Closed Thread
Old 10-22-2012, 07:43 PM   #5176
ghostvbhc
ghostvbhc's Avatar
Re: What did you do to your truck today!
VWnate1 - Yeah, when I get paid on Friday, we're gonna get a different and longer radiator hose. And, everything works fine with the lines, maybe ill replace them with the ones from rock auto when I get paid.
1969 Chevy C10 250 straight six. Still a work in progress.
ghostvbhc is offline
Old 10-22-2012, 09:24 PM   #5177
ksucatz
Suppose to be workin........
ksucatz's Avatar
Nate,
I think the tach I have is a stock 6cyl. It always reads off with the 8cyl I run. Way too high. When traveling 55, it reads like 4500 rpm or something like that. I need to get rid of it. Interested?
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
"Stupidity is like a skill, some are born with it and some develop it over a period of time."" Author unknown
ksucatz is offline
Old 10-22-2012, 11:48 PM   #5178
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Originally Posted by ksucatz View Post
Nate,
Yes I am ! .
VWNate1 (at) yahoo.com
Thank you .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 10-23-2012, 12:06 AM   #5179
ItsRandy
ItsRandy's Avatar
I went to the upholstery shop, this is my seat. I wish the upholstery dude would finish my interior, he has had my truck going on 3 weeks.
ItsRandy is offline
Old 10-23-2012, 12:18 AM   #5180
heathbirkendahl
Well worth the wait if you ask me. Very nice!
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline
Old 10-23-2012, 12:28 AM   #5181
HotRod C/10
HotRod C/10's Avatar
Originally Posted by VDOG View Post
Did you paint it with the front crossmenber on or off? Curious cause I need to do mine.
I left it on.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline
Old 10-23-2012, 01:45 AM   #5182
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Originally Posted by The Big Green View Post
Pulled my leader hose because Im dumb and trashed it lol. This is what I did the other day! Happy Halloween!! Since the cops got called and tried to make me do away with my Halloween I said F it and didnt. I did put yellow tape around it like a crime scene.
That is freaking hilarious.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline
Old 10-23-2012, 01:47 AM   #5183
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I have been fighting with my Vortec 454, been having low power and high fuel consumption issues, I am thinking it is my MAP sensor, going to go get one tomorrow and see if it fixes it.
MrBeast is offline
Old 10-23-2012, 06:15 AM   #5184
ghostvbhc
ghostvbhc's Avatar
Itsrandy - That seat is beautiful! Well worth the wait for it.
Old 10-23-2012, 09:05 AM   #5185
Gor77
Gor77's Avatar
___________________________________
Dima
1970 Chevrolet C10 stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=569197
Gor77 is offline
Old 10-23-2012, 09:09 AM   #5186
nlped
nlped's Avatar
Beautiful seat...I'm thinking that it is well worth the wait if it all turns out that good!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 10-23-2012, 09:17 AM   #5187
1970 C10 MJW
1970 C10 MJW's Avatar
totally agree with gor 77, my sway bar and bumper bracket came in finally
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline
Old 10-23-2012, 09:54 AM   #5188
ksucatz
ksucatz's Avatar
Originally Posted by VWNate1 View Post
Yes I am ! .
Thank you .
I will try and pull the dash tonight so I can get a better look. Is there any markings that state which it is?
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
ksucatz is offline
Old 10-23-2012, 10:01 AM   #5189
ksucatz
ksucatz's Avatar
I tried to put the freshly coated front upper control arms back together with the new cross shafts and bushings. The bushings would bottom out on the shaft before tightening up on the arm, so when installed, the rotation is on the arm threads instead of the greasable shaft threads. Ugh....If I understand these correctly, the bushing should lock down on the control arm. The shaft is centered because the bushings are tight on it, and there is equal gap between the hex ends and the control arm....
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
ksucatz is offline
Old 10-24-2012, 12:43 AM   #5190
ItsRandy
ItsRandy's Avatar
Originally Posted by Gor77 View Post
You and I must be related.
ItsRandy is offline
Old 10-24-2012, 01:07 AM   #5191
hpcgmc
hpcgmc's Avatar
I removed my Barden rear bumper (the thing must weigh 75 lbs!) and pulled apart the tailight wiring to get the tailights to work. Anyone in NorCal wanna trade a bigass Barden bumper for a stock smoothie bumper???
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline
Old 10-24-2012, 08:53 AM   #5192
VWNate1
VWNate1's Avatar
Yes but I know not what~ . there's other threads that cover the GM part @# in detail .
I imagine you could simply google the P/N and it'll tell you if 6 or 8 cylinder .
-Nate
Geezer
VWNate1 is offline
Old 10-24-2012, 11:34 AM   #5193
ksucatz
ksucatz's Avatar
Nate, looks like it is an 8cyl tach.
P/N even says it's an 8 cylinder
Just wish I knew why it reads off so bad.
Brent
'68 C10
'70 C10
'72 LeMans
"03 Trailblazer
ksucatz is offline
Old 10-24-2012, 01:25 PM   #5194
flushdrew
wednesday - purchased my 70 CST-10
thursday - bought parts and materials to shoot primer on it
friday - sanded all of the surface rust on the body - put rust preventer and sealant on.
saturday - blocked and primed with black primer - bought new wheels/tires from CL
sunday - mounted new wheels and tires - discovered front drivers side hub is rotten
monday - called everywhere to no avail
tuesday - posted here about finding a '70 hub
wednesday - ordered one from a semi-local place that actually had one
that takes up just my first week of owning this truck. am i addicted?
flushdrew is offline
Old 10-24-2012, 01:41 PM   #5195
jc70chevy
jc70chevy's Avatar
waited on my order from infinti machine got my heater delete panels and sanded down fire wall and tack weilded al panels in place now to figure out if im guna grind them smooth or leave them
jc70chevy is offline
Old 10-24-2012, 08:41 PM   #5196
Spike44
New Radiator w/ Upper and Lower Hoses..Not really a "fun" thing.
Spike44 is offline
Old 10-24-2012, 09:22 PM   #5197
Tinkermc
on my dd i drove it about 100 miles and replaced the fuel filter runs like new now
Tinkermc is offline
Old 10-24-2012, 09:26 PM   #5198
Mister-B
Do you mind posting up some instructions on how to do that?
Mister-B is offline
Old 10-24-2012, 10:38 PM   #5199
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Oooh, oooh, let me.
Open the driver's side door on the truck. Climb in facing the windshield.
Adjust the seat and mirrors, if needed. Maybe the tilt steering wheel.
Push the odo button, if you have one, until it reads "0". If you don't, and you probably won't, make a mental
note of the fourth digit from the right on the milage counter (odometer). You'll need that later.
Insert key in the big round thing under the ashtray (to the left of the heater/air conditioning controls). Turn the key to the right.
But only for long enough so that you can hear the engine start. If you let go, the truck will keep running.
Look up. Look left. Look right. Look in the rear and side view mirrors. If you have an auto trans like mine, the gear selector is on the steering column.
Select the appropriate gear. If you are backing out of a driveway...In fact, if anything is in front of you that's pretty close, choose "R". But before you do that,
check to see if the emergency brake is on...Put your foot on the foot brake. Keep it there while you release the e-brake. Keep it there while you 1) select the
proper gear..."D" usually works pretty well... and, 2) Look up. Look left. Look right. Look in the rear and side view mirrors. Again.
Signal if you're into that. Assuming an auto trans, release the foot brake and, at the same time, use the same foot (right) to lightly (if that's the way you want to start out)
press on the big rectangular foot pedal that's all the way to the right (on the floor).
If you have a standard trans, column or floor shifter, someone else will have to chime in.
Then, drive around until that fourth digit from the right adds up to one more number than when you started. If it was a "9" when you started, you'll be looking for a "0".
Another good tip is to check for gas. I mean, check to make sure there's gas *in the truck*. DAMHIK to do this....just make sure. And, oh, you can't always rely on that
big gage on the right side of the dash. Sometimes it reads Full when it's really "Empty". Just a bad joke that is sometimes played on 67-72m truck owners.
Don't know who started it.....
Hope you have a sense of humor...No disrespect intended...Just in a joking mood tonight...
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 10-24-2012, 10:48 PM   #5200
ole dollor
ole dollor's Avatar
and where are the pic's, you know we need pic's
Originally Posted by magwakeenercew2jh View Post
Oooh, oooh, let me.
Push the odo button, if you have one, until it reads "0". If you don't, and you probably won't, make a mental note of the fourth digit from the right on the milage counter (odometer). You'll need that later.
Insert key in the big round thing under the ashtray (to the left of the heater/air conditioning controls). Turn the key to the right. But only for long enough so that you can hear the engine start. If you let go, the truck will keep running.
Look up. Look left. Look right. Look in the rear and side view mirrors. If you have an auto trans like mine, the gear selector is on the steering column. Select the appropriate gear. If you are backing out of a driveway...In fact, if anything is in front of you that's pretty close, choose "R". But before you do that, check to see if the emergency brake is on...Put your foot on the foot brake. Keep it there while you release the e-brake. Keep it there while you 1) select the proper gear..."D" usually works pretty well... and, 2) Look up. Look left. Look right. Look in the rear and side view mirrors. Again.
Signal if you're into that. Assuming an auto trans, release the foot brake and, at the same time, use the same foot (right) to lightly (if that's the way you want to start out) press on the big rectangular foot pedal that's all the way to the right (on the floor).
Another good tip is to check for gas. I mean, check to make sure there's gas *in the truck*. DAMHIK to do this....just make sure. And, oh, you can't always rely on that big gage on the right side of the dash. Sometimes it reads Full when it's really "Empty". Just a bad joke that is sometimes played on 67-72m truck owners. Don't know who started it.....
ole dollor is offline
Closed Thread
