Old 02-24-2015, 10:24 AM   #476
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
Thank you Sir!!
Originally Posted by RockinKees View Post
I'm glad we're on the same level Mark
I didn't know you're closing it up, probably didn''t understand that part...
The more I look at it the more I like it.
Eyes and brains do strange things sometimes
Looking forward to the finished piece!!
Also, the bumper mount is some great enginering!!
reaper71 is offline   Reply With Quote
Old 02-24-2015, 10:27 AM   #477
reaper71
reaper71's Avatar
Thanks Doug...I wanted it to be some what simple to remove. So when it's all done you pull 2 bolts out and the bumper and the inner mounting system comes off pretty easy..
Originally Posted by Advanced Design View Post
Another great idea on the bumper mounting. The filler panel will look really good Mark.
Old 02-24-2015, 10:28 AM   #478
reaper71
reaper71's Avatar
Rusty76, Thank you!
The apron was a much needed item, there was just to much space between the bed and bumper..
Old 02-24-2015, 10:46 AM   #479
rusty76
rusty76's Avatar
You're doing this truck justice.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-25-2015, 10:58 AM   #480
reaper71
reaper71's Avatar
Your to kind...Thank you once again!!
Old 02-25-2015, 11:12 AM   #481
reaper71
reaper71's Avatar
Pic #1. The bumperetts needed some TLC...
Both had rot issues..
Pic #2. The other side..
Pic #3. After the repair work was done..
Pic #4. After repairs were done, also showing the holes for lights that will be filled.
Pic #5. After the holes were filled and metal finished..
Mark..
Old 02-25-2015, 08:21 PM   #482
Advanced Design
Advanced Design's Avatar
Nice repair work on the bumperette. Smooth!
Advanced Design is offline   Reply With Quote
Old 02-26-2015, 11:41 AM   #483
reaper71
reaper71's Avatar
Thank's Doug, It was a pain in the butt to do the repairs on them do to the compound curves they have, so it was a challenge!!
Pic #1. The bumper all prepped for clear...
Pic #2. The pan after texturing..
Pic #3. The bumperettes..
Pic #4. The bumper cleared and installed...
(The reason I cleared the bumper and pan was to tie the bumper into the interior concept. )
Mark...
Old 02-26-2015, 12:20 PM   #484
ratty 46
Nicely done on the bumper filler panels. Those came out as if they belonged.
ratty 46 is offline   Reply With Quote
Old 02-26-2015, 03:36 PM   #485
Spblack
Spblack's Avatar
how far does your tailgate come down?
1959 Chevy Apache (sold)
1958 Fleetside Current
My builds:
http://67-72chevytrucks.com/vboard/s...d.php?t=606412
http://67-72chevytrucks.com/vboard/s...=1#post7560906
Spblack is offline   Reply With Quote
Old 02-27-2015, 10:05 AM   #486
reaper71
reaper71's Avatar
Ratty46 thank's...it really needed the pan, it looked kinda silly without it...
Spblack....Oddly enough it comes all the way down with about 1/4" of clearance.
When it was in mock up stages it was worked out so it could still be used if needed..
Mark...
Old 02-27-2015, 10:17 AM   #487
reaper71
reaper71's Avatar
Update...
Ok, if you guy's remember awhile back I was kicking around the idea of the metal finish for the interior, so after I finished the dash I removed the door panels and the moldings from the doors and back panel from the cab to re-do them...
Pic #1. This is the rear panel for the cab after I textured it.
Pic #2. The door panel.
Pic #3. Steering column.
Pic #4. First look after the clear was done and parts installed..
Pic #5. A closer look at the door and molding..
Till next time
Mark...
Old 02-27-2015, 06:20 PM   #488
RockinKees
RockinKees's Avatar
Now I'm with you with the bumper, this is good!
Also love your doorpanel, that's slick!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-27-2015, 08:34 PM   #489
Advanced Design
Bumper, filler and the door panel looks really good. Nice ideas well done Mark!
Old 02-27-2015, 11:56 PM   #490
47 Fasttoys
47 Fasttoys's Avatar
That's some really slick work on the bumper reaper.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 02-28-2015, 12:07 PM   #491
reaper71
reaper71's Avatar
Kees,Doug and Rob Thank's again Guys for the compliments!!
I have one more small Item to post and then this old girl will go into the basement for awhile ( I have customer projects that need my attention so until I get farther ahead on them it goes in storage )
Old 02-28-2015, 12:25 PM   #492
reaper71
reaper71's Avatar
This last item on my list before I put her away, is for the steering wheel/column.
There is a gap between the wheel and column that needs attention.
Pic #1. Here I made a simple ring a bit larger than the column and welded together. Then I cut out the top ring/plate to fit the back side of wheel.
Pic #2. This is what it looks like sitting on the wheel..
Pic #3. After tacking together..
Pic #4. After welding and metal finish...( also notice the inner plate that was added )
Pic #5. This gives you a better idea of what I'm going for..(the small holes in plate are for 1/4-20 button head cap screws to hold in place)
More later...
Mark...
Old 02-28-2015, 12:52 PM   #493
Advanced Design
That is a nice detail. Putting her away...certainly understand the need and it is kinda like stopping in the middle of a good book. Here is to a quick continuation!
Old 02-28-2015, 05:30 PM   #494
youngrodder
youngrodder's Avatar
Your making some great progress Mark..
Looking forward to more very soon.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-28-2015, 07:34 PM   #495
rusty76
rusty76's Avatar
Man that rear bumper mod and panel really look great. Splash pans always seen to really tie everything together. Really nice work.
My build thread
Crossmembers CC
Old 03-01-2015, 04:13 AM   #496
RockinKees
RockinKees's Avatar
Looking real good!
Hope you get back at it very soon, we're waiting
It's great that you can use your talents at other peoples projects, they are lucky
Cheers!! Kees.
Kool Guyz CC
Old 03-02-2015, 10:27 AM   #497
reaper71
reaper71's Avatar
Doug, It is a bummer that it needs to be put away again but to spend money you need to make it first HAHA!!
Old 03-02-2015, 10:30 AM   #498
reaper71
reaper71's Avatar
Marc, Rusty76 and Kees Thank's Guys!!
I hope to be able to get some time to work on it soon, will have to see how things pan out...
Mark...
Old 03-02-2015, 10:39 AM   #499
reaper71
reaper71's Avatar
This will be the last portion of the updates for awhile as stated earlier...
Pic #1. A shot of the spacer/trim ring installed.
Pic #2. Another shot to give you a better idea what it was needed for.
Although I did not take pics of the wheel being painted and detailed (DUH) here is what it turned out like.
Pic #3. The back of wheel has stainless button head cap screws installed.
Pic #4. Front view with center cap installed..
Old 03-02-2015, 01:30 PM   #500
99 to Life
99 to Life's Avatar
nice job on the wheel, flowing with the rest of the truck for sure. keep up the good work
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
