Old 09-14-2010, 11:38 PM   #476
dbmx66
Re: my 80 build
sorry, didnt feel like reading back in the thread, but what you doing with the new frame?
dbmx66 is offline   Reply With Quote
Old 09-16-2010, 08:56 AM   #477
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
mine bent pretty bad and was cut down to short poorly
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-18-2010, 11:31 PM   #478
flamingbig10
6.0 powered square
Re: my 80 build
picked up a new sand blaster from harbor freight but it broke, before I was able to blast the frame
Aaron
Old 10-02-2010, 11:05 PM   #479
flamingbig10
6.0 powered square
Re: my 80 build
started sand blasting the frame I plan on finishing it this week
Aaron
Old 10-02-2010, 11:15 PM   #480
menace121978
menace121978's Avatar
Re: my 80 build
if your sandblasting it yourself you should prime what ever you get done that same day... if not it will start rusting. i had to redo mine for 15 hours straight then go and prime it immediately afterwards. it sucked.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 10-02-2010, 11:36 PM   #481
flamingbig10
6.0 powered square
Re: my 80 build
I'm using some rattle can primmer that's usable on bare metal on the spots I blast
Aaron
Old 10-05-2010, 10:37 AM   #482
87 chevy silverado
Re: my 80 build
updates?
87 chevy silverado is offline   Reply With Quote
Old 10-05-2010, 07:30 PM   #483
flamingbig10
6.0 powered square
Re: my 80 build
frame is sand blasted
Aaron
Old 10-17-2010, 09:20 PM   #484
flamingbig10
6.0 powered square
Re: my 80 build
primed the frame today
Aaron
Old 10-17-2010, 11:32 PM   #485
mooseknuckles
mooseknuckles's Avatar
Re: my 80 build
Are you planning on "Z" ing, notching, or drop crossmember with the new frame? I thought about getting another frame and doing that with mine cause I drive it every day.
mooseknuckles is offline   Reply With Quote
Old 10-18-2010, 12:26 AM   #486
flamingbig10
6.0 powered square
Re: my 80 build
nope going back to stock height
Aaron
Old 10-18-2010, 08:47 AM   #487
JohnC
JohnC's Avatar
Re: my 80 build
Are you going back stock height, or where you have your truck now?
JohnC is offline   Reply With Quote
Old 10-19-2010, 12:51 AM   #488
flamingbig10
6.0 powered square
Re: my 80 build
well maybe not back to a true stock height probably back up to a 2-3
Aaron
Old 10-19-2010, 04:20 PM   #489
LiveAnimals
LiveAnimals's Avatar
Re: my 80 build
3/4 is good too
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 10-22-2010, 12:02 AM   #490
nbpro
Re: my 80 build
2-3 drop dont look bad on your truck didnt you have it that way at one time?
nbpro is offline   Reply With Quote
Old 10-22-2010, 12:03 AM   #491
flamingbig10
6.0 powered square
Re: my 80 build
Originally Posted by LiveAnimals View Post
3/4 is good too
3-4 it will be
I got the frame all primed now I'm going to let cure til next week and paint it I did order the motor mount swap brackets and leaf spring bushings
Aaron
Old 10-22-2010, 12:10 AM   #492
nbpro
Re: my 80 build
so the 3/4 is 3 inch coil springs in the front, shackles and hangers in the rear?
Old 10-22-2010, 12:26 AM   #493
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
or 3inch drop spindles
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-22-2010, 08:33 AM   #494
Jonboy
Slots go on anything!
Re: my 80 build
Why are you going back up? I think the truck looks great at the height it is now.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-27-2010, 12:12 AM   #495
flamingbig10
6.0 powered square
Re: my 80 build
well most entrance's to parking lots that are kinda steep the frame tries to high center and the control arms are all bent up from driving on uneven road services, well first I'm going to a 2/3 or 3/4 then want it lower and go back down to a 5-7 or maybe bags
yes I did it was the first drop a cut coil drop shackles and removed leafs
or control arms and the rear could also be modified leafs, lowering leafs
Aaron
Old 10-27-2010, 12:19 AM   #496
flamingbig10
6.0 powered square
Re: my 80 build
the motor mount adapters came today http://www.summitracing.com/parts/TRD-4592/ next I'm going order a complete gasket set
Aaron
Old 10-27-2010, 12:47 AM   #497
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: my 80 build
Glad to hear you are still doing the swap. I have been out of the loop for a bit. There you go raising your truck back up & I am making mine lower yet.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 10-27-2010, 08:37 PM   #498
flamingbig10
6.0 powered square
Re: my 80 build
did you see my post
well first I'm going to a 2/3 or 3/4 then want it lower and I'll go back down to a 5-7 or maybe bags )
Aaron
Old 10-27-2010, 08:43 PM   #499
flamingbig10
6.0 powered square
Re: my 80 build
pick up a complete top end gasket set for the 6.0 ordered it through work and got a discount at napa, but found out it would be $10 cheaper at summit racing but it was on back order oh well
Aaron
Old 10-27-2010, 08:44 PM   #500
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
why not bag it right now when the frames all out its easier to do the cutting and stuff
-00 Saturn 5spd
1/4:13:90
