Old 06-27-2021, 09:07 AM   #501
8man
Re: Jesses' 48 PU
Nice job Jesse!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 06-27-2021, 11:56 AM   #502
Jesse49chevy
Jesse49chevy's Avatar
Re: Jesses' 48 PU
Originally Posted by Father&son56project View Post
Well done! Fabbing stuff inside tight spaces like that can be miserable, but you pulled it off nicely.
Thank you... definately a tight spot.. but worth it!
Semper Fi
Check out my project:
http://67-72chevytrucks.com/vboard/s...d.php?t=559086
Jesse49chevy is offline   Reply With Quote
Old 06-27-2021, 11:57 AM   #503
Jesse49chevy
Re: Jesses' 48 PU
Originally Posted by 8man View Post
Nice job Jesse!
Thank you Robert... inching closer to the finished product..
Semper Fi
Old 06-27-2021, 12:10 PM   #504
Jesse49chevy
Re: Jesses' 48 PU
Guys/gals... need help identifying a part. Im close to oedering the glass. But I noticed that on the doors, the window screws on to a piece that Im missing. Ive looked at all the usual places and cant seem to find it. Not sure what its called so for description purposes im calling it "the roller bar". This piece I assume has to somehow have the plastic rollers sit inside a channel similar to the one fixed to the door panel.
I found and ordered what I thought is that part but, either I am wrong and it just sits on the roller (doubt it) or I ordered the wrong part. The puece Inordered is the lower door window sash channel.
So if anyone could help me identify it and tell me where I could source a set, id really appreciate it.
Ive attached the below pics to hopefully help explain what im refering to.
The white plastic rollers is what I beleive sit inside a channel that screws onto the "lower window sash" which is attached to the window frame.
Semper Fi
Old 06-27-2021, 12:12 PM   #505
Jesse49chevy
Re: Jesses' 48 PU
This is the part I ordered, but I am convinced its not what I need. It does have a channel on one side, but its open, doesnt secure to anything, and I dont think this floats on the rollers.
Semper Fi
Old 06-27-2021, 12:25 PM   #506
Jesse49chevy
Re: Jesses' 48 PU
Found a pic of what I need... whats it called?? And where can I get them?
Semper Fi
Old 06-27-2021, 01:03 PM   #507
8man
Re: Jesses' 48 PU
I'm looking, but I'm not finding it either.
8man-aka Robert
Old 06-27-2021, 02:12 PM   #508
Jesse49chevy
Re: Jesses' 48 PU
I may have to go visit that place up in N Texas and dig up a set
Semper Fi
Old 06-27-2021, 04:01 PM   #509
8man
Re: Jesses' 48 PU
If you find yours, look for a set for me too. I have them for the 48, but I need them for the other truck.
8man-aka Robert
Old 06-27-2021, 04:09 PM   #510
8man
Re: Jesses' 48 PU
See if this works.
https://www.lmctruck.com/1948-59-che...glass-assembly
It calls it a window lift channel, item 11. It is for the 451-55.1 and a little shorter than we need.
8man-aka Robert
Old 06-28-2021, 09:21 AM   #511
8man
Re: Jesses' 48 PU
Try Bills Truck Shop, 47-55 catalog, Group 13, p 42, item 13-211-47L or 13-211-47SK. I think these may be the parts you are looking for.
8man-aka Robert
Old 06-28-2021, 10:14 AM   #512
Jesse49chevy
Re: Jesses' 48 PU
Thank you sir.. ill take a look shortly. Sad thing is that when taking the truck apart, neither my dad or I paid attention. Because the glass was broken we chunked it not realizing it was a seperate piece.
Lesson: NEVER throw anything away...
Semper Fi
Old 06-28-2021, 10:37 AM   #513
Tempest67
Tempest67's Avatar
Re: Jesses' 48 PU
About 3 weeks ago I close my drivers door and 'CLANG" inside the door. Hmmmm?
The window would crank up, but not down?
So, I removed the interior door panel, and lying in the bottom of the door was that piece. I believe it is part of the 'channel' that attaches to the glass and was welded at the factory.(it is part of the window glass assembly)
I really did not want to remove the window from the door to weld this back, so I was able to put it in place with vice grips, and weld it through the access hole of the door. So far so good.
Tempest67 is offline   Reply With Quote
Old 07-02-2021, 04:59 PM   #514
Jesse49chevy
Re: Jesses' 48 PU
Flying out tomorrow on a family vacation for a week. So took advantage of the day and decided to put in a little work on the truck. Installed the door seals, you guys have seen all ive done on this truck. I swear snaking these rubber seals through the track was the hardest thing ive done thus far... the rubber strip lubricant helped, but being a one man show is hard.
It looked easy so started from the bottom up but as soon as I hit the first curve on top it came to a halt.. would not budge. So after several attempts, including trying to pry the strip into the channel, I decided to cut it in half and start from the top down. Installed the front and rear seperately and the added weatherstrip glue in the center splice to put the back together. Hopefully wind noise will not be an issue...
Semper Fi
Old 07-02-2021, 05:02 PM   #515
8man
Re: Jesses' 48 PU
I hate to hear about that issue as I have it to look forward to!
Have fun.
8man-aka Robert
Old 07-02-2021, 05:03 PM   #516
Jesse49chevy
Re: Jesses' 48 PU
Here is where I glued it back together..
Semper Fi
Old 07-02-2021, 05:08 PM   #517
Jesse49chevy
Re: Jesses' 48 PU
Have fun.
I am sure that if you have a buddy to push while you pull it maybe easier. But had to get creative as a one man show. After splitting it, I managed to snake it in from the top down, then came back up to get into the upper half... have to admit that the second one went a bit faster as I had it figured out. Did use some plyers to gently tug on it as fingertips get sore pretty quick...
Semper Fi
Old 09-04-2021, 09:16 PM   #518
Jesse49chevy
Re: Jesses' 48 PU
I was bored today... so tried out my googley eyes idea....
Semper Fi
Old 09-05-2021, 01:05 AM   #519
Kermitt47
Kermitt47's Avatar
Re: Jesses' 48 PU
Cute! nice way to dress up the Red Neck air conditioner.
Kermitt's 47 truck build
Kermitt47 is offline   Reply With Quote
Old 09-05-2021, 07:43 AM   #520
Jesse49chevy
Re: Jesses' 48 PU
CUTE?? Thats it... its coming off!! LOL...
Thanks Kermitt... not sure if the eyes are a keeper...
Semper Fi
Old 09-05-2021, 08:15 AM   #521
8man
Re: Jesses' 48 PU
Aw come on! They give it character, like Mater.
8man-aka Robert
Old 09-05-2021, 09:54 AM   #522
nvrdone
Re: Jesses' 48 PU
but did the eyes interrupt the air flow??
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is online now   Reply With Quote
Old 09-05-2021, 02:43 PM   #523
Jesse49chevy
Re: Jesses' 48 PU
Lol.. youre right... just weird the way the truck stares at me!!
Semper Fi
Old 09-05-2021, 02:44 PM   #524
dsraven
Re: Jesses' 48 PU
Put a few fingers on each side like somebody looking over the fence, lol.
Old 09-05-2021, 02:45 PM   #525
Jesse49chevy
Re: Jesses' 48 PU
Not sure, im sure we will never find out as more than likely it will probably only be open when parked, Texas weather requires all vehicles to have AC.
Semper Fi
