Old 02-27-2009, 09:20 PM   #1
Musclerodz
Re: Our '66 Short Fleet Build
Originally Posted by joe231 View Post
Thanks Alan, i tried to get info from the place I got the paint.....they are an auto supply and don't seem to know much......I asked what I could use to thin it.....he told me the stuff that comes with it
Thanks Mike. I got the MSDS and instructions, it said 1.4-1.6mm and 40-60 psi....the one thing we missed was that with the DP401LF activator you are supposed to mix it then wait 30 minutes before spraying, oops. i got another quart of the DP90LF and this time got the DP402LF activator instead, no wait with it.
I live on the east-side of Norman, but the cab is in Tuttle at Scott's shop
you think it would work better with the suggested 1.4-1.6mm tip? it didn't hardly want to flow through the 2.0mm, but maybe that was due to us not waiting 30 min to spray it....
You should not need a 2.0 tip and waiting 30 minutes won't change the viscosity that much. Are you sure there is not a reducer that also goes with it? 1.4-1.6 tip should be plenty. Are you going to shoot the cab again this weekend or when are you going to be there? I don't mind coming over, my work shop is in Washington, just south of both locations. Just let me know.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 02-27-2009, 09:29 PM   #2
joe231
joe231's Avatar
yeah, I've looked and PPG says not to reduce it, it will lower the corrosion protection.
I still have to talk to Scott, but hopefully he will be available tomorrow or Sunday. I will let you know when I find out.
I assume you have used the dupont metal conditioner....does it have phosphoric acid in it?
CHEVY ONLY
Old 02-27-2009, 09:51 PM   #3
scotts62
One day...
scotts62's Avatar
Oh heck no!
So was it the wrong stuff? That's the reason why we used the 2.0 gun because it was so thick otherwise we would have used the 1.4..
Scott
93 crew cab build
Project 62
Old 02-27-2009, 10:03 PM   #4
Musclerodz
All the metal conditioners/etch primers have phosphoric in them. I am not up on PPG products anymore, but if they say 1.4-1.6 tip, then it should not require a 2.0 tip to shoot. Did you ask the retailer about it?
Mike Redpath
Old 02-27-2009, 11:17 PM   #5
joe231
joe231's Avatar
I got it at Palace auto supply.....they either don't have a clue or don't care to help......I'm kicking myself for not biting the bullet and buying the dupont gallon......now since i have started with the DP, think I need to finish with it. found more info saying you can mix 2 parts primer, 1 part activator, and 1/2 part reducer to make it a sealer.....but if it is being applied as primer, no reducer..... also found lots info that we didn't have to do the metal cleaner/conditioner, with the blast, could have just wiped it down with wax and grease remover then shot the dp on it
I will be using dupont on the rest of the body and maybe the frame.....just due to the customer service
CHEVY ONLY
Old 02-27-2009, 11:27 PM   #6
4dranch
Shloooooong bed member #2
4dranch's Avatar
Joe if anybody can figure this out and keep on chuggin, it's you. hope everything works out for. you only got two months before I take some good pictures of you guys cruzin across the bridge into Memphis..
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 02-27-2009, 11:32 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
The last mix you mentioned was roughly how the primer was mixed that my friend and I did on my truck. I mixed it 2:1:1.
Im no expert by any means, but Im thinking it would be reduced for sure.
Is it a high build product??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-27-2009, 11:29 PM   #8
joe231
joe231's Avatar
CHEVY ONLY
Old 02-27-2009, 11:34 PM   #9
jason65
Registerd User
jason65's Avatar
When are we gonna get some pics? Any action shots?
jason65 is offline   Reply With Quote
Old 02-27-2009, 11:37 PM   #10
protrash64
protrash64's Avatar
Yeah...whats up? Its probably all going to be a re-creation, just like watching Cops or something.
Old 02-27-2009, 11:36 PM   #11
joe231
joe231's Avatar
no it is a 1.5mil protective, moisture proof primer, then after it you can use filler and high build/sandable.......that requires no reducer according to the PPG site.
what primer is on your truck?
Jason, i'm working on it now
CHEVY ONLY
Old 02-27-2009, 11:44 PM   #12
joe231
joe231's Avatar
roflmao!!!
CHEVY ONLY
Old 02-27-2009, 11:50 PM   #13
protrash64
protrash64's Avatar
Joe, it was 5 years ago. I know it was a budget primer. I didnt buy it because at the time there were 3 of us doing trucks and we kinda all bought different stuff/ materials and I ended up using 1/2gal of primer that someone else bought as a trade for some stuff I had at the time.
You will eventually get it straight.
Old 02-28-2009, 12:53 PM   #14
TimE
Hey Y'all!!
TimE's Avatar
And yet another 1 off "Joe Custom" cab tilt. What's the details on it?
Hurry up and figure all of this paint stuff out. You and Scott won't have much time to get my cab done. I'm only gonna be there a week!
I'm not even gonna comment on the pic of Scott and his response...
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-28-2009, 01:00 PM   #15
joe231
joe231's Avatar
I found some curved arms off of some old wheelchair lifts in our shop with a nice 90* radius, welded some smaller tube to the dolly and drilled holes. I just have it on the rear now, but I'm going to add the smaller tube to all 4 sides so I can tilt which ever direction...I have to give credit to Rokcrln, if i hadn't seen this who knows if the gears would have started turning.....
one week is lots of time, just pay my weekly salary and I will dedicate the whole time to your cab
CHEVY ONLY
Old 02-28-2009, 01:03 PM   #16
TimE
Hey Y'all!!
TimE's Avatar
I was thinking more like 20 bucks and a "Thank you"...
Old 02-27-2009, 11:59 PM   #17
joe231
joe231's Avatar
how it is now.....it isn't horrible, I think another coat and it will be good.
got a couple runs to sand first......
anyone seen these before?? thinking maybe a PO did it?? It did have seam sealer in the holes
CHEVY ONLY
Old 02-28-2009, 12:02 AM   #18
jason65
Registerd User
jason65's Avatar
Ask and you shall recive. good progress man. Good to see it.
Old 02-28-2009, 12:09 AM   #19
4dranch
4dranch's Avatar
Looks nice Joe,
A whole lot different than the cab in your avatar huh.
David,
Daughters 66 truck:
Old 02-28-2009, 01:24 AM   #20
Captainfab
60-66 Nut
I don't remember the time frame exactly, but if you wait too long between coats, you should sand the whole area before coating again. I have the info sheet at the shop....I can look for you tomorrow if that will help.
Old 02-28-2009, 09:26 AM   #21
joe231
joe231's Avatar
Originally Posted by Musclerodz View Post
Palace makes a better auto parts store than a paint supplier. I go there to get AC Delco parts as it is cheaper through them than from the dealer even with shop discount sometimes. There are some things I can show you that you don't have to buy all the expensive stuff to get a nice job. Sometimes though, it pays to get the good stuff up front. Call me anytime, no sense learning the hard way when I am a phone call or short drive away.
cool Mike!
Thanks, I appreciate it.
yeah it is a 7 day window.....we did the first coat last Wednesday.....should be good to go
CHEVY ONLY
Old 02-28-2009, 10:27 AM   #22
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looking nice Joe....Cool to have members all helping out !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 02-28-2009, 11:52 AM   #23
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Like I said before, I'm not an experienced painter and 7 days seems like a big window. Was that on a can or MSDS or just hearsay? I can't read the fine print on the side of the can any more. I'm in denial that I need reading glasses.
Alan's Classic is offline   Reply With Quote
Old 02-28-2009, 12:09 AM   #24
joe231
joe231's Avatar
I aim to please, or am pleased to aim, or sumtin......
CHEVY ONLY
Old 02-28-2009, 12:12 AM   #25
joe231
joe231's Avatar
ain't it, it was cool to see it totally bare.......kinda like the truck is getting to start over, fresh new start......a "i'm not tearing up, i have something in my eyes" kinda moment
CHEVY ONLY
