12-10-2015, 11:47 AM | #476 |
Re: 1976 Square "Simple Green"
12-10-2015, 11:58 AM | #478 |
Not that I know of the only one I have seen is the fast one I posted up top. But it may not be a issue. The mechanic at FiTech said he has done it and has not had a issue. So idk. I am just prepping for the worse case. But that module is the way to go if that issue happens.
12-10-2015, 02:05 PM | #479 |
Well Ken the owner/founder of FiTech emailed me and said you CAN share the tach signal!!! It just keeps getting better and better!!
12-10-2015, 05:08 PM | #480 |
O2 bung in kit.
12-10-2015, 05:11 PM | #481 |
Installed. This is actually a great idea for doing this at home. You could leave it or have it welded on. I am going to get mine welded on but this is perfect for getting it up and running. I used a step bit for drilling the hole. Need a 7/8 drill bit. Step bit was the perfect length short and ate that aluminum up. Plus step bit deburs as it cuts nice and smooth.
12-10-2015, 08:06 PM | #482 |
All buttoned up underneath.
12-10-2015, 08:07 PM | #483 |
Different angle. Fits like it came that way. I like how they put HeatShield Procducts over the harness to protect it.
12-10-2015, 08:13 PM | #484 |
What I have left is. Install fuel pump relay and run wires. Install fuel tank. Run fuel line. Program. Fire this bad boy up. And go run the piss out of it!!! Make sure I got my money's worth haha!!
12-10-2015, 10:30 PM | #485 |
Cool, get some video if you can.
12-11-2015, 07:09 AM | #486 | |
12-11-2015, 07:10 AM | #487 |
12-11-2015, 03:19 PM | #488 |
My fuel line I will be using.
12-11-2015, 09:01 PM | #489 |
Well you know how dirt and grime get in every little orfice and crack in a vehicle. Got me thinking about my vent on my fuel pump. So I bough a diff/tranny case vent. So for you who do not know what it is or looks like the pic below will help. Vents pressure and keeps crap out of places it shouldn't be. Should work really good.
12-11-2015, 09:02 PM | #490 |
And here it is on the pump just fits.
12-12-2015, 09:22 PM | #491 |
Fuel filter mounted.
12-12-2015, 09:23 PM | #492 |
Pressure side return line and wiring to pump.
12-12-2015, 09:25 PM | #493 |
I ran into a issue with the damn filler neck. My filler neck on my truck will not fit a 87 R10 that's some BS. And not 1 damn parts store has one or can get one. But my buddy said he has one and will bring it tomorrow.
12-12-2015, 09:27 PM | #494 |
O and I had to do a little custom look. Piss in hanging something off my windshield. Not a fan of that. I have done this in other vehicle that I have custom tuned example SCT handhelds. So here is something a littl custom looking. It is just sitting for now I will mount it so I can close it without it moving around. Fits like a glove!!
12-13-2015, 08:59 AM | #495 |
This is how I ran my return line.
12-13-2015, 02:54 PM | #496 |
It's ALIVE!!!
12-13-2015, 02:56 PM | #497 |
Awesome. Can't wait to hear your impressions.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
12-13-2015, 05:48 PM | #498 |
12-13-2015, 06:09 PM | #499 |
12-13-2015, 06:40 PM | #500 |
Here is the first warm start up video. This is 20 min after first fire up and drive. Idk if this is any good. I don't YouTube lol. I have a few comments I will post up here in a few.
https://m.youtube.com/watch?feature=...&v=rfauqfN8m7c |
