Old 01-18-2010, 08:33 PM   #501
babyblueoval
babyblueoval's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
x2
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-18-2010, 09:03 PM   #502
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is the rear cab piece cuStom order///??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-18-2010, 09:21 PM   #503
68 short step
Originally Posted by Puropedo View Post
Looking good! Is there any difference betwen the Ls6 and the L76 intakes, powerwise? Did yours came with the Map sensor? I see you reused the TB, did you ran into any clearance problems?
the ls6 has the cathedrail shaped ports, and the l76 intake has the big retangular shape ports...you can not inter-mix the two...the l76 flows more do to the bigger runners....no it did not come with the MAP sensor...no problems at all with useing the TB, everything clears nicely..
68 short step is offline   Reply With Quote
Old 01-18-2010, 09:22 PM   #504
68 short step
yes, made to order...call scotts (they're a vendor) and tell them you want one...
Old 01-18-2010, 11:49 PM   #505
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Originally Posted by 68 short step View Post
yea, but that killer 2 logo is no longer there... 2 reasons 1) when the PB kit went on, the truck got lower, and the pumpkin hit it. 2) the quality, of it wasnt 'up there' so we're gonna get one made a bit diffrent this go around..
Problems with the PB arms?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 01-19-2010, 12:18 AM   #506
63chevyll
gets board easy.......
63chevyll's Avatar
I like those PB arms, not a Bad idea
63chevyll is offline   Reply With Quote
Old 01-19-2010, 12:33 PM   #507
68 short step
no, the arms are like they should be...they had a added 1" more drop built in, then the previous setup...so when the PB arms were installed it lowered the truck 1", and caused interference with the logo.
Old 02-03-2010, 07:35 PM   #508
68 short step
getting some work done on the hulk... moved into a bigger shop, and finally got back to 'working' on the projects again....i got the rear seam filler piece fitted, and tacked on...it was a great fit, only did some minor trimming on the rear (where the rear back glass channel is...it was a bit long....but thats probley because it can fit on a small back glass truck too)
the process wasnt to bad, i trimmed out the sharp edge where the roof meets the back of the cab... and cleckoed it in place, traced around the filler piece, and cut the excess off..then i cut the tabs i used for the cleckos off, and primed the back side off the panels....and tacked the pieces together, still need to tack the back side (along the rear glass channel), final weld, and smooth....
Old 02-03-2010, 07:36 PM   #509
68 short step
Old 02-03-2010, 08:08 PM   #510
VA72C10
VA72C10
VA72C10's Avatar
Looking good!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-03-2010, 08:59 PM   #511
FRENCHBLUE72
PROJECT 7DEUCE
That new shop looks comfortable..
MEMBER #6377
Project "7DEUCE"
Old 02-03-2010, 09:09 PM   #512
killer71
killer71's Avatar
my my how we are movin on up...
1) where's the flat screen? I see the shelf up on top but no tv!
2) you know how i like a clean area so what's with the leaves and scrap metal on the floor?
seriously though; those working conditions look ten times better!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 02-03-2010, 09:19 PM   #513
mcbassin
Still Learning
mcbassin's Avatar
Don, Nice work on the filler piece. Man that shop looks great! Looks to be plenty of room too. There goes the shop rate through the roof
mcbassin is offline   Reply With Quote
Old 02-03-2010, 11:33 PM   #514
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good Don!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-04-2010, 07:41 PM   #515
68 short step
thanks everyone, shop is alot better... i keep it at a nice 69*....it has A/C too, which im excited about that too come summer time...but with it snowing outside and freezeing cold, the shop makes it nice to work....
Old 02-06-2010, 03:16 AM   #516
Avidyn
Avidyn's Avatar
Hey 68,
Can you tell me where to get that bulkhead connector you used for wiring? I read earlier you got it from work, but do you know a supplier? I'd love to use one on my 63 project I have coming up soon. Also, what pins does it use?
Avidyn is offline   Reply With Quote
Old 02-06-2010, 11:35 AM   #517
68 short step
Originally Posted by Avidyn View Post
Hey 68,
ill go thru my receipts and find who the manufacture is, and let you know...
Old 02-06-2010, 11:39 AM   #518
68 short step
got the filler all welded on...an a coulpe of shots of how it use to look, for compairison
Old 02-06-2010, 12:28 PM   #519
msgross
msgross's Avatar
wow, that does look a lot better... goes with the shaved drip rail now...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-06-2010, 05:49 PM   #520
Avidyn
Avidyn's Avatar
Thank you. This truck is coming along great. I've been reading all of your build posts. Getting tips and inspiration for my upcoming project. 63 short step getting an LS3/4L65E.
Old 02-07-2010, 10:00 AM   #521
68 short step
Hey 68,
avionicsinternational.com is their web site...
the plugs PN is 206151-1 and 206150-1
the pins are PN 66099-1 (males) the female pins PN isnt legible...
but there should only be one pin style fot that plug.
Old 02-07-2010, 10:10 AM   #522
68 short step
got a little bit done yesterday, removed and re-installed the center x-member.. installed the raised one in its place, cause we want to run a 1 piece driveshaft...so in doing that the cab floor was cut, and the cab was placed back on the frame (to check how good of measureing i did for the DS loop).... it went on as planned.....i also had to trim more of the fender for it to fit on, i knew tthis would need to be done, since we switch to drop spindles with the new brakes..and or coarse pics of the progress/stance with 22/20 combo
Old 02-07-2010, 12:05 PM   #523
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Talking Re: project INCREDIBLE HULK 6.2L with 6L80E
can't believe I never caught this thread til now. guess I've been slackin' on my board reading.
nevertheless AMAZING job!
if all of us could have 1/4 of your talent there'd be a lot more perfect or near perfect restores and customs running around out there.
Keep the pics coming!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 02-07-2010, 01:06 PM   #524
thepartsguy
thepartsguy's Avatar
What a cool build...I love all the outta the box thinkin....keep it up.
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 02-07-2010, 01:21 PM   #525
killer71
killer71's Avatar
Think you have the "tuckin" issue covered! Sweet work Big Daddy! I'm diggin the two tone green for sum reason!
R.I.P.
Killer 71
10/26/07
