Old 06-08-2009, 10:23 AM   #476
joe231
joe231's Avatar
Re: The 283 Rebuild Begins
in my experience, with the distributor 180* out it will try to run but will crank over slow and then fast then slow, pop and back fire through the carb, sometimes even blow fire up through the carb too.....doesn't seem to matter how many times I have swapped out distributors I inevitably get the dist 180* out....or the last one I did, I accidentally put my wires on counter-clockwise, it kinda acted the same way then too...I knew it need to be clockwise but for some reason I looked at the cap and put the wires on backwards.
set it to TDC and just line up the rotor with your number one on the cap, that should get you close enough to run
oh and make sure you got the firing order right
CHEVY ONLY
Old 06-08-2009, 10:43 AM   #477
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - those numbers on the original intake manifold (used again on this motor) were the first thing I checked. It seemed to crank fairly consistently, albeit tight at first (which was expected) and I did get some nice flames out the carb (who needs eyebrows anyway?)
I hope I don't have to crank the dizzy half way around though, cause that little square plug's going to be right up against the firewall.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 06-08-2009, 11:27 AM   #478
padresag
you have to pull the distr up and turn the shaft 180. just time it back to nbr 1
ron
padresag is offline   Reply With Quote
Old 06-08-2009, 12:00 PM   #479
MacAttack
283 Drama Queen
MacAttack's Avatar
ron
Ron, sounds like the easy way to go. TDC #1 cylinder with plug out - to feel the compression stroke, take cap off - to note where the rotor's pointing, un-clamp the HEI body enough to turn the rotor to the proper position, drop the HEI back in, cap back on, plug in and wire back on and light her up, right?
Old 06-08-2009, 12:42 PM   #480
padresag
voom-voom
ron
Old 06-08-2009, 12:48 PM   #481
MacAttack
283 Drama Queen
MacAttack's Avatar
Well, you know what they say about old, fat white guys: No (timing) rhythm.
Mac.
Old 06-08-2009, 02:13 PM   #482
joe231
joe231's Avatar
if you are just moving it 180* there is no need to bring it to TDC, just pop the cap, mark where the rotor, is loosen the clamp, pull the distributor up enough to clear the cam and rotate the rotor 180* drop it back in, might take a couple stabs to get it just right, as you know the dist gear has to mesh with the cam gear and the oil pump drive
or you can use it as an opportunity to check TDC again....I have had to pull the valve cover and rotate the engine through all 4 strokes while watching the valves just to be sure of TDC before, the timing mark on the damper isn't always right, or if your valves aren't adjusted correctly you could have trouble finding TDC...
so now we gotta wait a whole 4 days to hear the continuation of this soap opera???
oh and...
I thought that was a joke
do we need to be worried????
CHEVY ONLY
Old 06-08-2009, 02:22 PM   #483
MacAttack
283 Drama Queen
MacAttack's Avatar
Oh no! I finally got those things sealed and I'm not taking them off again!
And you really expected otherwise?
Mac.
Old 06-08-2009, 02:23 PM   #484
joe231
joe231's Avatar
CHEVY ONLY
Old 06-08-2009, 04:59 PM   #485
daverod
SSN 706
daverod's Avatar
daverod is offline   Reply With Quote
Old 06-10-2009, 01:16 AM   #486
sidthirteen
sidthirteen's Avatar
sidthirteen is offline   Reply With Quote
Old 06-10-2009, 07:38 AM   #487
4dranch
Shloooooong bed member #2
4dranch's Avatar
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 06-10-2009, 07:59 AM   #488
2ndGenRR
2ndGenRR's Avatar
Somthing to consider... Make sure that you put your plug wires in clockwise firing order around the dizzy. I did counter-clockwise once and had the same result you are experiencing.
The Stable:
1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me.
1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck.
1951 Chevy 1/2 ton, 3-window...building to sell.
Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado.
I grew up in Flint, Michigan so I can't help but to bleed Chevy!
2ndGenRR is offline   Reply With Quote
Old 06-10-2009, 08:03 AM   #489
joe231
joe231's Avatar
Echo, Echo, Echo, Echo
CHEVY ONLY
Old 06-10-2009, 08:08 AM   #490
2ndGenRR
2ndGenRR's Avatar
That's what I get for ignoring one of Joe's posts...
The Stable:
Old 06-10-2009, 08:13 AM   #491
joe231
joe231's Avatar
see, i'm not ALL hot air and useless info
CHEVY ONLY
Old 06-10-2009, 08:37 AM   #492
4dranch
4dranch's Avatar
David,
Daughters 66 truck:
Old 06-10-2009, 10:07 AM   #493
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by 4dranch View Post
Yeah, you wouldn't want to put that to a vote.
Mac.
Old 06-10-2009, 10:16 AM   #494
joe231
joe231's Avatar
CHEVY ONLY
Old 06-10-2009, 11:00 AM   #495
4dranch
4dranch's Avatar
Mac.
David,
Daughters 66 truck:
Old 06-10-2009, 08:16 PM   #496
joe231
joe231's Avatar
CHEVY ONLY
Old 06-11-2009, 02:14 PM   #497
Desert1957
Desert1957's Avatar
Hey Mac,
If you just want to get it running , Rotate the engine around until mark on the balancer is at zero on the timing tab.
Take off the Distributor cap , Note where the Rotor is , Install Number 1 plug wire in the Cap to the left of the mark.(If you have enough slack in your wires)
Start your spark plug firing order (Clockwise) from this position , remember the Engine does not care where Number 1 is in the Distributor cap , It can be in any of the eight holes , as long as the rotor is pointing to it.
Start engine and Listen to the glorious smells and sounds of a Virgin Small Block come to life.
You can re-phase the distributor to put number 1 in the front after the engine break-in if you like.
Trust me , this WILL work.....
Your friend DESERT
Desert1957 is offline   Reply With Quote
Old 06-11-2009, 02:19 PM   #498
protrash64
Resistance is Futile
protrash64's Avatar
I had to do what Desert1957 mentioned because of my intake mainfold. Im running a performer airgap and the dizzy will hit the runners. It actually points towards the passenger side now so as to have some adjustment.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-11-2009, 02:33 PM   #499
MacAttack
283 Drama Queen
MacAttack's Avatar
It's odd you bring that up - as the more I think about it - I may have missed that and put it just behind (to the right). I may just be one hole off - like Jason said originally.
I'm so confused.
Old 06-11-2009, 06:29 PM   #500
4dranch
4dranch's Avatar
[QUOTE=MacAttack;3354839]I'm so confused.[/QUOTE]
David,
Daughters 66 truck:
