10-30-2010, 08:07 PM | #501 |
6.0 powered square
Re: my 80 build
I decided not to do bags too much money to do it wright
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-31-2010 at 11:38 AM. |
10-30-2010, 11:25 PM | #502 |
6.0 powered square
Re: my 80 build
well got the part of the black paint on the frame will flip it over tomorrow and paint the other side
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
10-31-2010, 11:36 AM | #503 |
6.0 powered square
Re: my 80 build
11-04-2010, 11:55 PM | #504 |
6.0 powered square
Re: my 80 build
If it goes well I plan on moving the frame to garage either tomorrow or Saturday to assemble it
11-05-2010, 10:24 PM | #505 |
6.0 powered square
Re: my 80 build
I was able to get some help and moved the frame to the garage so it should be a roller tomorrow
11-06-2010, 08:51 AM | #506 |
Re: my 80 build
Sweet!
11-06-2010, 09:05 AM | #507 |
Re: my 80 build
Keep @ it.
Food for thought.... you've been driving it super low for a while now & if you're anything like me, it won't be the same w/minimal drop. A 4/6 drop is a great compromise for everyday driving w/o worry (you can even get a little more a-arm clearance if the x-member is notched).
11-06-2010, 04:36 PM | #508 |
Re: my 80 build
looks good man!
can you put up some pics of it now/as a roller, especailly of the a-arms and crossmember (mostly front end stuff) im putting mine back together and need some pics for reference, thanks!
1979 c30 3+3 dually 1946 GMC |
11-06-2010, 06:31 PM | #509 |
6.0 powered square
Re: my 80 build
I did it its a roller took a little wile since every bolt and nut had messed up threads, luckily I had the tap and die I needed, and all the red and rusted parts will be swapped from my truck if any one wonders
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-06-2010 at 06:33 PM. |
11-06-2010, 06:36 PM | #510 | |
6.0 powered square
Re: my 80 build
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-06-2010 at 06:36 PM. |
11-08-2010, 01:27 AM | #511 |
Re: my 80 build
youre the man, thanks!
11-10-2010, 01:14 AM | #512 |
6.0 powered square
Re: my 80 build
11-10-2010, 01:24 AM | #513 |
6.0 powered square
Re: my 80 build
today I cleaned up and painted the brake lines aluminum but I think I'm going replace them with new ss lines, and may I have decided on a cam a texas speed 228
11-10-2010, 01:34 AM | #514 |
Re: my 80 build
looks good
11-10-2010, 11:02 PM | #515 |
6.0 powered square
Re: my 80 build
thanks
I pick up some new grade 8 hardware for the motor mounts that mount to the frame and new replacement motor mounts but I believe I'll sent them back because I bet they what last to many 3000rpm launches
11-11-2010, 10:21 PM | #516 |
6.0 powered square
Re: my 80 build
well I just ordered brand new stainless steel brake line kit and new clips, and might be ordering the cam, push rods, and springs tonight
11-12-2010, 02:13 AM | #517 |
6.0 powered square
Re: my 80 build
felpro top end gasket kit and timing chain gasket kit
leaf springs bushings I got the motor mounts split apart now I need to blast and paint them and install some poly mounts new front shock mounts
11-12-2010, 02:17 AM | #518 |
6.0 powered square
Re: my 80 build
I painted the factory brakes line silver but will be replaced by stainless steel lines
I'm replacing any bolt that deals with the motor to the frame with new grade 8 hardware
11-12-2010, 10:10 AM | #519 |
Re: my 80 build
looks great Aaron!! your going to love the ls swap. i love how your going back through and just replacing everything. this is going to be the build to watch!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
11-12-2010, 12:17 PM | #520 |
Re: my 80 build
I agree man. Now is the perfect time to pay attention to the little things.
11-12-2010, 08:03 PM | #521 |
6.0 powered square
Re: my 80 build
I want every thing to be right the first time around, its going to take a little more money than I wanted to spend but at least I only have to do it once.
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 11-12-2010 at 08:07 PM. |
11-12-2010, 08:37 PM | #522 |
6.0 powered square
Re: my 80 build
well I bought the cam http://www.texas-speed.com/shop/item...d=167&catid=44
11-13-2010, 03:16 PM | #523 |
6.0 powered square
Re: my 80 build
Now I need to get a ls2 timing chain there built better and stronger, h3 oil pan for extra clearance, corvette fuel filter and braided fuel hoses and fitting
11-13-2010, 08:46 PM | #524 | |
Badass
Re: my 80 build
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
11-13-2010, 08:51 PM | #525 |
6.0 powered square
Re: my 80 build
choppy
this what it sounds like in 6.0 gto
