Old 01-19-2026, 05:01 PM   #26
dennislbrooks
dennislbrooks's Avatar
Re: Can you run the Power Disc Brakes w/ Clutch Pedals?
There are very good ideas above.
I am not saying to do this but just got me thinking about what I have on my 59. I converted my brake to top swinging with the master cylinder on the firewall. I now run a column shift automatic. I just let the clutch pedal drop to the floor but is still there under the carpet and could be used. The master cylinder and underneath brake pedal are gone. I kept my hand brake.
I could have swung both from top if I knew I was staying manual.
My top pedal thread.
https://www.67-72chevytrucks.com/vbo...d.php?t=843333
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 01-19-2026, 07:27 PM   #27
dsraven
having trouble uploading pics, sorry. had a few of my envoy donor vehicle pedal assy which sandwiches through the firewall and has pedals, accel pedal for drive by wire, 11" vac booster and disc/disc master. mounted to plate that offsets the assy towards the engine side of the firewall for a little more foot clearance. keeps accel pedal off the floor as well, in case you have a crowded area from a recessed firewall etc.
ill try again tomorrow
Old 01-20-2026, 12:51 AM   #28
dsraven
envoy pedal assy
Old 01-20-2026, 12:55 AM   #29
dsraven
just an example. possibly another donor vehicle would have a set of pedals and booster etc that has the clutch included. seems I can only post a single pic at a time
if you sandwich the firewall with a set of hanging pedals and booster etc just ensure to brace things from firewall to dash so things are strong and also so they don't fatigue and crack the sheet metal
Old 01-20-2026, 12:59 AM   #30
dsraven
disassembled
Old 01-20-2026, 01:00 AM   #31
dsraven
firewall plate has hole and grommet for steering column shaft and another for wiring harnes grommet
Old 01-20-2026, 01:05 AM   #32
dsraven
from the inside without dash and pedals etc. an example of the firewall plate, which gives strength to the firewall area around the pedals and booster etc. bear in mind this was a frame swap and I used the floor and firewall drom the donor since my stock floor was not structurally sound
Old 01-20-2026, 01:10 AM   #33
dsraven
please disregard the untidiness, its in mock up. this shows how it all looks from the engine side with the envoy inline 6 and waaay too much wiring etc exposed
Old 01-20-2026, 01:12 AM   #34
dsraven
ok, sorry, still having trouble with adding pics, uploading, then they disapear when i hit post.
pm me if that interests you and i can just simply email them to you
Old 01-20-2026, 02:21 AM   #35
leegreen
some more firewall setups in this thread
https://67-72chevytrucks.com/vboard/...d.php?t=840996
I sense OP wants a proven approach that does not bite the wallet....check joedoh's s10 pedal setup in that thread and elsewhere. I think he sells and plate and template to take all the guesswork out as well.
leegreen is offline   Reply With Quote
Old 01-20-2026, 02:14 PM   #36
dsraven
it seems like joedoh has a pretty good set up. if you have a pick n pull nearby maybe cruise a few isles and see what you find. even the envoy set up could easily be modified to accept another pedal and a clutch master but, why not use something already built and spend that fab time on something else.
Old 01-20-2026, 03:34 PM   #37
dsraven
Checking if I can upload a pic.
Underhood on my 57 showing envoy brake booster. Rest in mock up
Old 01-20-2026, 11:38 PM   #38
wesmigletz
wesmigletz's Avatar
Thanks again everyone for all the suggestions.
Dennis thank you for the link
dsraven, I appreciate all the suggestions. Hoping to get something going without too much fab work.
Leegreen, I will look into the S10 pedal set-up
https://wesleymigletz.smugmug.com/Ga...2-PM/i-zf8rDsK
1970 2WD K5
1970 Bronco
1967 Chevy SWB
1964 Malibu SS
1955 Chevy Truck
wesmigletz is offline   Reply With Quote
