Old 12-13-2025, 01:05 AM   #26
0ldSoul
0ldSoul's Avatar
Re: Another '63 Restomod Build
..for now I decided these uppers designed to add up to five degrees of caster while providing full wheel travel should do the trick.
Current: Another 1963 C10 - Build in progress
Sold The '63 Restomod Build - 283/4 speed, 4.5/7 static drop, disc brakes, power steering
0ldSoul is offline   Reply With Quote
Old 12-13-2025, 02:19 PM   #27
SCOTI
SCOTI's Avatar
I never saw anything construction wise that looked 'different' as far as geometry on their uppers.
Could you get a pic of one of those uppers paired next to the same side OE arm for a visual reference before you get farther along?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-13-2025, 03:15 PM   #28
0ldSoul
0ldSoul's Avatar
Yikes, I hope that's not the case. We're about to head out to camp, but I'll get a side by side comparison when we're back.
Old 12-13-2025, 11:43 PM   #29
SCOTI
SCOTI's Avatar
I can see where the Caster gain is on the lowers but not the uppers.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-17-2025, 12:22 AM   #30
0ldSoul
0ldSoul's Avatar
Here's a few pictures. It's not significant, but the geometry is different where the ball joint mounts.
Old 12-17-2025, 01:30 AM   #31
SkinnyG
SkinnyG's Avatar
That angle allows you to air out without locking the upper balljoint. I pie-cut my own uppers to do just that.
Show us a picture of both arms as viewed from above - so we can see the "A" shape of both. That will show the geometry change if any.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-17-2025, 10:50 AM   #32
SCOTI
SCOTI's Avatar
^^ This exactly. ^^
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-18-2025, 12:03 AM   #33
0ldSoul
0ldSoul's Avatar
^^ This exactly. ^^
Gotcha, right on. Thanks for the info! I'll grab another picture in a bit.
Old 12-18-2025, 12:35 AM   #34
0ldSoul
0ldSoul's Avatar
Alright, so I tried to line it up as best as I could. What do you guys think?
Old 12-18-2025, 01:03 AM   #35
SkinnyG
SkinnyG's Avatar
If the balljoint location is moved back a bit, you are indeed getting more caster (yay!). If it appears to be in the same location, these arms only allow for a lower ride height (still yay!). It _appears_ that the ball joint is further back.
Small movement is a significant improvement in making these trucks "handle" a whole lot better.
Are you moving the lower arm forward at all?
Old 12-22-2025, 09:27 PM   #36
0ldSoul
0ldSoul's Avatar
Thanks for the info. I wasn't thinking of moving the lowers.
I found an old thread where the shafts were re-drilled to move them forward and increase caster. Is that what you're referring to or is there another way?
Old 12-22-2025, 10:47 PM   #37
SkinnyG
SkinnyG's Avatar
That is the way.
I drilled two new locator holes on my '77 (shown below), but you may only need to drill one.
I only drilled one (per bar) on my '61 (73-87 arms modified for 88-98 ball joints, and to clear Fox Mustang rack):
The '77 - note the spacing of the arm on the crossmember - arms is moved forward about 3/4":
Old 12-23-2025, 12:55 AM   #38
0ldSoul
0ldSoul's Avatar
That is the way.
Looks good! ..and relatively easy. How did you go about drilling it? The thread mentioned taking the shafts to a machine shop.
..besides drilling a new hole, everything else was pretty straight forward? Just simply moved it forward that 3/4"?
Old 12-23-2025, 02:03 AM   #39
SkinnyG
SkinnyG's Avatar
Pretty straight forward. I usually have to beat a bit of the crossmember edge in to make sure there is full range of movement. There are a variety of threads here on doing this - that's how I learned of the mod.
You could carefully measure, and then work your way up in drill bits to final size. I don't remember what size exactly, but you can buy a deming bit that will work. It's just steel, there is no magic here. The bigger the bit, the less fun they are to drill. I.... have a milling machine....
Old 12-23-2025, 10:25 AM   #40
SCOTI
SCOTI's Avatar
The CPP lower arms are where the geometry change is. They did this same mod to their lower arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-31-2025, 11:03 PM   #41
0ldSoul
0ldSoul's Avatar
The brackets arrived
generously 8.5" wide so the bags don't make contact
all 3/16" except for the rings on the drop pockets, those are 1/4"
Old 01-01-2026, 05:18 PM   #42
SCOTI
SCOTI's Avatar
If you're going to move the lower stock arms, mock things up to make sure all parts are happy once in place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-03-2026, 01:28 AM   #43
0ldSoul
0ldSoul's Avatar
Not going to move the lower arms for now.. mostly because I plan to eventually replace the front end with a drop member and Porterbuilt control arms
Christmas gift from my brother
a Lincoln 180i MP DV!!
Old 01-04-2026, 09:52 PM   #44
0ldSoul
0ldSoul's Avatar
Got the new ball joints pressed in.. got this done now since a buddy let me borrow his press kit
I went a bit deeper while drilling out the butt welds so I had to tack weld some material in
.. then it was time to trace the template for the air ride drop pockets
I was cautious, leaving quite a bit to grind away but I wanted to ensure a tight fit.
Old 01-04-2026, 10:41 PM   #45
0ldSoul
0ldSoul's Avatar
Happy with the fitment
Old 01-04-2026, 10:43 PM   #46
0ldSoul
0ldSoul's Avatar
After not welding anything for a couple of years, I began by practicing on some scrap 3/16 metal, got back into the groove, and started burning these brackets on
Old 01-05-2026, 11:12 AM   #47
SCOTI
SCOTI's Avatar
Looking good.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-05-2026, 02:06 PM   #48
cj847
cj847's Avatar
nice welds!
cj847 is offline   Reply With Quote
Old 01-11-2026, 01:32 AM   #49
0ldSoul
0ldSoul's Avatar
Looking good.
Originally Posted by cj847 View Post
nice welds!
Old 01-11-2026, 01:33 AM   #50
0ldSoul
0ldSoul's Avatar
Not a crazy update, but an update none-the-less
Winter's harsh in Las Vegas
