Old 04-09-2004, 09:15 PM   #26
low 84
low 84's Avatar
your carb and/or timing aren't right. i've got the same set up as you, th350, 2.73 gears and 2800 stall. i've got some more hp and tq than you but still, with that thing set up right it will roast them all over even with 2.73's.
are you sure the secondaries on the carb are opening? something aint right
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-10-2004, 01:12 AM   #27
ocbaud
Garage Queen Material
it idles fine, although a little rough revs nice and quick in neutral and park. the secondarys are opening, i can feel and hear them when they do. does it matter that it only has about 40 miles on it since its been broke in? i can tell the more i drive it, the more it seems to drive better.
ocbaud is offline   Reply With Quote
Old 04-10-2004, 05:27 AM   #28
79Silv4x4
Workaholic
79Silv4x4's Avatar
you'll get it working--BTW, the q-jet was the right choice--I'm sure you know to PM swervin and he can help with any issue you may have. ..
79Silv4x4 is offline   Reply With Quote
