Old 02-18-2004, 12:14 PM   #26
barn9
Half a bubble off!
barn9's Avatar
You will need jackstands for the frame of the truck, and a jack for lowering/raising the rear end to get the blocks in.
Dixiesys - if you have any truck magazines, just look in the ads where they sell suspension parts, most of those companies have these kits available. Most of them have websites also.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-18-2004, 12:59 PM   #27
jamis
F.A.S.T. president
jamis's Avatar
Originally posted by pissonNOS
okay so im gonna make some 3"x3"x7" blocks now how low will this get me?
and up front im gonna cut the coils for a 2 inch drop so how much should I cut out of there? also I orderd belltech drop shocks for the front.
I wouldnt go any more then 2" with the block, even the 2" on mine looks scary, if I ever get a flat it will drag the ubolts and trailering arms. The only reason I have blocks is a wanted a total of 7'' drop (using 5"springs). If you just want to drop between 3" to 6" I would just go with the springs.
jamis is offline   Reply With Quote
Old 02-18-2004, 11:33 PM   #28
bad69
Struggling Artist
you want to support the trailing arms and remove the u-bolts then jack up the diff. to install the blocks.
69 1/2 ton lwb lowrider
90 C-1500 2wd
08 2500 HD 4WD
94 Grand Cherokee
49 Cadillac sedan
bad69 is offline   Reply With Quote
