Closed Thread
Old 02-23-2017, 05:59 PM   #5026
Andy4639
Old member
Andy4639's Avatar
Wink Re: What did you do to your truck today? Chapter II
Mine blew out while driving it. Be carefull with it. You want have hardly any brakes if it blows out...ask me how I know.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 02-23-2017, 08:10 PM   #5027
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Late model rear view mirror installed in the ramp truck. Has the C&T in it. Glued to the new windshield.
Andy4639 is offline
Old 02-24-2017, 12:00 PM   #5028
toolboxchev
Love it Andy, I did some work on mine yesterday, the stupid thing still aint working, will post pics when I figure it out!
toolboxchev is offline
Old 02-24-2017, 12:19 PM   #5029
bean
Andy
What did that mirror come out of?
bean is offline
Old 02-24-2017, 12:20 PM   #5030
bean
Andy
bean is offline
Old 02-24-2017, 12:45 PM   #5031
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Originally Posted by bean View Post
Andy
I try and get them out of 2007-12 GM trucks. I have two more complete units.
toolboxchev,
you talking about a mirror not working?
If so what's the problem? I have all the diagrams for the different hook ups. The wiring is basic but the connectors are a little different depending on the models.
I have also found some sensor want read right with some of the mirrors I have.
Andy4639 is offline
Old 02-24-2017, 04:57 PM   #5032
ohboy321
ohboy321's Avatar
NH temps have been in the mid 60's, so I got motivated to work on the truck today.
I replaced my steering gear last summer, but the steering was getting sloppy again by fall. I then garaged it for the winter.
Today I hooked up a rope to the steering wheel so I could move it back and forth while underneath. I found that all 4 bolts on the steering gear were loose and it was moving up and down when I turned the wheel. 1 bolt had backed out about 1/2 and inch.
I replaced all 4 bolts and lock washers and torqued them to spec. I will keep a closer I on it when driving season returns in April.
I also replaced the center Yankee 77 marker light with a better one I picked up last fall.
ohboy321 is offline
Old 02-24-2017, 07:57 PM   #5033
ohboy321
ohboy321's Avatar
Originally Posted by firedemon View Post
use red locktight too
Thanks Firedemon, I thought about it but wasn't sure. I will now do that based on your suggestion.
ohboy321 is offline
Old 02-24-2017, 08:42 PM   #5034
Metaldoc
Metaldoc's Avatar
New speaker box and storage access to each corner. Door panel ribs all line up.
Metaldoc is offline
Old 02-24-2017, 09:01 PM   #5035
kilrcady
a little color
nice color
kilrcady is offline
Old 02-24-2017, 09:29 PM   #5036
ghalperin
ghalperin's Avatar
You should check your frame for cracks at the bolt holes. They tend to crack when the bolts are loose.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 02-24-2017, 10:03 PM   #5037
ohboy321
ohboy321's Avatar
The frame looks fine, but I am wondering if the bolt holes are out of round from things moving around. One of the bolts I replaced looked like it was beat up by side to side movement.
ohboy321 is offline
Old 02-25-2017, 12:12 AM   #5038
toolboxchev
Did a little fabrication and wound up with this...
Old 02-25-2017, 05:45 PM   #5039
66clow
66clow's Avatar
Went to a car show and then took the c10 to the sea and rode my monster bike.
66clow is offline
Old 02-25-2017, 07:17 PM   #5040
OregonNed
OregonNed's Avatar
A nice day for once so I pulled into the car port and put in my restored hood hinges. Nice to get some good, firm hinges in.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 02-25-2017, 07:30 PM   #5041
66clow
66clow's Avatar
How did you restore them? Just paint or were they repaired?
66clow is offline
Old 02-25-2017, 07:42 PM   #5042
dean_greenbean
[ATTACH]1626389[/ATTACH
Restored my grille.
dean_greenbean is offline
Old 02-25-2017, 07:47 PM   #5043
OregonNed
OregonNed's Avatar
I bought the set all refurbished and powder coated on EBay
Old 02-26-2017, 12:11 AM   #5044
mud.man.rj
mud.man.rj's Avatar
Firedemon, engine looks nice, so with alt on drivers side does that make it no power steering then.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 02-26-2017, 09:08 AM   #5045
NoStopN
NoStopN's Avatar
Nice to know that I'm not the only person using ratchet straps to hold body parts up where they can be worked on.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 02-26-2017, 11:47 AM   #5046
Nomadicflyer
Nomadicflyer's Avatar
I finished paint on the cab, last night. This green is so translucent, it took 8 coats over the repaired/primed areas. 6 coats of clear. PPG shopline. For me, this is a huge milestone.
Nomadicflyer is offline
Old 02-26-2017, 11:50 AM   #5047
427Carl
427Carl's Avatar
Nice job love the green
88 Suburban Silverado (original 48,000mi)
99 GMC Z71 stepside
01 GMC 2500HD crew (Texas truck)
07 Chevrolet Suburban LT
84 Chevrolet S10 short box 355 V8
427Carl is offline
Old 02-26-2017, 12:28 PM   #5048
BC10
BC10's Avatar
Inspiring and beautiful.
I keep going back and forth and either painting mine in the garage, or just sending it to paint prison in a shop.
BC10 is offline
Old 02-26-2017, 12:39 PM   #5049
Nomadicflyer
I was kinda forced into doing it myself. I couldn't find a shop that would do it (they all want the insurance jobs), the help I did find didn't work out so well. So, if you want something done....
What a humbling experience. I think I made every mistake in the book, and then started writing my own chapter! For me, if I could have had someone work with me, steer me on the righteous path, it would have been a pleasant experience. Unfortunately I only had help here and there, lots of reading and youtube, a warchest for tools and supplies.
Thanks for the compliments! I take motivation wherever I can. Here's where we started:
Old 02-26-2017, 12:42 PM   #5050
Nomadicflyer
Dean Greenbean:
Nice job, brother. I've got cracks in the plastic insert, did you have any to fix?
Closed Thread
