04-25-2012, 08:29 PM | #5151 |
Re: What did you do to your truck today?
Installed the generator wiring harness.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by 62 Barnfind; 04-25-2012 at 08:49 PM. |
04-26-2012, 01:52 AM | #5152 |
ive decided on buying some porta walls instead. my bullets didnt fit so i shipped them back. i'm trading some locksmith work to a muffler shop in town this week and i'm getting my stainless shorties hooked up and tucked in under the truck.
If you used to be...then i guess you never were. |
04-26-2012, 02:02 AM | #5153 |
tried to arrange the body of my truck to look like its actually a truck and not just a body sitting next to my house.(keep the neighbors happy) need to still stick some tires under it
my build:::patina 67 c10 chopped/bagged/z'd::: http://67-72chevytrucks.com/vboard/s...d.php?t=521253 |
04-26-2012, 06:26 PM | #5154 |
I added oil... She's sucking a lot back these days. Then drove it to make sure some of that oil went to good use.
Posted via Mobile Device |
04-26-2012, 08:30 PM | #5155 |
is that what they call yard art? i like it but i don't think my HOA would go for it
04-26-2012, 09:02 PM | #5156 | |
Exactly what I "was" looking for. This is what I came up with though... |
04-26-2012, 09:08 PM | #5157 |
1/4-28 rod, and a rod yoke, what do you think?
04-26-2012, 09:09 PM | #5158 |
Started sanding and pulling dents.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
04-26-2012, 09:14 PM | #5159 |
Tried to fix gas gauge with new sender/wire. Still no luck. Barely moves off empty. Wonder if I have 90 ohm gauge with 30 ohm sender?
Try again tomorrow. Posted via Mobile Device |
04-26-2012, 09:50 PM | #5160 |
Senior Enthusiast
Good fix, and more dependable than the clip. Other than being a different style heim joint, that's the same setup I ran for 20 years until recently switching to a cable style gas pedal.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-26-2012, 10:31 PM | #5161 |
hey markeb, just going through your build thread, very nice truck, and very enjoyable read, actually just on page 2.
04-26-2012, 10:31 PM | #5162 |
Replaced my column shifter bushings and aligned the shifter arms. Put the name decals on the front bumper and tailgate.
'66 C10 250 3-on-the-tree '68 Galaxie 460/C6 '74 914 2.0 |
04-27-2012, 12:18 AM | #5163 |
Mounted & plumbed my new 1961 Schlitz keg in the bed of my truck. Tomorrow the stock tank comes out & the old fuel filler neck come gets shaved off.
04-27-2012, 12:49 AM | #5164 |
Now the cops will pull you over and say,,what's in the keg.
04-27-2012, 01:40 AM | #5165 |
Senior Enthusiast
Thanks for the interest and feedback! I try to keep up with the various build threads, but there are so many cool things on this site every now and then I'm surprised to find an ongoing thread I've never seen before.
04-27-2012, 03:59 AM | #5166 |
rotated the tires, front to back.
pulled the drums and checked the shoes for wear. checked the fluids while I was dirty. -W |
04-27-2012, 09:55 PM | #5167 |
Started pulling the front torsion-bar crossmember - 3 bolts out and a bunch to go.
04-27-2012, 10:09 PM | #5168 |
I added a second yoke at the carb, and switched to socket head shoulder bolts. I am very pleased with the result. A before, and an after for ya
04-27-2012, 10:14 PM | #5169 |
the new intake, coil, and painting of some of the bits and pieces helps too!
04-27-2012, 10:57 PM | #5170 |
ordered 108 button head stainless steel bolts and washers in different sizes to replace all the visible bolts on the engine, inner fenders, fenders, etc.
Even if my painting sucks, the bolts will look good! We finally decided on the color scheme - dark purple with the tan silverado interior. Going to fab up a vinyl over fiberglass shell dash cap and headliner and cover the door panels in the vinyl as well. I will be so glad to get all the patch panels in so we can start, sanding and painting. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
04-27-2012, 11:46 PM | #5171 |
dantimdad,
For your button head stainless bolts, you might want to check out the Mc Master-Carr catalog and get some of the clear nylon flat washers to place under the button head bolts for the inner fenders etc. to protect the paint from scratching or marring. Just a thought. |
04-27-2012, 11:51 PM | #5172 |
Terry
Saw the pictures you linked me to, very, very nice looking truck sir! They all need some work, no matter how good the look. I am off to bed now, want to get an early start at finishing up me intake swap, and get the old girl back on the road, need a fix! Craigerr |
04-28-2012, 12:25 AM | #5173 |
64shortbox,
Thanks for the tip! I will order some. Steven
04-28-2012, 08:36 PM | #5174 |
Old and crusty
Got some parts back from powder coat this week so I did some assembling.
This is what the finished grill I've been working on will look like. I had to remove the headlight buckets from the C50/60 grill and use the C10 ones so as long as they were out I powdered them black and just used small screws to remount them into the grill. The backside shot shows how I attached the letters to the center section. I think it came out real nice. I also assembled my power brake assembly. I went to the local yard and sawed off a pedal off a late model Silverado, did the same to my pedal then welded the longer pedal to my brake arm. All was powder coated, reassembled and a new rubber pad from the local Chevy parts store installed. |
04-28-2012, 09:00 PM | #5175 |
I am not much for mods, but let me tell you... that grill looks absolutely fantastic... how much would you take for it
Today, I did not accomplish too much... Mom in Laws 80th, happy birthday to you, bye now! I did however get my distributor back in, and ran a bit of new fuel line. Need to sort out the top rad hose, and the routing of the spark wires. I think then it is time to get her back on the road. |
