02-29-2016, 04:00 PM | #476 |
Re: 53 Surburban "Family Truckster"
Looks like a racecar already!
Pretty low indeed!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
02-29-2016, 07:25 PM | #477 |
A320 Pilot/USAF Retired
Very nice!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
02-29-2016, 10:52 PM | #478 | ||
Thank you
Thanks Jim...
...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-29-2016, 10:53 PM | #479 |
Thanks guys....
Marc
03-06-2016, 10:37 PM | #480 |
I managed to get out in the garage for a bit on Sunday. Most of the time was spent rewilding my rear watts link mounting tabs. I only tack welded it on so it was not that big of a deal.
I borrowed a LS mock up block from my friend Friday so I threw that in to check oil pan clearance. It looks like my F-body oil pan will clear the drop member nicely. I was also please to see the driver side F-body manifold fit. The seating needs to be sorted out yet but It will be close. The passenger side is requiring more messaging in order to fit.
03-06-2016, 11:21 PM | #481 |
Marc, very nice the F car pan and exhaust manifolds will work. Looks good.
03-09-2016, 11:13 PM | #482 |
Youngrodder, frame looks great. That PB stuff is awesome looking stuff. Those poly blocks sure make things easier, no struggling like an iron block.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
03-10-2016, 10:21 PM | #483 | |
I think I will move my focus toward the gas tank, since AD (Doug) has already done the heavy lifting on that. I have always been good at copying off others school work. Marc
03-10-2016, 10:27 PM | #484 |
And I was copying off of Dave with Hollister Road Company. Even then, it is taking me too long!
03-10-2016, 11:05 PM | #485 | |
Marc
03-10-2016, 11:52 PM | #486 |
The plastic blocks are such a cool thing. Nice to have friends with cool things.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-11-2016, 01:38 AM | #487 | |
03-11-2016, 11:31 PM | #488 | |
Good luck on your 53 GMC. Marc
03-11-2016, 11:50 PM | #489 |
If the Camaro tank is too long, a 55 Chevy tank might fit. Another option is a 53 Chevy. I think I remember they were both shorter front to rear than the Camaro...I measured for a number of tanks from dimensions on Tanksinc.com web site. And both have a fill that may clear between the frame and Burb body.
03-14-2016, 10:00 PM | #490 | |
Marc
04-03-2016, 11:11 PM | #491 |
Well let me start off by saying that due to cyber bullying I decided that I needed to get out in the garage and accomplish something. I don't want to name the source of the bullying as I would not want any ill will toward the offending party. It just wouldn't be fair to Advance Design (Doug)....
I installed my frame mounted brake pedal/booster set up. I think this is right. All of the holes lined up here. I was lucky as I filled a lot of the holes before I remembered that I needed to install my pedal set up. There were no instructions so I tried to use common sense. You know how that can go....Let me know if this does not look right to anyone. I also treated the lower third of the body and rear wheel wells with POR15. I plan to seam seal then coat the same areas with raptor liner which is kind of like a spray on bed liner. I also removed the rear brace and will start planning my gas tank solution. On to the pics
04-03-2016, 11:12 PM | #492 |
One more pic
Marc
04-04-2016, 02:29 AM | #493 |
Guilty as charged I guess...sorry man...good progress Marc. Way more than I did this week end....busy with yard work, equipment maintenance and determining the exhaust tips I ordered won't work.
The brake assembly looks to be in the right place to me and same as my 48 truck was. I had an issue with the transmission mount wanting to be in the same place as the master cylinder that hopefully you won't run into. Good luck as you and I continue to vie for third place in the Iceburgh, Youngrodder, Advanced Design Burb build off... |
04-04-2016, 09:59 PM | #494 |
Looks great. I know what you mean about getting the truck ready for the season, mine still needs some attention. I will rephrase that, a lot. But at least it is drive able. All good thing take time. That burb should drive great.
Shannon
04-05-2016, 07:21 PM | #495 | ||
Yes, I hear you about yard work. I did that the weekend before. I still need to open the pool in a few weeks which will waste a weekend. Oh and I'm soooo confident that I will have 3rd place locked up that I've ordered myself a trophy. Quote:
Marc
04-06-2016, 09:15 AM | #496 |
looks great. Man I love the looks of the rear end......
04-06-2016, 10:07 PM | #497 |
Thanks, the side of the notch might have to be quite large....
Marc
04-06-2016, 11:35 PM | #498 |
marc - what m/c & booster are you using ? thanks
04-07-2016, 11:13 PM | #499 |
I picked it up off of EBay.
Here is a link http://www.ebay.com/itm/221674734248...%3AMEBIDX%3AIT Marc
04-08-2016, 08:11 AM | #500 | |
