#26 | |
Re: Some carb advice for a new guy.
I've uploaded a copy of the 500CFM 1901-1904 chart for any that may be interested.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
#27 | |
![]() Join Date: Jul 2000
At high engine vacuum (when cruising) we have the .073" diameter in, let's say, a .100" jet. But, when vacuum drops during acceleration, the rod lifts up and now its small .047" diameter is in the jet for a richer mixture. The rods work in conjunction with step-up springs to determine the vacuum at which they operate. On at least some of the original equipment AFB carbs used on AMC, GM, and Chrysler performance engines, the rods had 3 stages, which would have made for ultra-fine tuning. I don't think the aftermarket universal versions of AFB carbs had 3 stages. The metering rod equivalent on a Holley is the power valve, which is designed to open when manifold vacuum drops to a certain level adding more fuel for acceleration. The most common size being 6.5"hg for a mild performance engine. Page 3 here is a better explanation of how the metering rods and springs work together. https://www.edelbrock.com/media/wysi...ers-manual.pdf
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-25-2026 at 03:00 PM. |
#28 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I know how a carb works. I also have the guide that came with the cal kit.
#29 |
You asked a couple questions, but I guess I went overboard!
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#30 |
No biggee. Someone will get some use from it.
#31 | |
![]() Join Date: Feb 2002
When they quit the carb business [in the Mid '80s -- due to factory fuel injection] Federal Mogul took over building AFBs for the aftermarket. Edelbrock also got some AFBs from the same Weber factory still making them, and marketed them with a higher polish and emphasis on high performance parts. To my knowledge, no one still built the AVS. [Until Edelbrock revived it fairly recently.] The original AVS carbs had three stage Metering Rods and Jets. The middle apertures were to dial in midrange performance. I have an old Carter AVS i found discarded as a prop after a movie wrapped. Instead of annular rings in the secondaries, it has 1/4'' x 2''[~] probes with many small holes. I bought Edelbrock AVS2 Rods and Jets in the hope of rebuilding it, but found they were only two-step. Edelbrock consolidated logistics by converting the AVS2 to use 2-step parts like their Performer [AFB] Federal Mogul quit making AFBs in the early 2000s. Guys at the local Hot Rod Shop said my rebuilt AVS would ''Probably run like ass anyway'' so I dropped the project.
#32 | |
That is still one of my all time favorite carbs. Every one of them was configured by the factory (GM, AMC, Chrysler) for a specific engine. I never even re-jetted mine, because it worked so well (and I wasn't very knowledgeable about carbs back then). Tried to find that exact model/part number many years later for a 327 that I had built. There were a few available on eBay and elsewhere, but prices were stratospheric.
#33 |
I want to add that all Edelbrock Performer-series carbs use Air Valve Secondaries, not just the ones ones branded AVS and AVS2, which are adjustable. I copied this explanation from a Jeff Smith article:
"The AVS name is an acronym that stands for Air Valve Secondary. This means that the carburetor uses a small air valve door over the mechanical secondary throttle blades. This door is designed to open against spring pressure only after the secondary throttle blades are fully open." What he didn't say is the air valve on the earlier Edelbrock carbs used a fixed weight instead of an adjustable spring. So instead of overcoming spring pressure, the air valve opened when air flow overcame the counterweight. Sometimes guys would lighten the weights, but that could introduce a bog. Also, the AVS2 has a major improvement, and that's the annular boosters. Plenty of info about them in the Interment.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-27-2026 at 01:30 PM. |
| Bookmarks |
