#1 | |
Re: Tbi swap build thread
Your 1 ton probably has 14 bolt FF with 4.11 gears. Depending on tire size your highway engine RPM is between 2500 and 3000 RPM. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Hey RF when holding the injector and looking at the top and you have the long part # then you have the small # what does the small # mean? I have two injectors given to me and they both have GM5235279*RPD but the small # read D017 GM* the other Looks like N307 GM*
#3 | |
5235279 is a 61 lb-hr (@13 PSI) injector, RPD stands for Rochester Products Division. //RF
#4 | |
#5 | |
2) The reason why you need to floor gas pedal on start up is that remaining 5.7 L injector is dumping too much fuel. You need to have both injectors to be RPD 5235206 (aka 55 lb-hr). Even with both injectors being 55 lb-hr your tiny 283 will run rich on start up! Having O2 will help ECM to lean out fuel mixture. Additional EPROM changes would be required (later on) to optimize VE table. 3) You need to verify that your idle air control motor is working. The way you do this is by inserting a jumper wire between pins A & B of ALDL connector (do you know what it looks like?). ECM will command IAC into fully closed position. Do not start engine - just turn ignition into run - you should hear clicking noise coming from TB. Clicking noise is from IAC motor jamming pentacle head - keeping idle air passage closed. Remove harness connector from IAC (4-pin square), turn off ignition. With Ignition off reconnect IAC motor connector. Now ECM knows fully closed position. This way it will be able to control idle speed by controlling amount of idle air. //RF
So If I get a set of injectors from a 4.3L I should be set as for gas amount?
#7 | |
The 4.3L V6 injectors are only rated for 45 lb-hr and can support 170 vs. 208HP offered by 55 lb-hr units. Another reason why you want to use 55 lb-hr injectors is that BPC calibration constant used in 305 calibrations is 132 (please post your ECM service number and broadcast code). When BPC constant is calculated for 283 with 55 lb-Hr injectors BPC is 122. 10 points is not bad (it is not great either and eventually you would want to have a custom EPROM burned). If you use 45 lb-Hr injectors for your 283 then BPC constant is 149 - 25 points of. With 45's you'll always start on lean side and with 55's you'll be slightly rich. Stock 283 heads (we are talking 40+ year old designs) are not known for high efficiency combustion chambers and like to run slightly on a rich side anyway. Why is it important? ECM has no idea if injectors have been changed to a different size or engine displacement is different. It calculates amount of fuel based on EPROM stored values. O2 provides some degree of trim over stored baseline line values. Change one or more variables - the amount of fuel commanded will be of from what engine needs for best performance. All TBI injector ratings are baselined at 13 PSI. //RF
RF I am not finding any info on this question. I have a chance to pick up a 1970 350 4 bolt main with 17000 on rebuild.
The question is could I pull the 70's intake off and and put the TBI intake on or could I just put the tbi on the 70's intake with the adapter ? |
O one other question other then the intake what is the deference from a tbi to a LT1 engine could I swap out the intake?
#10 | |||
Slots go on anything!
1974 Jimmy- 5.3/4L80e/NP241 |
#11 | |
Really ? The 89 LT1 out of a Iroc-z that I have setting in my garage has the same dist as the TBI set up. O thanks |
#12 | |
//RF
#13 |
The original engine in your '89 IROC would be an L98, if it is a 5.7. That is gen 1 SBC, with TPI (Tuned Port Injection). Physically similar to doing a TBI swap, but you will have to pay more attention to the fuel system. TPI will want 43-46 PSI, compared to 13 or so fir TBI.
#14 |
Hi Guys,
Just a quick update - I found a DRAC for $20! Actually, I found two - I bought one for spare since they seem to be getting hard to find. Half price of the Dakota Digital solution and I have a spare. I love hunting parts, finding/recycling them, and saving money! We all win! Now to get serious about hunting up a '91 Suburban speedo . . . |
#15 | |
Still plays with trucks
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#16 |
I've ran across a few 90/91 Suburban speedos online and many say "blue" or "blue/silver". do I take it that a blue background with silver pointer / numbers was an option? I've tried to look up what the speedo options were online, as well as tried to find a picture of a "blue" burban speedo but I can't find any info at all on 'em - can you enlighten me?
Thanks! Steve |
#17 | |
#18 |
Should the A6 pin have power under cranking?
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
#19 |
If you have 1227747 ECM Pin A6, Ignition-ECM Fuse (Pink/Black wire) must have 12.0 to 13.8 Vdc when ignition is on. Failure to have 12.0 V during cranking will shutdown ECM and injectors will never fire. Not good at all.
//RF
#20 |
Got it thanks!Didn't have power under cranking.
#21 |
Hi Guys,
I'm hoping to start on this project the first part of June. Until then I've been gathering parts - got the DRAC problem solved by a couple of fellow forum members (thanks guys!) and I picked up an electric speedo that's supposed to be off of a '91 Suburban and it arrived today. Got a couple hundred thousand on it but that's OK, I don't care what the mileage displayed is as long as the speed displays correctly. The trip metter even still has the stem and it reset the meter back to zero so I'm assuming it works. I wish I could find the camera but alas my wife and daughter are gone and I can't find it (I can't find stuff in the fridge either!). It has a cut mylar ribbon cable going to a connector that slides onto the speedo pcb. The ribbon cable and pcb have three leads. I'm assuming soldering to that mylar ribbon cable isn't going to happen so using the connector probably isn't an option (though I haven't taken it apart to see if it is or not yet). I'm sure that's no mountain to climb though, one could probably just solder leads onto the pcb traces where the connector slid on. Do I take it the three leads are power, ground and signal? Can anyone clue me in on which is which? Thanks! Steve |
#22 |
Found the camera!
Here's the electrical connector I'm talking about. It appears in this pic only two leads have traces on the pcb but the third trace is on the other side of the pcb. /Steve |
#23 | |
If there are any electrolytic caps - find negative terminal which are usually tied to chassis ground. Use DVM to find which of the three pins (if any) are ground connected by checking continuity from cap neg terminal. //RF
#24 |
Ok had a few minutes . . .
I held the speedo in it's normal position and then rotated it so I could see the back. When I do that the connector is on my left side and the three connections are as follows: Pin 1 ===> Pin 2 ===> <gap> Pin 3 ===> When viewing the back of the speedo there is a 16 pin dip in the upper right hand side of the pcb with a paper tag and a part number printed on it. I didn't get the part # written down, though I thought I did. It has pins 1 & 5 tied together but where it goes from there I lose as it as the tracegpes under the chip. There is another 16 pin dip chip below that, It's a Texas Instruments chip and has the following printed on it: <TI symbol> 022 CB AC SPARK 980 6535H There is an 8 pin dip chip in the lower right and on top of it it says: 1681B CS9035H Pins 5 & 8 of it are tied together. They run to a 15K resistor and it runs to Pin 1 of the connector Pin 2 of the connector indeed runs to the negative side of a polarized cap. Pin 3 of the connector runs to a diode oriented like this: -->l-- and then a resistor and then I lost it. Sooo, we have: Pin 1 ===> 15k resistor, 8 pin dip pins 5 & 8 Pin 2 ===> negative side of polarized capacitor <gap> Pin 3 ===> diode -->l-- , a resistor and more. I tried looking the chip part numbers up to see if I could get a clue as to what they do but I didn't have any luck. The 16pin dip in the upper right with the paper printed part # seems to have a crystal hooked to a couple pins if that helps. Thanks! Steve |
#25 |
Steve
AC-Delco (GM) is notorious for using custom part numbers of commonly available parts. When you buy a million of anything in electronic industry putting a custom part number is an unquestionable ritual. Makes reverse engineering just a little bit more difficult. Let me take a look at my 94 FSM see if it offers anything worth of note worthy. //RF
