Old 10-22-2015, 01:03 AM   #501
Captainfab
60-66 Nut
Re: Lost My 65
What rpm does your engine like to idle at?
Old 10-22-2015, 07:56 PM   #502
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Lost My 65
I really don't know.
I got the starter and flexplate mounted today.
Cranked it over just to see if all was good.
Tomorrow I plan on mounting the radiator support and radiator to start it up and run it for a short time.
I'll hook the tachometer up also and see what idle is.
66 C20 Service Truck:
Old 10-23-2015, 10:46 PM   #503
LostMy65
LostMy65's Avatar
Re: Lost My 65
When I poured the slab in my pole barn to have a clean dry area to work on my truck, I didn't consider the height of the loft above. Fortunately I had only tacked the sheathing down. So I pulled up a center section of the sheathing, rearranged the joists, and now i have an area that I can hoist things through.
Old 10-23-2015, 11:06 PM   #504
LostMy65
LostMy65's Avatar
Re: Lost My 65
Originally Posted by captainfab View Post
what rpm does your engine like to idle at?
750-1000
Old 10-27-2015, 06:46 PM   #505
LostMy65
LostMy65's Avatar
Re: Lost My 65
So, I was mocking up the Th350 so I could figure up my driveshaft length, and as many times as I checked, I never really felt comfortable getting a driveshaft made/shortened for the Ho32 knowing I eventually will be swapping it out for a 12-Bolt. Although it's only around 5/8" difference, I figured I might as well go ahead and do that swap now also.
I didn't want to dig this far into it at this time, but it just makes more sense to do it all now.
Old 10-27-2015, 07:49 PM   #506
Re: Lost My 65
I would go ahead and do the swap now. No use redoing the shaft twice.
BTW I think your idle is a bit high. mine is around 500
Old 10-27-2015, 08:00 PM   #507
LostMy65
LostMy65's Avatar
Re: Lost My 65
Yep, doing it now.
That's the 12-Bolt sitting behind the bed.
Too many of the upgrades that I've been wanting to do, all make sense to do now while I have it tore down.
As I mentioned before, I don't like taking on too much for fear 'life' will get in the way and the truck sits out there torn apart.
Old 10-27-2015, 09:16 PM   #508
likaroc13
Rollin' Old Skool
Re: Lost My 65
Originally Posted by LostMy65 View Post
Yep, doing it now.
That kinda happened to me, but I agree that I'd go ahead with that swap as well while you're there.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-28-2015, 01:32 AM   #509
Captainfab
60-66 Nut
Re: Lost My 65
It sounds like you need a 22-2400 stall converter.
750-1000
Old 10-28-2015, 07:49 AM   #510
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Lost My 65
The key to getting that project done.... in focused steps.. break it down into bite sized chunks. I focus my efforts on my current project by setting up 6 hours every Sunday morning with 1 or 2 goals in mind.. since doing this.. I've made significant progress.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 10-28-2015, 06:23 PM   #511
LostMy65
LostMy65's Avatar
Re: Lost My 65
Got Captainfab's axle perches/saddles mocked up today.
I approached it very similar to how I did the 14-bolt on my 3/4 ton service box truck.
I propped up the back end - bracing the trailing arms with 2x6 wood members. Removed the Ho32, and then made a template out of plywood (wafer board) - marking the existing axle perch holes. Then I lined my template up under the 12-Bolt. I was hoping I wasn't going to have to remove the existing perches from the 12-Bolt.
As you can see from the pics; I pretty much have Captainfab's axle perches slapped up against the existing 12-Bolt perches. I'll tac them on and then test fit it before welding them on permanently.
The pinion angle will remain the same.
Old 10-30-2015, 07:38 PM   #512
LostMy65
LostMy65's Avatar
Re: Lost My 65
Tacked on Captainfab's axle perches.
Bolted them up, tightly, then tacked them permanently.
I'll pull it back out tomorrow to weld them up completely.
The axle is out of a 65, so it looks like I'll be able to use the track bar too.
Old 10-30-2015, 11:46 PM   #513
LostMy65
LostMy65's Avatar
Re: Lost My 65
Just a small video of my engine running.
I wanted to run it some after i cleaned it to check for oil leaks and idle rpm
Old 11-03-2015, 07:15 PM   #514
LostMy65
LostMy65's Avatar
Re: Lost My 65
Having things apart, I found one of my oil leaks. Someone at one time looks to have used a chisel or something to install the cam plug. But then later when a new one got installed, those chisel marks actually damaged the inner surface of the cam plug hole.
You can even see how those chisel marks scraped the edge of the cam hole plug.
There's four on the plug which align perfectly with the chisel marks on the cam hole.
Old 11-03-2015, 07:27 PM   #515
LostMy65
LostMy65's Avatar
Re: Lost My 65
Found the Dorman version .
Hmm, Dorman from China. :-(
Old 11-03-2015, 09:16 PM   #516
LostMy65
LostMy65's Avatar
Re: Lost My 65
The question I have now is, how do I remove those bumps on the inner surface of the cam shaft hole?
Maybe a small three or four stone hone?
Old 11-03-2015, 10:36 PM   #517
LostMy65
LostMy65's Avatar
Re: Lost My 65
I think this 2" grinding wheel might be the best solution.
I only need to just smooth the very outer edge. The cam plug actually sits a bit behind the chisel bump.
It's just when inserting the plug that the plug gets that scratch in it. So if i remove the bump from the outer rim, I think it'll seal up ok.
Old 11-03-2015, 10:59 PM   #518
LostMy65
LostMy65's Avatar
Re: Lost My 65
Ok, I think I got this video to work now.
Old 11-04-2015, 06:26 AM   #519
Re: Lost My 65
It sounds good to me.
I have never had to deal with the stuff like you are with the cam. It sounds like you are going at it with the right ideas.
Old 11-04-2015, 01:09 PM   #520
LostMy65
LostMy65's Avatar
Re: Lost My 65
Talking with a guy at work today, I think we came up with a good idea.
Lightly grind the old plug I removed, drill a hole in the center of it,
Wipe some grease around the outer edge of the plug, and then slide it back against the cam.
Then use the 2" grinding stone I mention above.
Wipe down. Remove plug. Wipe again. Install new plug.
Old 11-04-2015, 08:20 PM   #521
LostMy65
LostMy65's Avatar
Re: Lost My 65
Surprisingly nice day today, so I
went to the local Pick-N-Pull to look for a driveshaft.
Every stupid one destroyed. I looked at 40 to 50 vehicles.
All destroyed from forklifts. Why the heck advertise them for 37.99 if you're going to destroy them?! Jerks
Old 11-06-2015, 04:04 PM   #522
LostMy65
LostMy65's Avatar
Re: Lost My 65
I ended up going with this.
http://www.amazon.com/gp/aw/d/B004GI...way+driveshaft
Old 11-07-2015, 02:40 AM   #523
Captainfab
60-66 Nut
Re: Lost My 65
Are there not any local machine shops or such that can shorten or build a driveshaft? I guess I'm spoiled up here.
Old 11-07-2015, 12:01 PM   #524
LostMy65
LostMy65's Avatar
Re: Lost My 65
The shaft in my 65 on a 62 frame was from my longbed 65. It was a two piece. I had it shortened when I built my 65 back up on the 62 frame.
I didn't want to have it shortened again for the th350.
It would have ended up being roughly two 2' pieces with a carrier bearing.
So I started watching Craigslist for something close or longer than what I needed. After a few dead ends with CL and going out to the wrecking yard and looking under 40+ vehicles, I figured I'd burnt up enough of my time.
I have Builders needing me to finish up house plans.
A little over $200 shipped for a brand new driveshaft with u-joints and yoke ain't a bad deal. Especially if I was going to pay more than that to have one made.
Besides, if Southwest Speedway's shaft works out no hassle, I think it'll be a nice source for others needing a new shaft.
Old 11-13-2015, 03:47 PM   #525
LostMy65
LostMy65's Avatar
Re: Lost My 65
I need to make a Black Friday shopping list.
(to keep updated)
1. Auto Transmission Thermostat.
2.
