#5151 |
Post Whore
![]() Join Date: Aug 2013
Re: Facebook Finds
1977 Chevrolet Silverado C10. "Square Body" Long Bed. 350/350 ( 350 engine / turbo 350 transmission). 42,xxx miles showing, but it could be 142,xxx miles. A lot of original parts might suggest 42,xxx miles. Looks , runs and drives great. Daily driver. Power steering, power brakes, factory AC ( works just fine). Most of the mechanicals have been redone over the years as needed. Backup camera added to add a bit of technology. We know some of the history of the truck but not from the beginning , so some of this has to be a guessing game. What we do know is the engine was replaced a while back, newer carburetor , and most other mechanical stuff has been redone. Things you'd expect to replace on a 45 year old vehicle no matter how many miles. Just from age alone. Truck came from Wisconsin originally but I don't feel it was ever used in the winter time and subjected to salt on the roads. Frame is solid and so is the body. A little bit of surface rust here and there but no holes or "rot". Very minor. Truck looks, runs and drives great. Very clean inside and out. Nice sounding exhaust, not obnoxious , just right. Feel free to call or message with any questions, or if you'd like more pictures. Or pictures of certain areas. I can only post a finite amount of pictures in the ad. https://houston.craigslist.org/cto/d...546619019.html
#5152 |
Post Whore
Re: Facebook Finds
#5153 |
Post Whore
Re: Facebook Finds
#5154 |
Post Whore
Re: Facebook Finds
#5155 |
Post Whore
Re: Facebook Finds
#5156 |
Post Whore
Re: Facebook Finds
#5157 |
Post Whore
Re: Facebook Finds
305 V8
AUTOMATIC TRANS POWER WINDOWS POWER LOCKS TILT CRUISE CONTROL 4/6 PROFESSIONAL DROP NEW AIR SHOCKS ON REAR IN CASE YOU NEED TO HAUL A LOAD !!! NEW TIRES TINTED WINDOWS TONNEAU BED COVER NEW SMOOTH REAR BUMPER NEW DUAL EXHAUST THIS TRUCK IS IN AMAZING ORIGINAL CONDITION EXCEPT FOR THE LOWERING KIT. THE FRAME WAS NOT CUT AND ONLY A REAR AXLE FLIP WAS INSTALLED AS TO KEEP FROM CUTTING THE FRAME EVERYTHING WORKS ON THIS TRUCK. THE AIR IS COLD , CRUISE WORKS , EVERYTHING !! THE INTERIOR IS AS NICE AS I HAVE EVER SEEN ON A C10 SQUAREBODY THE ORIGINAL DASHPAD DOES NOT HAVE ONE CRACK !!! THE MILES ARE BELIEVED TO BE THE ACTUAL MILES ALTHOUGH THE TITLE WILL SAY EXEMPT DUE TO THE AGE OF THE TRUCK , BUT YOU CAN TELL IT IS ACTUAL MILES WHEN YOU SEE IT IN PERSON. THE TRUCK STILL HAS 90% ORIGINAL PAINT WITH A FEW PATINA SPOTS. THE RIGHT FRONT FENDER HAS BEEN PAINTED WHEN THE ORIGINAL OWNER BUMPED INTO THE LEFT SIDE OF HIS WIFE"S CAR WHEN PULLING INTO THE GARAGE IN 1998. THE TRUCK RIDES AND DRIVES BETTER THAN ANY C-10 WE HAVE OWNED , AND WE HAVE OWNED MANY OF THEM !! ABSOLUTELY NO SMOKING WHEN STARTED AT ANY TIME !!! NO LEAKS THIS IS AN EXCEPTIONAL TRUCK. I LOVE THE FACT THAT IT STILL HAS THE FACTORY AM/FM CASSETTE THAT WORKS ! IF YOU ARE LOOKING FOR A TRUCK YOU CAN ENJOY FOR YEARS THAT YOU CAN DRIVE TO THE LOCAL DRIVE-IN CAR SHOW , ONE THAT WILL ONLY INCREASE IN VALUE , THEN YOU HAVE FOUND IT !! THIS COLOR IS A RARE COLOR. ALSO THIS IS A HIGHLY OPTIONED TRUCK. SO DO NOT LET IT GET AWAY !!! TRUCK DOES HAVE A COUPLE OF MINOR BRUISES I WILL POINT OUT IN THE PICTURES. TRUCK WAS PURCHASED NEW IN CARROLLTON GEORGIA AND IS A RUST FREE SOUTHERN JEWEL !!! ASKING 19,900 !!! LINK TO VIDEO: https://dallas.craigslist.org/dal/ct...545147247.html https://www.youtube.com/watch?v=us5D4JjXATk |
#5158 |
Post Whore
Re: Facebook Finds
#5159 |
Post Whore
Re: Facebook Finds
#5160 |
Post Whore
Re: Facebook Finds
https://chicago.craigslist.org/nch/c...551849605.html 1979 Chevrolet Silverado BIG 10 C10
Factory 454 V8, TH400 Trailering Special 2 wd long bed 99k actual miles Mostly original paint NEW brakes Restored 16 x 8 1/2" Ralley Wheels New Caps, trim Rings New Tires 1,500 miles ago Fresh alignment New headliner - LMC Truck New carpet New seat, arm rests, sill plates New center grill New door to cab rubber seals New rear leaf springs --- $1,200 New rear kyb gas shocks --- $300 New rear brake shoes, drums - $375 New windshield / rubber gasket ONLY 1 rust hole behind rear wheel in each rear fender bottom, and 1 in each front inner fender LOADED WITH OPTIONS: Factory Power Disc brakes, tilt steering, ps Power windows All Weather A/C Heavy Duty Chassis / Suspension Intermittent wipers 3.40 rear axle ratio Camel Special Custom Interior Tinted glass Front stabilizer bar Speed Control Chrome Rear Step Bumper Dual Fuel Tanks - switch works Deluxe Two Tone Paint - MOSTLY original Fresh Tune New valve cover gaskets, covers painted gm blue NO RUST HOLES in hood, windshield frame, rocker panels, floors, doors, cab, OR THE bed!!! Needs some minor interior trim still. I have some tidbits Clean utah title in my name all exterior lights work the power windows both work up n down the a/c needs to be charged and the system is intact The gauges and speedometer were NOT re connected by the shop i hired to install the new gauge cluster cover and dash pad were installed - they need to be connected. That was 1,500 miles ago. This is a very nice running, great driving classic '79 Big 10 "Trailering Special" 454 V8 C10 pick up truck. I'm asxkin' $14,900 / offers Delivery from UTAH, 84401 Available 60 more photos available by email I also have 25 Factory Original GM 15 x 8 and 15 x 7 5 and 6 lug steel ralley wheels available at xtra cost. some are powder coated. some epoxy painted. some original. |
#5161 |
Post Whore
Re: Facebook Finds
#5162 |
Post Whore
Re: Facebook Finds
#5163 |
Post Whore
Re: Facebook Finds
#5164 |
Post Whore
Re: Facebook Finds
#5165 |
Post Whore
Re: Facebook Finds
#5166 |
Post Whore
Re: Facebook Finds
#5167 |
Post Whore
Re: Facebook Finds
#5168 |
Post Whore
Re: Facebook Finds
#5169 |
Post Whore
Re: Facebook Finds
#5170 |
Post Whore
Re: Facebook Finds
#5171 |
Post Whore
Re: Facebook Finds
#5172 |
Post Whore
Re: Facebook Finds
#5173 |
Post Whore
Re: Facebook Finds
#5174 |
Post Whore
Re: Facebook Finds
#5175 |
Post Whore
Re: Facebook Finds
