01-30-2004, 11:27 AM | #26 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-30-2004, 12:15 PM | #27 |
its all about the +6 inches
Cool, thanks for the clearifcation.
01-30-2004, 01:47 PM | #28 |
As for the power brakes, my '72 Super came with manual brakes.I have since changed over to power brakes . You can always pull the metal trim ring on the headliner and see if there are holes in the roof for the snaps for the ring. I believe (I could be wrong) that cheyennes had the headliner as part of the interior package, and others didn't. If the holes aren't there, it's not a true cheyenne, and the owner added it after the fact.
Someone please correct me if my facts are wrong. Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
01-30-2004, 01:52 PM | #29 | |
Resident Curmudgeon
01-30-2004, 03:01 PM | #30 |
CPNE,
Thanks. It's nice to get a fact right once in a while. I hate giving people bum scoop. There always seems to be some miniscule excetion to every rule I think I know. (Can you tell I'm frustrated with my College Algebra Homework? )
01-30-2004, 03:54 PM | #31 |
The head liner trim holes that he is referring to will include one for a regular screw in each corner and the middle of front, back, and each side (I think anyway) and would be very easy to drill. The other holes are oval shaped, about 3/8" x 3/4" and would be very hard to cut in and have it look like a factory stamp. The trim usually breaks if you try to pull it out of the oval holes so be carefull if you start looking there. If it has the factory oval holes, it is at least a Cheyenne, but doesn't guarantee a Cheyenne Super.
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72) '56 Chevy short step V-8 (My dad bought it new!!) '70 Olds 442 convertible '70 Olds Rallye 350 |
