Old 06-03-2015, 10:44 PM   #501
robgmaddux
Junior Member
robgmaddux's Avatar
Re: LS swappers, post up your pics!!
My 1972 k20 ls swap.
My build thread! http://67-72chevytrucks.com/vboard/s...d.php?t=665907
robgmaddux is offline   Reply With Quote
Old 06-03-2015, 11:05 PM   #502
6L72C10
6L72C10's Avatar
is that air intake system a kit?
I was told that Spectre made a ls conversion kit, is that what you used?
I am running a 2003 6.0L with the Edelbrock intake and I am trying to find a kit that will bolt up to it. anyone have any ideas?
Thank you
6L72C10 is offline   Reply With Quote
Old 06-03-2015, 11:15 PM   #503
robgmaddux
Junior Member
robgmaddux's Avatar
Thank you
Yes it's a spectra kit for a 2000 silverado.
Old 06-03-2015, 11:57 PM   #504
mongocanfly
mongocanfly's Avatar
72c10..on mine I just bought the spectre parts I needed off ebay,, that way I only bought the pieces I needed.got the 4" tube off there as well.
Old 06-04-2015, 12:01 AM   #505
robgmaddux
Junior Member
robgmaddux's Avatar
What did you use for a battery box?
Old 06-04-2015, 12:18 AM   #506
mongocanfly
Robg ,, that was the stock location for my battery..mine had a big hole ate thru it from a battery leak so I bought a new battery tray from lmc..it was a exact match for my old one..they had right and left side battery mounts. Btw mine is a 1981.
Old 06-04-2015, 12:21 AM   #507
6L72C10
6L72C10's Avatar
do you happen to remember what the parts were? if you had a list that would be great.
I spoke to Spectre and they said they have a brand new LS conversion on the way part number 901235, but he said to wait for a month before pulling it up on the web site. but the impatience man I am I pulled it up on Summit Racing and there was a pic but the pipe looks straight. So if I can't find something soon I guess I will have to wait and see.
Old 06-04-2015, 01:01 AM   #508
mongocanfly
C10..here is what I used..spectre filter #hpr9889, $35.13,,,, spectre flex 90 #9785,, $28.70,, spectre 4x3 adapter (between maf and tb),,#97411,,$12.53,,, mandrel bent 45 degree 4 "od alum pipe with 6 in legs from mandrel bends on ebay was $30.37...maybe that will help you out.
Old 06-04-2015, 11:08 AM   #509
mongocanfly
C10,, just to clarify that adapter is 4x3 1/2...not 4x3...part number is right.97411
Old 06-05-2015, 09:32 AM   #510
6L72C10
6L72C10's Avatar
thank you for the info, now I can finish the engine bay.
Old 06-05-2015, 12:30 PM   #511
Bowtiguy
Bowtiguy's Avatar
for those looking to swap in a TR6060 trans, I just ordered one of these. It should make using all the aftermarket T56 tranny cross members a bolt in.
www.RPhotrods.com
Here is what they had to say...
"To keep up with new transmission options Muscle Rods® has released two new transmission adapter brackets for the T-56 and TR-6060 transmissions, including the MG9 “high-torque” version of the TR-6060 behind the LSA engines in the CTS-V and ZL1 Camaro.
The adapter bracket for the Cadillac CTS-V T-56 as well as the late model TR6060 (non MG9) is laser cut, CNC bent and jig welded using 3/16” thick A36, steel is powder-coated black and comes with all necessary hardware. It is designed to adapt a standard transmission mount to the transmission using the factory bolt holes in the side of the extension housing and places the transmission mount in the correct location for our LS swap kits.
The adapter bracket for the MG9 high-torque TR-6060 is CNC machined from 6061-T6 billet aluminum, has a milled finish and comes with all necessary hardware. It is designed to adapt a standard transmission mount to the transmission using the factory bolt holes at the rear of the extension housing and places the transmission mount in the correct location for our LS swap kits. Polyurethane transmission mount is not included with the transmission adapter brackets, but is included with our LSx swap kits."
Bowtiguy is offline   Reply With Quote
Old 06-12-2015, 02:02 PM   #512
DLW
Just fit check this 2014 LS3 in my 66 C10 with mild PB drop member. Will be using the MSD Atomic LS EFI setup here to so will simplify the computer system, plus be speed density, wide band and no MAF. I have a new 4L70E as well with stand alone controller.
DLW is offline   Reply With Quote
Old 06-12-2015, 05:20 PM   #513
old yelr
LS3 or L99? Are you keeping the variable valve timing?
old yelr is offline   Reply With Quote
Old 06-13-2015, 02:50 PM   #514
DLW
Nice catch ..
It is an L99 out of a 2014 Camaro. I already have everything to convert it to an LS3, per say. Dumping the VVT and AFM, swapping to a small TSP 225/230 cam. As soon as I pull the engine back out will pull the heads, swap cam and lifters, springs and move up to roller rockers. Also setting aside the 6L80E for now and use a 4L70E so I don't have to stick with the OE PCM, no real solution for a stand alone TCM for the 6L80E plus the pain of the output yoke. Will also use FBC.
Old 06-13-2015, 03:46 PM   #515
old yelr
Sounds like you've got it covered. Do you have a build thread going?
Old 06-13-2015, 03:54 PM   #516
DLW
No Build thread yet. Debating on whether to start one, I'm horrible at documenting as I go..
Old 06-15-2015, 12:17 AM   #517
Bowtiguy
Bowtiguy's Avatar
Final mock up complete. LC9 w/ a TR6060. now just have to pull it and put on the CTSV pan, notch the frame rail for the NLE power R&P and, put in the 14' Camaro SS clutch and drill a few more holes for mounts.
Old 06-16-2015, 03:30 PM   #518
1moretoy
Here is mine.
1moretoy is offline   Reply With Quote
Old 06-16-2015, 04:02 PM   #519
DLW
Originally Posted by 1moretoy View Post
Here is mine.
Love turbo LSx builds! You have any pics of how you mounted the coil packs?
Your just right down the street from me, maybe we'll cross paths sometime...
Old 06-18-2015, 01:58 PM   #520
chevyc10lover
Thumbs down Re: LS swappers, post up your pics!!
Originally Posted by mac72 View Post
Nice work guys they really look sweet
Heres a few of mine
nice swap. i know is an old tread, but i should ask.. what kind or rack and pinion is that?
chevyc10lover is offline   Reply With Quote
Old 06-19-2015, 12:54 PM   #521
mac72
87/93 mustang
mac72 is offline   Reply With Quote
Old 06-26-2015, 02:17 PM   #522
dwcardfan
dwcardfan's Avatar
Originally Posted by dwcardfan View Post
Here is mine. I am just getting started.
I made a little progress on mine.
dwcardfan is offline   Reply With Quote
Old 06-26-2015, 02:19 PM   #523
dwcardfan
dwcardfan's Avatar
Another pic of motor.
Old 07-19-2015, 10:55 PM   #524
knightvizion
knightvizion is offline   Reply With Quote
Old 07-23-2015, 09:06 PM   #525
Mhubbard85
Question fellas. I just did my harness. Out of the fuse panal connections which do I need to keep
Mhubbard85 is offline   Reply With Quote
