#26 |
the white box is a early style trailer brake (mechanical), may have been a dealer installed item, will be removing it as soon as the brakes are open to put disc parts on.
beater 65 gmc at the moment |
#27 |
cpne, where do I look for the code and I will post it for you, I think GM calls it light green.
#28 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#29 |
cpne, 04533AD Light Green/Off-White
inside is 04616AC Green Vinyl trim
#30 |
Navel Inspector
yeah, I'm kinda scared to dig up my carpet. Feels solid though. That count???
1948 Chevy Aerosedan GONE! I think. 1984 Cadillac Fleetwood Brougham Coupe WANTED 1967 IMPALA 1967 CST C10 Long Bed with a 283 |
#31 |
dynamat
cost aside anyone used Dynamat that was unhappy with the results? How about Dynamat Extreme? If a person needed to remove Dynamat to make a change or repair will it come off? Any chance of rust growing under it?
#32 | |
Resident Curmudgeon
Thanks!
#33 |
floor update
Well I covered up the green floor, it needed a little attention at the edge where the carpet meets the kick panel on both sides, the kick panel was worse than the floor, I guess from wet shoes and sand. If those areas need attention in the future they will be real easy to get to, the rest of the floor was really cherry. Here are the middle photos, the dynamat first (full coverage), and then a little of the rv type insulation in the flat spots, laid the carpet in it seems stiff will have to heat up garage before fitting.
#34 | |
My other Love
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#35 |
Young Gun wth Fast Inline
veltrex, where in idaho are you. btw nice truck and it looks like you want to keep the sound inside.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
#36 |
stelth, near Boise, I am more concerned about keeping sound out than in, bb tends to rumble some at slow speeds, and road noise was loud.
#37 |
I would be very interested in your opinion of the differance the dynamat makes when you start driving it. Will probably be doing it to my suburban in the next 2 to 3 months. By the way, the install looks awesome, are you that good, or is it just easy to install!!!
1972 Chevrolet Suburban ('68 front clip), 2wd, 350/350, factory tilt 2008 Kawasaki Concours 14 ![]() 1997 Harley-Davidson Soft Tail Custom 1948 Chevrolet Coupe (project) 1972 Porsche 914 |
#38 |
If you think thats cab rust you should see the cab on my first 67 it's rotted BAD!!!
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
#39 |
68plus, its a piece of cake, I'll try to have it on the road this weekend and will post how it sounds.
#40 |
![]() Join Date: Dec 2002
.... my '71 GMC has 402 eng. with 400 trans... and is low hump !
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
#41 |
Wow that's clean enough to eat off of.
I'm gonna probably be ripping out my interior soon to save myself some man hours at the body shop, planning to have my 72 LWB GMC painted soon, and since the interior already has been painted once (I think) I'm gonna go ahead and have the interior painted too, and change away from that godawful green. My plans are to use that brown bread "cheaper than dynamat" stuff over every surface of the interior that I can to help with noise/heat. So I'm very curious in what sort of difference you notice in yours. 402BB here so less noise inside is good. |
#42 |
its all about the +6 inches
For all of you who have enver seen a truck floor from this side of the states, feast your eyes on this Kansas truck's floor. People around here say it is fairly clean just becouse the floors are original and not made from no parking signs.
#43 |
an update
just wanted to update my progress, got it all done, huge difference in sound level inside, happy with all products used, one small thing aside, when I went to put my carpet kit in I realized they dont go all the way to the kick panel, there is a small gap there 1/4 to 1/2 inch, which you dont notice when your floor is stock because the floor color shows through. And since I was very thorough installing the dynamat it goes flush to the kick panel, so I ended up with black carpet next to a line of bright foil shining through. It bothered me and ended up pulling carpet back and spray painted foil flat black. Just a heads up to do something with the edge, leave it, paint it, carpet welting maybe. Also used longer bolts for the seat. I bought the Dynamat extreme 36 square foot pack, and I did the floor, had two of the sheets left over, once I prep and have some rust fixed inside one part of each door I will use the dynamat on the inside of both doors, in hopes of killing a little more noise and making my speakers sound better. Thanks for the input of all who posted.
#44 |
Thanks for the details, makes you feel better doing a project when you know it has already worked well for someone!
#45 |
thats a hydraulic trailer brake head.
yeah, but how's it wheel? |
