Old 02-03-2014, 01:43 PM   #501
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Project: "Full Metal Yellow Jacket" Build Thread
Grease fitting..
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-03-2014, 08:17 PM   #502
Ta2Don
Ta2Don's Avatar
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 02-10-2014, 06:19 PM   #503
1Bad62Pro/Street
Just lil' more adjustments on the doors..
We got some snow coming so.... lil' at a time!
Old 02-11-2014, 11:09 AM   #504
Ta2Don
Ta2Don's Avatar
Updates=Progress!!!
Stay Warm!!!
DON
Proverbs 27:17
Old 02-11-2014, 11:56 AM   #505
1Bad62Pro/Street
Talking Re: Project: "Full Metal Yellow Jacket" Build Thread
http://www.wbtv.com/clip/9828355/kel...esday-forecast
<script type='text/javascript' src='http://WBTV.images.worldnow.com/interface/js/WNVideo.js?rnd=579438;hostDomain=www.wbtv.com;playerWidth=640;playerHeight=358;isShowIcon=true;clipI d=9828355;flvUri=;partnerclipid=;adTag=Weather;advertisingZone=;enableAds=true;landingPage=;islandin gPageoverride=false;playerType=STANDARD_EMBEDDEDscript;controlsType=overlay'></script><a href="http://www.wbtv.com" title="WBTV 3 News, Weather, Sports, and Traffic for Charlotte, NC">WBTV 3 News, Weather, Sports, and Traffic for Charlotte, NC</a>
Old 02-11-2014, 07:14 PM   #506
1Bad62Pro/Street
JEGS Performance Products#555-60300
TH350 Performance Transmission
Chevy with Short 6" Tailshaft
http://www.jegs.com/i/JEGS-Performan...rentProductId=
http://www.jegs.com/jegs/555-60300_trans_specs.html
JEGS Performance Products#555-60400
GM TH350/TH400 12" Torque Converter
10.75" Bolt Circle
Stall Speed: 2300-2700 RPM
http://www.jegs.com/i/JEGS+Performan...60400/10002/-1
JEGS Performance Products#555-28071
Quick Shift Automatic Transmission Fluid
2 gallons
http://www.jegs.com/i/JEGS-Performan...28071/10002/-1
Subtotal:$877.96
Old 02-11-2014, 07:29 PM   #507
1Bad62Pro/Street
Champion All Aluminum Radiator
3-Row Core
Cools up to 650hp
$209.98
Radiators Dimensions:
Total: 25” tall (with cap) x 26.6" wide (including brackets)
Core: 18.88" tall x 21.75" wide x 2" thick
Inlet: 1.5" center
Outlet: 1.75" passenger side
Tanks: 2.5" thick
Tubes: 0.63" thick
Bracket Mounted
Radiator Cap Included
Transmission Cooler Included
Radiator Polishing (add 2-3 more business days to shipping) (+$65.00)
http://www.championradiators.com/Che...-row-1960-1962
Old 02-14-2014, 04:25 PM   #508
1Bad62Pro/Street
10.75" Bolt Circle
2 gallons
Subtotal:$877.96
It appears that I have a 9" Tail Shaft. I forgot
The TH350 I have is out of a 69-70 Chevrolet C-10 CST Camper Special Truck.
Old 02-17-2014, 07:39 PM   #509
1Bad62Pro/Street
Things I gotta get. Oh yea.... rebuilding my transmission.
Floor Jack Cross Beam
Replace the saddle on your floor jack with this floor jack cross beam to balance and stabilize vehicles. Distributes weight to prevent damage to undercarriage. Our floor jack cross beam works with most floor jacks. The beam member adjusts from 28 in. to 37 in. wide. Adjustable pads on each end of the floor jack cross beam provide additional lift.
For use with most Pittsburgh steel floor jacks and most floor jacks with a removeable saddle
Provides longer contact point for increased stability and distributes weight to prevent undercarriage damage
Can be used to lift entire side, front or rear of vehicle
Adjusts from 28 in. to 37 in. wide
5" x 5" rubberized lifting plates adjust for additional height
Heavy duty welded steel construction
Includes 9" safety chain
http://www.harborfreight.com/floor-j...obile_redirect
450 Lb. Capacity Low Lift Transmission Jack
Perfect for removing transmissions on smaller vehicles, this low lift transmission jack works under vehicles on jack stands. Heavy duty steel construction with ball bearing easy-roll casters. The saddle tilts for easy positing of your transmission during repair, making this transmission jack versatile and easy to use.
Saddle tilts for easy positioning
Large 13" x 6-7/8" contoured cradle
Non-marring swivel casters
43" L nylon safety strap
http://www.harborfreight.com/interes...obile_redirect
Transmission Stop-Off Tool
Use this tool to plug the transmission shaft opening when removing the drive shaft, repairing the U-joints or performing general transmission service. This stop off tool eliminates the need to drain transmission fluid, reducing fluid waste on most rear-wheel drive vehicles. This is a great transmission service stop off tool for do-it-yourselfers and professional auto mechicanics.
Fits most domestic rear-wheel drive vehicles
Suitable for the home garage and professional auto shop
Reduces fluid waste
http://www.harborfreight.com/transmi...obile_redirect
1/2 In. Professional Air Impact Wrench
This professional class pneumatic impact wrench delivers more power with better weight distribution, lighter materials and a more compact housing. Premium grade components with close tolerances give this tool a longer lifespan than conventional air wrenches.And with less vibration, you can work longer with this durable impact wrench than the competition.
Precision machined to master-mechanic standards
Most powerful wrench in its class
Variable speed reversible
Handle-vented to direct exhaust away from user
Twin-hammer delivers more torque to the anvil
http://www.harborfreight.com/12-in-p...obile_redirect
5 Piece Brass Industrial/Milton Quick Connect Starter Set
These quick couplers are constructed of durable brass and have fittings designed to rotate to prevent a twisted air hose. The set includes a female coupler, a female connecter and three male connectors to choose from making this a great set of industrial quick couplers to save you time changing air tools while working in your workshop or garage.
Kit includes female coupler, (3) male plugs, (1) female plug
Industrial/Milton style interchange
1/4 in. NPT
http://www.harborfreight.com/5-Piece...obile_redirect
Old 02-17-2014, 08:10 PM   #510
1Bad62Pro/Street
And this...
Milodon One-Piece Oil Pan Gaskets 41000
Simple logic says that one of the best ways to avoid oil pan leaks is to make the pan gasket one piece. That's the philosophy behind Milodon's one-piece pan gaskets. In particular, they end leaks at the corners, where multi-piece gaskets often fall down on the job. They're molded in one continuous piece of rubber, with steel inserts around each bolt hole, so that the bolts can be securely tightened but not over-tightened. Because of this construction, these gaskets are reusable.
http://www.summitracing.com/parts/mil-41000
Old 02-17-2014, 09:40 PM   #511
1Bad62Pro/Street
And I gotta get some oil as well..
Joe Gibbs Driven HR2 10W-30 High Zinc Petroleum Hot Rod Oil
Designed Specifically For Hot Rods & Classic Vehicles
Great for small block and crate engines. Features storage protection additives that guard against rust and corrosion during winter storage.
10W Multi-grade formula provides excellent start-up protection for flat tappet, overhead and roller cam engines. No ZDDP or additives required. Viscosity typical of 10W-30. Formerly referred to as HR2.
http://www.drivenracingoil.com/dro/h...al-10w-30html/
Old 02-18-2014, 09:57 AM   #512
Ta2Don
Ta2Don's Avatar
Thanks for posting the above links… Especially the Floor Jack Cross Beam…
I see one of those arriving in my Shed in the near future...
DON
Proverbs 27:17
Old 02-18-2014, 09:10 PM   #513
1Bad62Pro/Street
Thumbs up Re: Project: "Full Metal Yellow Jacket" Build Thread
No problem Bud!
Old 02-18-2014, 09:25 PM   #514
1Bad62Pro/Street
A Poor Attempt of an Under Body View.
Drained and took the deep trans pan off.
Put the old one back off for now.
Drained the oil pan and filter.
Thought I take a short video while I laid on the floor.
As you can see I need a new radiator.
Old 02-18-2014, 09:40 PM   #515
Ta2Don
Ta2Don's Avatar
Sweet Video… Enjoyed the jam too…
DON
Proverbs 27:17
Old 02-18-2014, 10:09 PM   #516
1Bad62Pro/Street
Enjoying my new Floor Jack! Awesome for Low Pro's!
Old 02-18-2014, 10:19 PM   #517
1Bad62Pro/Street
Gear Headz love tools!
Old 02-18-2014, 10:28 PM   #518
1Bad62Pro/Street
Trying to get the passenger side square. The cab was hit slightly once.
Old 02-18-2014, 11:08 PM   #519
1Bad62Pro/Street
Prolong Nash Metropolitan Pro/Street
Old 03-10-2014, 11:59 AM   #520
1Bad62Pro/Street
Finally painted my oil pan.
Orange…
Old 03-10-2014, 12:06 PM   #521
1Bad62Pro/Street
Now black.
VHT Epoxy Paint
Old 03-10-2014, 12:42 PM   #522
1963c-10
1963c-10's Avatar
Nice job. Im glad our weather is finally changing. Im through with our winter weather this year.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-10-2014, 12:51 PM   #523
Ta2Don
Ta2Don's Avatar
Very Nice!
Almost forgot… Cross Beam for the floor jack arrived this week!
DON
Proverbs 27:17
Old 03-11-2014, 04:29 PM   #524
1Bad62Pro/Street
I know right! Just got over a bad cold. Weather keeps going warm to cold!
Very Nice!
I'm waiting Thursday for mine.
Old 03-11-2014, 04:35 PM   #525
1Bad62Pro/Street
Getting the interior redone on dads 1969 AMC Rambler American Pro/Street.
(( 1969 AMC Rambler American Pro/Street - Tuning The Modified SBC 283 HO - YouTube ))
