Old 03-08-2004, 04:48 AM   #26
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
I had this happen to my 307...and it sounded real bad, like it was coming from beneath the truck....loss of oil pressure on the freeway and lots of knocking, truck stalled when I got onto the access road and wouldnt turn over unless i had the pedal down.....we assumed it was a rod knock and pulled the motor and replaced it woth another....the motor is still sitting on my dads trailer, coverend up and all...I'm gonna take off that timeing chain cover when I get a chance maybe the motor was salvagable after all....OOOOPS!!!!! BUt luck will be that it ain't cause the guy who rebuilt it rebuilt my dads 250 I6 and it did the same thing on his way to mexico. What a crooked mechanic.....he did something wrong...FOR SURE....sorry to but in an vent....
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-09-2004, 01:52 AM   #27
kiley
Timing
When timing with a double roller chain with multiple keyways, when it's advanced 4 degress does it change how I time it with a timing light?
Will it still be timed to 8btdc
kiley is offline   Reply With Quote
Old 03-11-2004, 04:17 AM   #28
kiley
Timing Chain
Well....I opened up the timing chain cover and lo and behold everything is just fine. It already has a double chain setup and is tight as a drum. My father-in-law wants to do a compression check and go from there.
Old 03-11-2004, 11:27 AM   #29
Yellow Cheyenne
The dist has 2 ways of advancing the timing-mechanical and vaccuum. Sounds like you have already checked the vaccuum. The mechanical advance can either get sloppy and bind up or can get so rusty that it will not move as designed. Either problem can give mechanical advance problems that can be intermittent.
Good luck,
Randy
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72)
'56 Chevy short step V-8 (My dad bought it new!!)
'70 Olds 442 convertible
'70 Olds Rallye 350
Yellow Cheyenne is offline   Reply With Quote
