Old 06-07-2010, 06:09 PM   #476
joe231
joe231's Avatar
Re: My Crew Cab Short Bed Project, AKA "Project Destiny"
I've converted several from R-12 to R-134. All
I do is pull a good vacuum to get all out that I can then put new oil and R-134 back in.
I don't have any way to add freon with out the gauges hooked up.
Hopefully I'll be able spend some time on it in the next day or two.
CHEVY ONLY
Old 06-07-2010, 06:31 PM   #477
scotts62
One day...
scotts62's Avatar
I have one of those thingys that you just screw on the cans and pull the trigger and it punctures the can and injects it, will that work for you?
Scott
93 crew cab build
Project 62
Old 06-08-2010, 12:25 PM   #478
JohnC
JohnC's Avatar
Here is one that I have on the shelf at the store.
Here is one that I can order. Real similar to the other one, but it has a gauge on top.
Name:  Freon Hose Gauge.jpg
JohnC is offline   Reply With Quote
Old 06-08-2010, 03:39 PM   #479
mcbassin
Still Learning
mcbassin's Avatar
Attachment 593907
Attachment 593908
I have the one similar to the one on the bottom with the squeeze trigger. It works pretty good.
mcbassin is offline   Reply With Quote
Old 06-08-2010, 06:55 PM   #480
joe231
joe231's Avatar
I might need it....
gonna try the gauges again and see what happens first
CHEVY ONLY
Old 06-08-2010, 11:08 PM   #481
scotts62
One day...
scotts62's Avatar
Originally Posted by joe231 View Post
I might need it....
Cool ill grab it tomorrow for you just in case.
Scott
93 crew cab build
Project 62
Old 06-09-2010, 07:59 AM   #482
joe231
joe231's Avatar
Right on!
I'll try to swing by after work.
Thanks!
CHEVY ONLY
Old 06-09-2010, 08:02 AM   #483
scotts62
One day...
scotts62's Avatar
Cool, ill be there..
Scott
93 crew cab build
Project 62
Old 06-09-2010, 08:06 AM   #484
BGRAFX
Wow could you be anymore specific, ya know one of those thingys lmao
BGRAFX is offline   Reply With Quote
Old 06-09-2010, 10:30 AM   #485
JohnC
JohnC's Avatar
We don't have to be specific. We all know what we're talking about. One of us can say that do hickey, and the others will know exactly what we're describing. It's an okie thing.
Old 06-09-2010, 12:10 PM   #486
RandyP
Getting Old; Going Broke
RandyP's Avatar
Lots of rotosynchreverters get worked on. I mean lots.
(Rotosynchreverter is the loose nut situated halfway between the steering wheel and the back of the front seat)
So, any closer to cold air blowing out of those vents?
RandyP is offline   Reply With Quote
Old 06-09-2010, 06:47 PM   #487
scotts62
One day...
scotts62's Avatar
Ya, you know, the hootis to the thingy mabob... come on Michael join the ok lingo
Scott
93 crew cab build
Project 62
Old 06-09-2010, 10:15 PM   #488
mcbassin
Still Learning
mcbassin's Avatar
I think it's just a deal or dealy, or whatchmacallit?
Old 06-09-2010, 10:26 PM   #489
joe231
joe231's Avatar
I did manage to get it charged. I now have cold air
I was a pain. I found a cheapie R134 line with a gauge in the garage. I used it and it took the freon great. I realized I didn't have enough oil when my compressor started knocking and growling so I went and got more oil, then I had a leaky valve core in my low side adapter that I had to replace so I had to run get more R134. I test drove it and it seems to be blowing nice and cool, although it was about dusk. I'll see how it cools tomorrow during the day.
CHEVY ONLY
Old 06-09-2010, 10:31 PM   #490
BGRAFX
Can I bring mine down there so U guys can fix my AC?
Old 06-09-2010, 10:38 PM   #491
joe231
joe231's Avatar
Hells, yes!
Bring it on!!
CHEVY ONLY
Old 06-09-2010, 10:57 PM   #492
scotts62
One day...
scotts62's Avatar
Sorry mine is next
Scott
93 crew cab build
Project 62
Old 06-09-2010, 11:00 PM   #493
joe231
joe231's Avatar
CHEVY ONLY
Old 06-09-2010, 11:14 PM   #494
BGRAFX
Its a 6hour drive I'm sure you will have ac working in all your projects by the time I get there.
Old 06-10-2010, 12:37 AM   #495
mcbassin
Still Learning
mcbassin's Avatar
Joe,
How did you find the leak in the evap? Just pressure it up and listen for a leak? My burb leaks like a mother and at $7 a can I can't just keep dumping it in there. It has the rear air too and it takes a bunch to charge it. I tried the red dyed freon and it didn't work. I have heard of sniffers but don't know anyone that has one. BTW, congrats on the cold air! Can I get my kid's truck on the waiting list?
Old 06-10-2010, 01:19 AM   #496
joe231
joe231's Avatar
Mike,
I hooked up a vacuum pump to suck it down. The low side gauge has a vacuum scale built in. I let the pump run for awhile and it wasn't achieving any vacuum, so I started looking for leaks. The leak in the condenser was big enough I could hear it sucking air.
I've had good luck with the yellow/green dye/freon. You need a black light for it to stand out, but you can also see it under regular light if you look closely.
I'm no expert, but I'm willing to help out with what I do know.
I borrow the equipment from a friend that I work with, so I just need a few days notice.
One of these days I'm gonna buy my own stuff. Harbor Freight has the gauge set for @$40 and a vacuum pump for $70-80. Just not a priority at the moment....
CHEVY ONLY
Old 06-10-2010, 08:01 AM   #497
baclay9
Congrats on getting the AC going Joe. What's next on the list?
baclay9 is offline   Reply With Quote
Old 06-10-2010, 08:36 AM   #498
mcbassin
Still Learning
mcbassin's Avatar
Mike,
Thanks Joe, I have my own gauges but no adapter for the R134 yet. I also have access to a vacuum pump. I haven't tried the black light thing yet. That may be the difference maker. Thanks for the offer to help! Now get back to your build
Old 06-10-2010, 09:33 AM   #499
joe231
joe231's Avatar
thanks Brandon!
Gotta get my dash back together and get my radio installed....
cool!
Sir, Yes Sir!!
CHEVY ONLY
Old 06-10-2010, 02:59 PM   #500
JohnC
JohnC's Avatar
I have a set of gauges if you ever need to use them. I got them, but haven't used them yet. I don't have a pump though. I also carry freon at the store for future reference.
