03-18-2017, 06:10 PM | #5126 |
Re: What did you do to your truck today? Chapter II
replaced new drivers mirrors that some POS broke on me
03-18-2017, 07:30 PM | #5127 |
Put some primer on my interior heater box. Going to fix my rear brakes after the kids are in bed.
03-18-2017, 07:42 PM | #5128 |
Attempted to change fuel filter, but the line nut is stuck pretty good.
Was afraid to mess the threads up or bend the line. Also was gonna change the oil and filter, but the oil pan is bent up pretty bad, concerned to get the drain bolt to seal again. These past couple weeks have been rough trying to undo all the rigged up, backwoods ass work that's been done over the past 45 years lol. |
03-18-2017, 09:09 PM | #5129 |
Bolted on the new rolling stock...
72 Cheyenne Super SWB 350/TH350 18 GMC Sierra All Terrain Crystal Red/5.3 daily driver 14 Corvette Stingray Black/1LT/7M |
03-18-2017, 10:43 PM | #5130 |
Entered it into and drove it to the Good Guys Spring Lone Star Nationals at Texas Motor Speedway in Ft. Worth Texas.
Today was just a perfect 80 degree, blue sky, white puffy cloud car show kinda day! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
03-19-2017, 09:52 AM | #5131 |
Getting close...the Transformation is almost complete....
First pic 17 years ago when my son drove it as his first vehicle. Second pic a few weeks ago. |
03-26-2017, 07:34 PM | #5132 |
03-26-2017, 08:40 PM | #5133 |
03-26-2017, 08:45 PM | #5134 |
I knocked the pee waddle outa my carb today. Float was stuck. Fixed.
03-28-2017, 01:19 PM | #5135 |
70+ ( Old Skool Club )
Not today but yesterday has the new booster/master, shocks plus new brake hoses installed on my truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
03-28-2017, 01:31 PM | #5136 |
Just need an altitude adjustment like this 72 we just did and that will be one sweet truck!
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
03-28-2017, 03:13 PM | #5137 |
What are specs on the drop you used on that one?
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
03-28-2017, 03:26 PM | #5138 |
I would like to know too!
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
03-28-2017, 03:38 PM | #5139 | |
Thanks Derek |
03-29-2017, 11:52 AM | #5140 |
Front is a 4" drop with 3" spindle and 1" CPP spring. Rear is a 5" DJM flip kit. Yes that's correct it is a rear leaf spring truck. I think Front was $325 in parts and the rear was $135.
03-29-2017, 12:34 PM | #5141 |
I have a factory sway bar on my truck and they are ( I'm pretty sure ) 7/8 inch thick. I picked up a 1 1/4 inch sway bar from a wrecker from a 85 1 ton Chevy and will be installing that with new polyurethane bushings. If you do not have a front sway bar put one on, they are literally a bolt in , and you won't believe the difference it makes in the handling of your truck. I haven't driven the truck enough to comment on the shocks but the truck stands a touch taller now and seemed smoother on the ride home from the shop. Living on the Prairie here in Western Canada there are not a lot of canyons to carve...
03-29-2017, 12:55 PM | #5142 |
Getting ready to do a voltage meter conversion.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-29-2017, 07:32 PM | #5143 | |
03-29-2017, 10:29 PM | #5144 |
03-29-2017, 11:38 PM | #5145 |
Nearly finished cleaning the exhaust heat shield under the passenger side, oh boy. Guess it wants an overnight vinegar soak. Nice piece though, no pitting.
Installed the bench seat adjuster wire in the driver, and if an operable seat wasn't cool enough, I found the original jack handle & stow-away bag hid behind the seat. Did my part to help keep Wes in business. Good parts and always great information. Must have been on the phone an hour.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-30-2017, 06:48 PM | #5146 |
Finally put the dimmer switch grommet in months after installing the carpet and just cutting an X for access. Seriously just used a box knife after stressing about doing it "right" and it fits perfectly. Ignore the old torn rubber mat, it came with the truck that way 5 years ago!
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
03-30-2017, 08:08 PM | #5147 | |
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
03-30-2017, 08:17 PM | #5148 |
It came with the Trim Parts carpet I got. Summit has them. https://www.summitracing.com/parts/oam-z0100
03-30-2017, 09:14 PM | #5149 |
Thanks brother
03-30-2017, 09:24 PM | #5150 |
What setup do you have on front to use a 3" spindle? I've only seen 3" spindles for 73-up.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
