#26 |
Never too many LONGHORNS!
One more thing that I noticed that was missing in regards to these Eaton rear ends is:
1. The HO72 means 7,200 lbs. axle capacity and HO52 means 5,200 lbs. axle capacity. This difference is ONLY because size brake drums that where mounted to the axle housing it's self. There is NO difference in the actual axle housings. Depending on the year there was either 1/2" or 9/16" studs (note 1/2" stud doesn't automatically make it 3/4 ton rear end NOR does a 9/16" stud make it a 1 ton rear end!!! So with this said, you could actually take a Eaton rear end coil sprung 3/4ton and make it a 1 ton by simply changing the brake drums (and backing plates) to the larger ones and have a 1 ton coil sprung Eaton rear axle. Just remember the coils would now Not match the newly found 2,000 lbs. capacity of the rear end!! 2. Two more problems with these rear ends that were not mentioned is: A. The ring gear size is SMALL (About 10") and only has 10 bolts when compared to the Larger ring gear of the popular 14 bolt rear end (ranges from 10 1/2" - 12"!!). The 12" is found on Newer Chevy/GMC H.D. 2500's or 3500 with the 8.1 engines or Diesels Or All newer Dodges 3/4 -1 tons B. The number of splines on the axle shafts (or lack of them). They have about half as many as the 14 bolt rear ends! I actually prefer these axles though..............I like how they look and under the truck and I personally have never had a problem with them!! Jim "69oldie" ![]() |
#27 |
![]() Join Date: Sep 2001
At Randy's Ring & Pinion site download their catalog: P. 27. Here's the snipet. If they don't carry them someone else will. Do a search on Yukon gears. At least this pic shows the part number...
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
#28 | |
And the newer 14 bolt that is in GM and Dodge trucks is a completely different axle, made for them by AAM. I don't believe parts from this interchange with the old style 14 bolt.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#29 |
What's "Yukon"
#30 |
It's the manufacturer Randy's Ring & Pinion deals with. They make a 3.90 gear set for the HO52/72.
