Old 02-12-2004, 05:37 PM   #26
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I would probably get a fuel hose line and shove it over the end of the supply line and turn the switch on. The electic pump should come on and pump in the run posistion. Just run it into a gallon jug to catch everything.
If you have doubts about the foam, call the manufacturer and ask them about pulling it out, first. Like I said I haven't pulled any out before.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-12-2004, 06:47 PM   #27
RockHQ
ROCKET POWER!
RockHQ's Avatar
You might want to take a look at the factory fuel lines (whatever's left after all the mods you've done). If there was water in the system it might have caused them to rust on the inside, possibly clogging them.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 02-12-2004, 08:32 PM   #28
swervin ervin
You get what you pay for
swervin ervin's Avatar
Good idea rock. Never thought about that. Could be if it did rust some of it may be turning loose and pluging things up.
Anyway, if you still have the fuel pump running through the oil pressure switch like you SHOULD (read: better have for safety), the fuel pump won't run but a few seconds and then quit if the engine isn't running. But, it will run long enough to see if fuel comes out of the line. Just mentioning this in case you see it stop and panic.
Yeah, run a rubber hose on the hard line and stick it in a clear jar or a can to catch the gas.
swervin ervin is offline   Reply With Quote
Old 02-12-2004, 10:27 PM   #29
Low87
been here longer than Liz
Low87's Avatar
Thanks guys! I'll get to it and keep you up to date.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
