Old 01-20-2004, 06:26 PM   #26
Tom
driving is in my blood
Tom's Avatar
Over the weekend I got a 5.0 mustang almost finished [hehe], completley took apart my vortecs to get ready for the machine work, did lots of research on springs/pressures to match my component selection properly, gave the machine shop guys a little motavation to get my stuff done quicker, and started sanding down the 79 to get ready for the new paint so I can sell it.
Old 01-20-2004, 07:05 PM   #27
C-10volvo
C-10volvo's Avatar
today i installed a jbl 1200 watt amp under the seat. HUH? IS IT LOUD ENOUGH?? i did blow one fuse when i really had it cranked. i might have to upgrade to 0 gauge wire
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 01-20-2004, 09:33 PM   #28
SCOTI
SCOTI's Avatar
Yanked the 3spd tranny out of my 68. What year did they start adding metallics/pearls to the gear lube ?
Now to decide which direction..... 5spd or 700R4??????????
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2004, 12:24 AM   #29
apstguy
LED King
apstguy's Avatar
I replaced the belt on the Tahoe, put clear corners on the Tahoe, charged the jetski battery, and checked all the fluids in my truck.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 01-21-2004, 02:19 AM   #30
87 Shortwide
HEHEHE, you just had to ask
ALRIGHTY...
My buddy keeps whining to me that his car sounds funny and it needs fixed, so I determine that there is something wrong in the valve train.
Yank a cover off, run all the valves...were good to go
Next day it starts making odd noises again, so I yank the covers again and determine that a stud must be coming loose. Find the loose rocker and decide that the easiest fix is to pin the stud cause he doesnt wanna spend much cash.
Well I have to pull the intake to get to the stud, so I do....then Im curious, I pull that lifter and it is SCREWED all up. were talkin you could use this thing for a golf tee.
So I end up yankin the motor to put a new cam in, and out of curiosity again...I roll it over and pull a few mains to make sure that no iron filings got in them.
hahaha, the mains have a odd wear pattern....later find that the crank is bent
Then I find that every single rod bearing is trashed, so the motor pretty much gets a complete overhaul.
Good thing it aint my motor or I would kill the guy that built it 2700 miles ago!
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 01-22-2004, 11:28 PM   #31
zzChevy
BANNED
Test fitted a new Holley 650 Double Pumper for the ZZ4 that'll be put on Saturday. Will be adding a lowprofile 6" aircleaner to top it off, AN fittings and braided hose are being run down to the pump. Also have a 1" spacer and in line fuel pressure gauge thats going to be used too. Looks mighty sweeeeeeet. Will post pics Sunday.
zzChevy is offline   Reply With Quote
