Closed Thread
Old 12-17-2009, 12:21 AM   #501
menace121978
menace121978's Avatar
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
i dont know buddy... 79gmc5.3 is going to take a stock compressor and lines over to brp and have them test fit it. i'm hoping it works... if not, the best solution is the conversion plates and high mount a/c bracket and compressor. that is maybe another option though(tbss compressor)
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline
Old 12-17-2009, 10:00 AM   #502
Jonboy
Slots go on anything!
I thought Bob looked at a TB compressor, and it was a no go? IIRC, it was close, but the frame still needed to be notched a little bit for clearance, and it was about an inch from the idler arm. I thought that was why he decided to go with the high mount compressor.
Jonboy is offline
Old 12-17-2009, 01:35 PM   #503
JohnC
JohnC's Avatar
Yeah I think you are correct. Someone did look into the TBSS compressor, but don't remember what the issue was.
JohnC is offline
Old 12-17-2009, 05:42 PM   #504
rongstad
Future: 86 on GenIV power!
If I recall correctly; not able to find the correct 90 degree output and/or adaptor. I will look at my bookmarks once I get home.
Dennis;
Codys87 has the BRP engine mounts and it appears he is using a 96 compressor.
Originally Posted by Codys87 View Post
Heres the pics of my a/c compressor, but I haven't gotten the adapter yet. Honestly didn't know if it would work until I found your thread and found the link to the adapters on here. I have about 2 inches of clearance from the a/c compressor to the frame so I'm not sure why it wouldn't work. I am using the brp motor mount conversion kit though. But it looks like we both may have about the same clearance.
Let me know what you think. I was going to order the adapter tonight.
rongstad is offline
Old 12-17-2009, 07:47 PM   #505
menace121978
rongstad, thanks alot for posting those and checking your book marks. i'm going to pm Cody and see what the deal is...
"Dennis the Menace"
Old 12-21-2009, 06:40 PM   #506
78-5.3
78-5.3's Avatar
very nice build!!!!
78-5.3 is offline
Old 12-21-2009, 06:55 PM   #507
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Hey slacker, what's up? No posts on this thread from you in like, 4 days!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline
Old 12-21-2009, 07:10 PM   #508
menace121978
work... PRIME RIB TIME!!
and actually i'm waiting to hear from a fellow board member if the BRP mounts are going to work like i had hoped i do need to take a few pics of the fuel system parts i got last week.
quick question buddy, can you shoot me a link to the fuel lines and adaptors you used and how you ran the driverside tank fuel line? did you use the factory steel fuel line that goes across the crossmember?
"Dennis the Menace"
Old 12-21-2009, 07:16 PM   #509
glock35ipsc
I have my receipts and notes at home, I'll look that stuff up tonight. Not sure if I have pics of the left to right lines or not, but yes, I did use the OEM steel lines that run across that crossmember right behind the cab. I just replaced the fuel lines that connect from the SU to the lines with the same Summit high PSI hose I used throughout.
Bob
Old 12-21-2009, 09:54 PM   #510
rongstad
Bob hope you dont mind.....
C&P
You will need to swap the sending units to the 87 models. The 87's had TBI and used in-tank pumps. The sending unit part numbers are:
* Dorman p/n 692027 for the driver side, $94 at rockauto.com
* Dorman p/n 692044 for the passenger side, $101 at rockauto.com
I used ACDelco fuel pumps:
* AC Delco EP381 in-tank pumps. $69 at getgmparts.com
And a high pressure tank switch valve:
* Pollak high psi tank selector valve. $83 at JC Whitney, p/n ZX812705U
And be sure to use fuel injection hose, not regular fuel hose. Also use good fuel injection clamps, not the typical worm gear clamps.
I ordered FI rated 5/16" hose for the return lines, and Summit's -6 hose for the pressure side. FI rated clamps on all the tank and valve connections, and Summit's Snap-Tite AN fittings on the Vette filter/regulator and fuel rail.
This is the hose:
Summit SUM-220785 - Summit Racing® Twist-Tite Hose - Overview - SummitRacing.com
rongstad is offline
Old 12-21-2009, 10:28 PM   #511
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Hey Dennis I still have not had a chance to get to BRP but I will, don't give up on me. With Christmas and work it has been tough. I have been pming Bob and he did not think they would work. I also talked to a friend who is a stress engineer where I work and he did not think knocking the fram in that area would be a problem.
Russell
What ever the mind of man can conceive......... he can achieve!
My built thread http://67-72chevytrucks.com/vboard/s...d.php?t=375914
1979 GMC Sierra 6.0 L 4L60E
1995 Mustang GT 347
79gmc5.3 is offline
Old 12-22-2009, 10:27 AM   #512
glock35ipsc
More part #'s:
Dorman 800-120: 5/16" adapter for the inlet end of the filter (return line) (need 1)
Dorman 800-121: 3/8" adapter for the inlet end of the filter (feed line) (need 1)
Dorman 800-155: 3/8'' x 12'' Double Bead Line, cut in half and use one on the outlet end of the filter (need 1)
RUS-640850: 3/8" Fuel rail fitting adapter (need 1)
* RUS-660350: -6AN male to -6 AN male, use at the outlet end of the filter (need 1)
* RUS-660650: -6AN tube sleeve (need 1)
* RUS-660570: -6AN tube nut (need 1)
SUM-220701: -6AN straight hose end, barbed for Twist-Tite hose (need 2)
SUM-220785: -6AN Twist-Tite rubber hose, 20' length (won't need this much though)
IDE52F15: 5/16" FI hose clamps
IDE52F16: 3/8" FI hose clamps
STIFI-503: 5/16" FI hose, 10' length (for return lines)
The Dorman numbers I got from Rock Auto. In a pinch, AutoZone and the like usually stock part #'s 800-120 and 800-121, but I don't know the price. The Russell and Summit (RUS, SUM) numbers are from Summit Racing. The FI hose clamps and 5/16" FI hose I got from www.autobarn.net I did also find the hose clamps locally, if you have someone that can get Auveco parts, those part numbers are 15861 (5/16") and 15862 (3/8").
(*) These will get used on the double bead line, as well as the trans cooler lines if you need to go from steel line to SS hose. The tube nut gets slipped on, then the tube sleeve, then a 37° flare put on the line. The the RUS-660350 double -6AN male threads to the nut, then the SUM-220701 swivel end on the hose threads onto that.
Bob
Old 12-22-2009, 10:59 AM   #513
menace121978
C&P
This is the hose:
thanks man... i have everything except the fittings and hoses.
Russell
i havent given up buddy... this time of year somethings come up and take priority
Originally Posted by glock35ipsc View Post
More part #'s:
and thank you sir!! thats what i needed... going to order this next
"Dennis the Menace"
Old 12-22-2009, 11:04 PM   #514
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Dennis, I am glad to see you are keeping things coming. That has been the hard thing for me since getting my truck. The delays between when I am able to get certain parts is why I don't have a build thread. (I know go ahead and take you shot). But I am really enjoying following this with you. Keep going! Keep going! Keep going!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline
Old 12-23-2009, 08:23 AM   #515
menace121978
little by little man! i will finish her... next month will be the 1 year anniversary and i'm farther along than i had hoped. its easier to buy the little nickel and dime stuff here and there rather than huge chunks all at once.(for me anyways) i figure i got only 1 large chunk left now. it has def. been fun for me too. mark my words... you WILL see this truck in person man.
speaking of build threads...
new job, new thread....???!!
"Dennis the Menace"
Old 12-23-2009, 02:10 PM   #516
79gmc5.3
6.0L power.........
79gmc5.3's Avatar
Dennis: Please help me to be as patience as you are. I see all the things I need and know I don't have the money to go buy them, and it is driving me CRAZY!!!! OK OK i'm calm now. Please don't start a new thread I can't keep up as it is
1995 Mustang GT 347
79gmc5.3 is offline
Old 12-23-2009, 07:25 PM   #517
menace121978
the new job/thread thing was for Gerald. He NEEDS to start a build thread with his plans at least
patience... its hard man. just imagine if you had the money and still had to hold back i'd rather hold back than have to hear it. Amy is already talking about going back to our original agreement of "a dollar for a dollar" that would be rough... that would mean everything i buy is doubled. We did that with the parts on the GOAT.
"Dennis the Menace"
Old 12-24-2009, 12:37 AM   #518
Driveway Dreams
I have car A.D.D.
Wow, she must have got some cool...Shoes? Purses? Clothes? Whatever she enjoys spending money on. Because I am sure that you don't just have "a couple bucks" into that one.
And about seeing your truck in person...I am sure that will happen. Here or there, it will happen.
Maybe I will start a build thread when time allows me to actually sit on here and type it all out one night. That might be fun and keep me motivated to do some more when I can.
-Gerald
Old 12-24-2009, 09:24 AM   #519
JohnC
JohnC's Avatar
That's why I started my build thread Gerald. Didn't really have much to show, but everyone wanted me to start one. Now it's just a place to hang out and bs, and every once in a while some of my progress get's thrown in.
JohnC is offline
Old 12-24-2009, 10:19 AM   #520
tvblazer78
Low & Fast!
tvblazer78's Avatar
Man that would suck, I just sneek parts in all the time. If my wife only new. But she is getting a new house so this will hold her over for a little bit.
tvblazer78 is offline
Old 12-24-2009, 10:23 AM   #521
Jonboy
Me too. Stuff just shows up here at work all the time.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline
Old 12-26-2009, 12:01 AM   #522
Fer79
Fer79's Avatar
very very nice project... congrats...
Fer79 is offline
Old 12-26-2009, 12:43 PM   #523
ryguythayer
ryguythayer's Avatar
hello i've been looking and reading you whole thread and ur truck is so nasty i got alot ot tips from here just wanted to say ur truck is badass and i cant wait to see her all done looks badass!!!!
ryguythayer is offline
Old 12-26-2009, 07:57 PM   #524
menace121978
right on thanks guys!!
"Dennis the Menace"
Old 12-30-2009, 08:11 AM   #525
menace121978
quick picture update... finally got the stones to go out and snap a few pics of the fuel system parts from 2 weeks ago!
"Dennis the Menace"
Closed Thread
