Old 01-17-2015, 11:19 PM   #476
shadow1967
shadow1967's Avatar
Re: 1959 Fleetside REBORN
Next came the dreaded bottom and as you can see we took one piece of after
market metal , cut it in half and added 6"s to it in the center.
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 01-17-2015, 11:22 PM   #477
shadow1967
shadow1967's Avatar
Since the ends weren't stamped like the original I cut the originals out and tacked
them in place.
Old 01-17-2015, 11:24 PM   #478
shadow1967
shadow1967's Avatar
Had to laugh the window didn't fit, My son commented you must have mismeasured.
Old 01-17-2015, 11:26 PM   #479
shadow1967
shadow1967's Avatar
Next was the door skin, prestressed it, bent the edges, acid etched and sealed the
inside of the door then installed it.
Old 01-17-2015, 11:28 PM   #480
shadow1967
shadow1967's Avatar
Then came the fun part, the windows. first was to slice and dice the window frames
and the window bottom being careful to keep the window cam channel in the original
position. next was the door cam channel tacked in place (I chose to use a full length
channel because of a possible mod later).
Old 01-17-2015, 11:30 PM   #481
shadow1967
shadow1967's Avatar
Next I installed the window channel inserts (the fuzzies), connected the power and
ran the window up to form the channel insert at the radius, a few light taps with a
ball peen hammer did the job nicely. LMC apparently cuts the inserts 6 inches longer
than required for a stock door in that all I had to do was move the insert clip at the
bottom of the channel about 5/16th of an inch to hold the insert in place. Lucky Me!!
Old 01-17-2015, 11:32 PM   #482
shadow1967
shadow1967's Avatar
Ran the window up and down a couple times to make sure there were no issues.
The arrow heads in the following picture indicate where the cam follower is when the
window is all the way up, down and in the middle. Everything was OK soooo.
Old 01-17-2015, 11:34 PM   #483
shadow1967
shadow1967's Avatar
Next we modified the inner brace to facilitate the door cam, rosette welded the cam
chnl. then replace the skin and close up that section.
Old 01-17-2015, 11:38 PM   #484
shadow1967
shadow1967's Avatar
The following five pictures show the splicing of the fuzzies at the top of the door.
And finally, the next picture is self explanatory. So much for the passenger door
Old 01-17-2015, 11:39 PM   #485
shadow1967
shadow1967's Avatar
The last one of this group.
Old 01-17-2015, 11:42 PM   #486
shadow1967
shadow1967's Avatar
the next 16 pictures are of the driver side door, we didn't have as bad a time with it
since the door bottom didn't need to be replaced.
Old 01-17-2015, 11:44 PM   #487
shadow1967
shadow1967's Avatar
6-10
Old 01-17-2015, 11:47 PM   #488
shadow1967
shadow1967's Avatar
11-14
Old 01-17-2015, 11:50 PM   #489
shadow1967
shadow1967's Avatar
15, 16 DOORS DONE
Old 01-18-2015, 12:01 AM   #490
ricott
Thanks for the door stretch tutorial. Your truck is looking great. I will be stretching the doors on mine at some point this year, so I at least have an idea what to look for.
Ricky
ricott is offline   Reply With Quote
Old 01-18-2015, 12:20 AM   #491
shadow1967
shadow1967's Avatar
Ricky
Thanks, if I can help further let me know...
I should also add that after operating the windows and seeing how much torque the window motors had I thought it prudent to add some (front to rear) bracing since these doors were not designed for electric windows. The bottom brace and window stop are inadequate .
Old 01-18-2015, 12:30 AM   #492
Kim57
Kim57's Avatar
That's a ton of work.
Looks real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-18-2015, 11:26 AM   #493
Drifters
That's gonna be nice!
Drifters is offline   Reply With Quote
Old 01-18-2015, 12:20 PM   #494
shadow1967
shadow1967's Avatar
Looks real good.
Kim
Thanks guys.
Old 01-18-2015, 02:46 PM   #495
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome job!!
ChuckDriver is offline   Reply With Quote
Old 01-18-2015, 06:47 PM   #496
waybad
waybad's Avatar
wow!! wow!! wow!!
waybad is offline   Reply With Quote
Old 01-19-2015, 09:41 PM   #497
shadow1967
shadow1967's Avatar
Originally Posted by ChuckDriver View Post
Awesome job!!
Originally Posted by waybad View Post
wow!! wow!! wow!!
Thanks JJ and Waybad, appreciate the complements
Old 01-31-2015, 12:17 AM   #498
Green 1959
Green 1959's Avatar
Too much talent yo. Awesome work.
I pity the fool with only 2 headlights!
Green 1959 is offline   Reply With Quote
Old 01-31-2015, 11:47 AM   #499
Rude Dude
Rude Dude's Avatar
You guys are awesome, hard work building it at home and not in a shop I can appreciate the talent it ain't easy. Once again outstanding!
Rude Dude is offline   Reply With Quote
Old 01-31-2015, 01:44 PM   #500
_Ogre
_Ogre's Avatar
looking good shadow, that's a lot of progress over the past few months
shop air compressor timer
