Old 01-23-2017, 03:28 PM   #476
RodsGreen10
RodsGreen10's Avatar
Re: Project "Steppin Wolf" LS swap
Looking good man. MR Bad Luck. Lol.
RodsGreen10 is offline   Reply With Quote
Old 01-23-2017, 03:33 PM   #477
Liltroy
Liltroy's Avatar
Originally Posted by aggie91 View Post
Cover looks good. Stepsides can use the extra weight over the rear tires.
Did you ever figure out what was causing to run bad?
Thank you! and I still need to raise the rear a bit. I think Im going to take a leaf or two out of my old sring pack and add them to the current spring pack to raise the rear and stiffen it a bit at the same time. Im thinking the reason the flip kit lowered it way more than it was suppossed to is maybe because of the additional weight on the rear of the frame from the rear mount fuel tank. I didnt think about all that weight when I put it the flip kit on. What was suppossed to be 5" of drop has turned into about 7+ and will get even worse when I put the aluminum sheet in for the bed floor. As far as needing the weight, I think Im more than good since relocating the tank. I mean, itll destroy street tires but the 325/50-15 drag radials dead hooked....even with no fenders, no bed floor, and no topper on! Of course Im sure that will change once I get my stall converter.
Yes, we figured out what was wrong and its a bit embarressing that I didnt figure it out sooner. Apparently I have a ton of water in my tank!! I put new plugs in and checked that coils were firing and they were so I pulled one of the plugs out again and just like before it was soaking wet. I held it up and told my buddy "look! its dripping with fuel!" He took it and smelled it and was like Dude thats not gas!!! Sure enough, my injectors were pumping straight water!! Pulled the pump, dropped a sypohon hand pump in the bottom of the tank and pumped out almost a gallon of water before fuel started coming out!!! Were trying to figure out how so much water got in my tank and trying to get as much out as possible since I have over 3/4 of a tank before we put it all back together.
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac
Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303
My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw
Liltroy is offline   Reply With Quote
Old 01-23-2017, 04:36 PM   #478
Rich84
Rich84's Avatar
Wow..That's a lot of water. Sounds sketchy to me. Sabotage?
I have a roll n lock cover on my 2016 chevy and I like it a lot.
Good luck with it.
Rich84 is offline   Reply With Quote
Old 01-23-2017, 09:31 PM   #479
Liltroy
Liltroy's Avatar
Good luck with it.
Im rolling over how the water got there. Making sure my custom fuel filler doesnt leak in the rain. I also thought maybe condisation sence the weather has been going from 8 degrees to 70 and back over and over here but yea, thats alot of water! Im really digging the roll'n'lock. I dont really like the box at the front but the rest looks good I think. I needed something for better aerodynamics and also to keep my nitrous bottle secure and out of the weather. Im actually thinking about a small but functional aluminum ducktail at the back as well. At triple digit speeds I noticed the rear end kinda floats a bit but Maybe the bed cover will help with that.
Old 01-23-2017, 10:02 PM   #480
Jeramy
Jeramy's Avatar
really like the bed cover and glad the running problems figured out. double check your seal at the sending unit. customer had same thing happen in a 95 turned out the oring seal for the sending unit had slipped.
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 01-23-2017, 11:12 PM   #481
Liltroy
Liltroy's Avatar
This is completely possible as until I installed the bed cover the tank was out in the open
Old 01-25-2017, 09:03 PM   #482
Liltroy
Liltroy's Avatar
Well I was wondering how I was going to be able to afford a better fuel pump since I put nitrous on the truck and then out of nowhere Rodney(Rodsgreen10) calls me like " hey man, if you want this Walbro 450 come get it!" Thanks again brother!!! Now I just need to find some larger injectors and Im set!!
Old 01-25-2017, 10:00 PM   #483
Liltroy
Liltroy's Avatar
Another update video and my buddy from Lokar came by.
https://www.youtube.com/watch?v=OMG2LxgSOFs
Old 01-28-2017, 11:40 PM   #484
Liltroy
Liltroy's Avatar
got the walbro 450 that Rodney donated in. Throwing the fuel tank back in tomorrow and hopefully be able to drive for the first time on the 20s and see if anythings rubbing!
Old 01-28-2017, 11:45 PM   #485
RodsGreen10
Anytime man. Just happy I could help a fellow c10 brother out. And so we can race again haha.
Follow me on Instagram @rodsgreen10
Hit my YouTube page up http://www.youtube.com/c/RodsGreen10
Old 01-28-2017, 11:46 PM   #486
RodsGreen10
That big boy will suck the basket dry!!! Time for some E85!!!
Old 01-29-2017, 12:04 AM   #487
Liltroy
Liltroy's Avatar
Yea Im kinda worried about the whole sucking the basket dry thing since I already have to keep at least a half tank to keep from happening. I may have to go to a custom tank at some point. As far as the E85, Im gonna have to find some larger injectors. Im already having to short shift at 5800 cause the injectors are over 100% duty cycle.And thats just on 10% fuel.
Old 01-29-2017, 12:06 AM   #488
Liltroy
Liltroy's Avatar
New video update
https://youtu.be/j9sdpiqaBIs
Old 01-29-2017, 12:42 AM   #489
RodsGreen10
Never ending is it.
Old 01-29-2017, 08:21 PM   #490
Liltroy
Liltroy's Avatar
Alright people I got more issues. I got the Walbro 450 installed and I think its overpowering the corvette regulator. Im getting 78psi at the rail now! Truck idles fine but the longer I drive it the more its starts missing so Im thinking its getting too much fuel. I didnt have my wideband installed to confirm this but with that much fuel pressure at the rail Im sure its getting too much fuel. Has anyone else had this problem with the big walbro pumps?
Old 01-29-2017, 10:25 PM   #491
Liltroy
Liltroy's Avatar
video update
https://youtu.be/Kg1hlpSQS_I
Old 01-30-2017, 10:27 AM   #492
reaper71
reaper71's Avatar
What you could do is use the Corvette style Filter/regulator and it will cut down the pressure going to the rails.
I'm going to guess that if you keep running it the way it is you will destroy your injectors! and may possibly cause one to "piss fuel" into the cylinder and therefor cause it to blow when ignited and ruin a rod or piston.
A friend of mine had a similar issue and destroyed 2 motors because it was "pissing" into the cylinders.
Just my 2 cents.
Mark...
reaper71 is offline   Reply With Quote
Old 01-30-2017, 10:45 AM   #493
reaper71
reaper71's Avatar
The part # for the filter is from Oreillys 33737 from micro guard for $20.00
Old 01-30-2017, 01:32 PM   #494
aggie91
I'm just glad to be here!
aggie91's Avatar
He is already running a vette filter/regulator in his system. You can see it in the 5th picture in post #225.
He may need to add a regular just before the rail. I would probable remove the vette filter/regulator and put a regulator neat the rail and a return hose from there.
We run the 450 pump to a set of stock truck return style rails with the regulator as part of the rail and have not issues with pressure at the rail.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-30-2017, 02:56 PM   #495
Liltroy
Liltroy's Avatar
Thank you for that part# but I'm already running the corvette filter/regulator. If I find out I need a new one I'll definitely get that one though cause the last one cost me $35..
Old 01-30-2017, 03:03 PM   #496
Liltroy
Liltroy's Avatar
After researching I'm seeing others have had this same issue with the walbro 450 with a vette fuel system. Some have solved it by enlarging the return but my return is -6 just like my inlet so I don't know where to go from there. I wouldn't mind trying the return style system but that would require buying more fuel line and a different set of fuel rails. I think I'm gonna stick the stock pump back in and if the pressure goes back to normal I'll just run it that way until I can afford to replace the vette piece with an adjustable regulator and filter. That way I can mount that setup next to the tank and not have to buy more fittings or fuel lines. Don't know if I mentioned it but the company I work for recently cut my pay by over $1000 per month so until I find a new job I can't afford to buy anything else so I'm trying to work with stuff I already have right now.
Old 01-31-2017, 10:25 AM   #497
aggie91
aggie91's Avatar
Dang, sorry to hear about your job. That's a tough blow.
Hope everything works out for you.
Karl
The LST Challenge:
Old 02-04-2017, 02:21 AM   #498
Liltroy
Liltroy's Avatar
another video update. https://youtu.be/MVi3qLSjBnw?list=PL...JHsUAX-dOyZH-i
Until I can get a stable picture hosting site it looks like Im just going to start documenting my progress on my you tube channel. I cant get photobucket to work and my trial is up on image shack. If anyone knows of any free image hosting sites that arent just 30 day trials let me know, otherwise I guess Im finished posting pictures.
Old 02-04-2017, 06:55 AM   #499
RodsGreen10
I post picks directly from my phone. I don't use photobucket or anything like that. Bad Luck all around for you bud. Lol.
Old 02-04-2017, 10:17 AM   #500
reaper71
reaper71's Avatar
When I post pics, I just transfer my pics from phone /camera to my computer then upload to the site as I need to. Very simple and free!
Mark..
