring surrounding the bow tie, and weights can vary too. Asking $70 each. SOLD OEM truck tie downs, they’re in excellent shape and will clean-up super if you care to, the finishes are perfect either way. I don’t know what they’re worth, but if someone is looking for these, I think $25 would be a deal. SOLDOne NOS Deluxe Badge with some pitting. The other is used, but the chrome is beautiful, $10 for both. Two OEM 400 badges. One has excellent chrome, the other is okay, and was used to experiment with a black epoxy finish. FWW, it held up remarkably under test conditions, $5 OEM oil cap, I think so anyway, hmm. Buy something else it's free. OEM Grille brackets, for a 1971-72, perhaps earlier too, I don’t know. $40 SOLD OEM tail housings, nice shape, $25 SOLD One fuel cap, I believe it's OEM, for an auillary tank, needs a new gasket - buy something it's free. One OEM spare tire bolt and wing nut. It's OEM, but I don't know the application, $10, wing-nut is worth that easy, hmm, maybe I'll keep it☺ Called for☺ Couple of OEM bed towers, buy something it's free. OEM washer bottle bracket, $10 SOLD Nice pliable and clean OEM brake pad: $3 I'll just keep it. Some vacuum fitting, if you recognize it - free if you're paying shipping. called for OEM points distributor and parts. It came off a 1971 402/400. The distributor (1112064-0M7) basically failed back in the 90s, I switched to HEI. I don’t know why the distributor failed, someone else was doing the work. If you want these parts just pay shipping. CALLED FOR Replacement Stuff New replacement sport bumper bolts and hardware. Somewhat replacement, the fronts are supposed to have smaller heads, what can you do, I suspect the fronts aren't reproduced. $8 New replacement bed bolts with hardware, $15 SOLD New replacement 5/16-18 Rally cap bolts, 20 of them, $7 New brake boot, free if you buy something. I'll just keep it. New blower gasket at the firewall. I'll just keep it. New replacement fuel sender for without a return line. Part number 72-9300-S, $20 is half the price otherwise available on this part. New replacement heater water hose tower clamps, $5 New correct type replacement thermostat housing, since painted with POR15 engine. Sprayed if I remember right, turned out pretty nice. I ended up with three of them somehow☺ Spray isn't as durable as a brush with por-15 engine FWW, which applies nicely on cast iron. Looking forward to painting the original housing I thought I wasn't using SOLD Buy something for $15 more I'll put a copy of the kit into the box. It's described by my signature.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-05-2025 at 01:06 PM. |
| Bookmarks |
