Closed Thread
Old 04-21-2012, 07:30 PM   #5076
Hagelin
Hagelin's Avatar
Re: What did you do to your truck today?
Paint!
Hagelin is offline
Old 04-21-2012, 07:35 PM   #5077
mud.man.rj
mud.man.rj's Avatar
Now that is blue and more blue, looks good.
mud.man.rj is offline
Old 04-21-2012, 08:09 PM   #5078
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by CRGRS 66 View Post
Removed the cracked intake, and working on installing the new edelbrock performer. Doing some clean up in the process. Called it a day so the paint can dry on some bits and pieces. Should have it all back together tomorrow. As the manifold is aluminum, I installed SS pipe plugs in the heater, temp sender, and extra vac ports. Careful not to over tighten of course
Coming together nicely and looking good. Interesting and nice to see you still have the late 60's draft tube/smog adapter. They work great and are the easiest solution for converting to a smog valve, but like a lot of other 45+ year old parts they are becoming increasingly difficult to find.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-21-2012, 09:23 PM   #5079
lwb66step
lwb66step's Avatar
Originally Posted by Hagelin View Post
Paint!
Looking good
1966 LWB Stepside......SOLD
1963 SWB Fleetside.....Current Project
I hate all fords.
lwb66step is offline
Old 04-21-2012, 10:04 PM   #5080
Fastest32
Fastest32's Avatar
Installed rear tj springs and cut a coil and a half!! Looks 100x better.
Fastest32 is offline
Old 04-21-2012, 10:09 PM   #5081
lwb66step
lwb66step's Avatar
Pics? I have tjs on my 63. Just curious to see mine comp to yours
I hate all fords.
Old 04-21-2012, 10:12 PM   #5082
64shortbox
64shortbox's Avatar
Pics, Pics, we want pics! All the hard work you did you need to show off the fruits of your labor.
64shortbox is offline
Old 04-21-2012, 11:07 PM   #5083
Fastest32
Fastest32's Avatar
Old 04-21-2012, 11:14 PM   #5084
CRGRS 66
CRGRS 66's Avatar
I was wondering about that adapter. I had been wondering where the PCV valve was, it was in line, hoses were so tight together I overlooked it. Not having a sandblast booth, I wire wheeled it (and a number of other bits, and painted it with aluminum coloured rust paint. Should have all back together tomorrow except the distributor. I ordered an electronic conversion kit from Performance Improvements, should be in Tuesday. I will post a pic tomorrow of the PCV RD adapter once it is re-installed.
Thanks for noticin!
CRGRS 66 is offline
Old 04-21-2012, 11:17 PM   #5085
CRGRS 66
CRGRS 66's Avatar
Paint!
That looks awesome. I am glad the truck I settled on has a 283, but I would have loved to have had a 6! Please be sure to put more pics up as you go, can't wait to see it in the engine bay
CRGRS 66 is offline
Old 04-21-2012, 11:18 PM   #5086
CRGRS 66
CRGRS 66's Avatar
tj springs?
CRGRS 66 is offline
Old 04-21-2012, 11:22 PM   #5087
CRGRS 66
CRGRS 66's Avatar
Very nice stance, I plan to lower my front end 2.5, but kind of want to leave the rear where it stands. I am older than my truck, so I like the rake look, mild rake mind you.
CRGRS 66 is offline
Old 04-21-2012, 11:24 PM   #5088
Fastest32
Fastest32's Avatar
I set it down after i cut the springs and before i did the rear and it looked pretty cool. I wish I would've taken a picture. It sits pretty level now.
Old 04-21-2012, 11:30 PM   #5089
dantimdad
dantimdad's Avatar
My son and I got the front clip just about disassembled today.
We'll finish it up tomorrow and blast the cowl parts and start the smoothing process.
Next up after that, is blasting and sanding the inner fenders and core support in prep for painting.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 04-21-2012, 11:31 PM   #5090
lwb66step
lwb66step's Avatar
I like the stance how's it ride? Did you change shocks? Mine seems to sit lower in the rear on the tj coils but I heard that there are different spring rates to tj coils depending on the model of jeep they came on
I hate all fords.
Old 04-21-2012, 11:33 PM   #5091
CRGRS 66
CRGRS 66's Avatar
very nice looking truck sir!
what are TJ springs?
CRGRS 66 is offline
Old 04-21-2012, 11:34 PM   #5092
lwb66step
lwb66step's Avatar
tj springs?
Yessir the tj model jeep wrangler has coil springs that aren't as heavily rated as ours and also are tapered allowing direct bolt in with the rear retainers allowing a 2 inch drop
I hate all fords.
Old 04-21-2012, 11:37 PM   #5093
CRGRS 66
CRGRS 66's Avatar
Well... you learn something new every day, especially when you are new in town like me! Thanks lwb66
CRGRS 66 is offline
Old 04-21-2012, 11:39 PM   #5094
lwb66step
lwb66step's Avatar
Here's mine after I cut the front but with the stock rears still on it
Here it is with 1997 - 2006 tj coils and Monroe sensamatic shocks part #310000 the entire drop cost me 65 dollars and 2 hours
I hate all fords.
Old 04-21-2012, 11:49 PM   #5095
Fastest32
Fastest32's Avatar
It dropped mine about 4". Rides really good so far. Stock shocks too
Old 04-22-2012, 12:01 AM   #5096
ctandc
Finished tearing the old 230 down. Crank is clean and out. Cam is clean and out. Broke the cylinder glaze with a hone, then gave the block a good bath. Dried it off, then wiped the cylinders down with WD40.
Masked off the block for primer / base / clear.
Soaking the main caps now in parts cleaner, tomorrow I'll bolt up the timing cover and oil pan before paint.
After that I'll soak the pistons in parts cleaner and polish the crank.
____________________________
ctandc is offline
Old 04-22-2012, 06:49 AM   #5097
a37lesalle
a37lesalle's Avatar
It was actually yester day, but, got the interior sprayed with clear coat and the exterior has its first coat of clear. Today plan on start putting interior back together. Wish I could post some pics of the 62 chevy but have not figured that part out yet.
a37lesalle is offline
Old 04-22-2012, 08:33 AM   #5098
CRGRS 66
CRGRS 66's Avatar
a37lesalle, to upload pictures, first click on "Post reply" when you do that if you scroll down you will see "Manage Attachments", click on that. In the new window click on "Choose File" Then locate the picture you want to upload on you PC. Then it goes back to the "Choose File" screeen, you can select another pic if you wish, or click "Upload", it may take a few seeconds to a minute depending on the number of pics, and the file size.
NOW, LET'S SEE SOME PICS!!!!
CRGRS 66 is offline
Old 04-22-2012, 12:13 PM   #5099
steve'62
steve'62's Avatar
I plugged my new intake, applied some "bling", painted engine compartment and tried to clean everthing up the best I could. Also replaced cap/rotor, re-ran fuel line, new fuel filter ect ect. Here are a couple before and after pics.
steve'62 is offline
Old 04-22-2012, 12:21 PM   #5100
markeb01
Senior Enthusiast
markeb01's Avatar
Nice improvement!
markeb01 is offline
Closed Thread
