Closed Thread
Old 10-06-2012, 01:08 PM   #5026
jd7
jd7's Avatar
Re: What did you do to your truck today!
Installed a black magic extreme fan, updated the p/s pump bracket. Going to install fuel log and push on fuel lines today.i would post pics but I'm not that smart i guess.
jd7 is offline
Old 10-06-2012, 01:22 PM   #5027
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Shawn ;
Why does your truck have two oil pressure gauges ? .
I got my spare tire mounted to my freshly powder coated stock wheel and installed one of the two hub caps I had coated , they're badly dented but better than none IO .
Pix to follow soon .
I'm looking for someone / someplace that can paint in the black and blue on my hubcaps , L.A. area , I want them to look nice .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-06-2012, 06:45 PM   #5028
Mike Bradbury
Mike Bradbury's Avatar
I fabricated a trailer hitch that tucks underneath the frame and comes out behind the license plate. I still need to fabricate the hinge for the plate. I was able to get it in my powder coat oven and I made it all out of scrap steel that had been lying around my shop. Total investment $0
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline
Old 10-06-2012, 07:14 PM   #5029
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
Nice deal. Got to love the price to!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 10-06-2012, 07:18 PM   #5030
Sideways
Sideways's Avatar
Check out late 60's to early 70's buick/chevelle etc,they had the fuel filler behind the plate and all you have to do is unbolt it and put it on yours.This is what I used and it works great!Oh yeah it's spring loaded as well.
Sideways is offline
Old 10-06-2012, 09:53 PM   #5031
kyle fitz
kyle fitz's Avatar
picked up my rebuilt turbo 350. ordered my 5 inch drop springs and adjustable track arm from POL, this will compliment my cnotch and shock relocation i did the other day
kyle fitz is offline
Old 10-06-2012, 10:03 PM   #5032
ItsRandy
ItsRandy's Avatar
Replace my dual 14" electric fans and shroud with dual 16" electric fans and shroud trying to solve an over heating problem when it's 110* outside, however, now it's only in the 80's and I don't know if I have solved the problem.
Took my truck to the upholstery shop today, it will look something like the picture. Should be done in a week. I am suffering from separation anxiety, lol! I'm lucky I will be on vacation while it's in the shop otherwise I wouldn't be able to cope.
ItsRandy is offline
Old 10-06-2012, 10:14 PM   #5033
hayhauler71
hayhauler71's Avatar
Would love to see some pics of your fan set up
Fuzzy
hayhauler71 is offline
Old 10-06-2012, 10:19 PM   #5034
jayman68
Fun Stuff
jayman68's Avatar
This guy has lots of the flip plates, pretty cheep.
http://67-72chevytrucks.com/vboard/s...d.php?t=370823
Some stay up some don't.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 10-06-2012, 11:06 PM   #5035
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
X2
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-07-2012, 01:00 AM   #5036
ItsRandy
ItsRandy's Avatar
Here you go. I got the radiator and fans from Entropy Radiator. The first picture is with the 14" fans, the second is with the 16" fans. The 16" fans are supposed to draw 6600 cfm. They hang over the sides of the radiator a bit but Tony at Entropy built a filler piece to fill the area where the fans hang over, so the fans only draw air through the radiator core. You can see when you compare the first picture with the second how much more radiator core is covered by the larger fans.
When I told Tony about the over heating problem he suggested the larger fans and agreed to refund the price of the new fans when I returned the smaller fan package. That was great and, I think, the right way for Tony to treat his customer. Thank you Tony!
ItsRandy is offline
Old 10-07-2012, 11:12 AM   #5037
VWNate1
VWNate1's Avatar
Post Re : Running Hot
How hot is it running ? .
Overheating means spewing coolant , not running @ 200° F .
How many rows in the radiator core ? .
Base and full advance timing ? .
What engine size ? .
Those fans look very nice indeed , how about sharing the contact info and location of this Entropy Radiator Shop , there are very few good ones left .
-Nate
Geezer
VWNate1 is offline
Old 10-07-2012, 12:28 PM   #5038
c10srule
c10srule's Avatar
looked at it wandering why its been two weeks and still havnt gotten my new guide plates to warranty the broken ones, havent had time to do much with it been building dads truck with him, got the front end parts layed out and started prepping to paint the backsides of them
c10srule is offline
Old 10-07-2012, 02:32 PM   #5039
UNEASYRIDER
UNEASYRIDER's Avatar
Put my badges on!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 10-07-2012, 02:44 PM   #5040
jd7
jd7's Avatar
what are those seats out of they look basdass
jd7 is offline
Old 10-07-2012, 02:56 PM   #5041
ole dollor
ole dollor's Avatar
this was from a few days ago....just a update for the inside and some new badges
ole dollor is offline
Old 10-07-2012, 05:44 PM   #5042
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Bought a 4x6 stall mat for the bed. Now maybe the dogs will ride back there without sliding around on the hard plastic bedliner. And it'll keep the chain saws etc from sliding around so much.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 10-07-2012, 06:47 PM   #5043
ItsRandy
ItsRandy's Avatar
Re: Re : Running Hot
Hey Nate...ya' geezer. This is Randy, you met me at Bob'b Big Boy in Downey with the C10 club guys, red '69 no wood in the bed. Ring any bells?
Anyway, not spewing any coolant, running 210* - 215* on freeway@70 - 80 mph. Running 220*+ in traffic on 100*+ day.
2 row 1.25" tube radiator core, aluminium radiator. 20lb cap.
Timing is 10* base, 36* total (vacuum can unplugged), all in at 2500 rpm.
ZZ502
Here's the link for Entropy Radiator: http://www.entropyrad.com/. Tony is in Chicago.
ItsRandy is offline
Old 10-07-2012, 06:53 PM   #5044
ItsRandy
ItsRandy's Avatar
I don't know what the seats came out of, they were in a '57 sedan delivery I saw at the Route 66 event in San Bernardino. Not my seats, I used the picture to give my guy an idea of what I wanted. I hope mine will look as good. You guys will be getting pictures next weekend when my interior is done.
ItsRandy is offline
Old 10-07-2012, 08:26 PM   #5045
VDOG
Grand PooBaa Member
VDOG's Avatar
Hey Randy, let me ask, what temperture thermostat are you running?
160 deg, 180 deg, when were your fans turning on? What core is your radiator? Sorry for asking incase you mentioned it and I missed it. And lastly, are you running a 50/50 mix or just water?
VDOG is offline
Old 10-07-2012, 09:46 PM   #5046
CParnell
CParnell's Avatar
I brought mine home finally after 23 years. Now the fun really begins.
1968 GMC 910 Project Tommy
1974 Olds Cutlass
CParnell is offline
Old 10-07-2012, 09:52 PM   #5047
69vetteside
69vetteside's Avatar
we took the truck and the vette to a car show put on by my local corvette car club .Was a GM muscle car heaven show and shine.
Sorry about the dark pics but it got overcast before i got to taken pics:waah:
69vetteside is offline
Old 10-07-2012, 10:18 PM   #5048
ItsRandy
ItsRandy's Avatar
Vince, I have a 180* thermostat. Fans come on a bit early, one around 160* the other comes on around 175*. Radiator is aluminium with a 2 row core and 1.25" tubes. Coolant is about 70/30 (water/anti-freeze, we live in So. Cal.).
ItsRandy is offline
Old 10-07-2012, 11:12 PM   #5049
PAWS 72
PAWS 72's Avatar
What got the most looks?Truck or vette
PAWS 72 is offline
Old 10-08-2012, 03:01 AM   #5050
mcmlxix
Collector of Projects
mcmlxix's Avatar
Started tear down for the LQ9/4L80e/D60|AAM ... no pics as my phone fell anf I trashed my touchscreen....
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Closed Thread
