Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-07-2016, 12:04 PM   #501
First c10
First c10's Avatar
Re: Project 68 k10 LWB..aka "The Hulk"
Got a chance to pull the Old Air evaporator (under dash piece) out of the box to check the mounting brackets. I removed the studs form the engine bay side bracket and welded them on inside of the firewall.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-07-2016, 12:06 PM   #502
First c10
First c10's Avatar
Here are a few more pictures of what I did to the bracket. I will take a few more to show what I did to the backside of the bracket that bolts to the cab side of the firewall.
Oh and the sharpie writing on the back of the mount was incorrect...
GO GO!!!
Old 03-08-2016, 01:17 AM   #503
swamp rat
swamp rat's Avatar
Reading your rocker repair its dully noted that the passenger side had less of a gap between the rocker and cab corner and you used an OEM rocker, i have a bit of a gap as well but an going to have to live with it, just wondering if you will be filling the gap with something?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-08-2016, 11:28 AM   #504
First c10
First c10's Avatar
Mike that is a great question.... I plan to fill with something but not sure what. That is where the body shop guy comes in. I am not sure if 3M seam sealer is the best or some epoxy like what is used on the drip rails. Please let em know if you have any ideas.
GO GO!!!
Old 03-08-2016, 03:23 PM   #505
First c10
First c10's Avatar
Ok so I started a Hulk Jr build thread. I need Mod to change the name of this thread from 68 to 70.
Here is a link to the hulk Jr build. Hulk Jr build
GO GO!!!
Old 03-08-2016, 03:26 PM   #506
swamp rat
swamp rat's Avatar
Ok, if you find out please relay the information, Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-10-2016, 12:44 AM   #507
First c10
First c10's Avatar
Got a chance to work on the this truck a little today. 1 thing that always bugged me was the swaybar mount. In all the pictures I have seen and all the different ways of mounting. I had to just get the welder out and let in burn.
GO GO!!!
Old 03-10-2016, 12:47 AM   #508
First c10
First c10's Avatar
The other one. After a little clean up and paint wont even know I touched them.
GO GO!!!
Old 03-12-2016, 09:02 PM   #509
First c10
First c10's Avatar
Got a chance to install the old air ac compressor. I painted the Alan Grove brackets to match the cast aluminum of the rest of the engine accessories
GO GO!!!
Old 03-12-2016, 09:05 PM   #510
First c10
First c10's Avatar
Another picture of the ac conpressor.
Not sure if the refrigerant lines go out the top or the side. But I just have it in the bracket just to see how it looks and not tighten down yet.
GO GO!!!
Old 03-16-2016, 11:55 PM   #511
First c10
First c10's Avatar
Was able to clean up the front swaybar mounts and get them installed. But forgot to take a picture. It looks good!
Next is to get the hole cut in the core support for the condenser so I can get it painted and installed on the frame.
GO GO!!!
Old 03-17-2016, 09:03 AM   #512
7dee2
7dee2's Avatar
Nice work!
Brett
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 03-20-2016, 01:10 AM   #513
swamp rat
swamp rat's Avatar
Nice welding too...
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-22-2016, 09:55 AM   #514
First c10
First c10's Avatar
Thanks for the comments guys.
I got a chance to get the new idler pulley on so I could put the serpentine belt on.
Also got a quick picture of the swaybar brackets.
GO GO!!!
Old 03-22-2016, 11:20 PM   #515
First c10
First c10's Avatar
Nothing more exciting then a hole.....
Got the hole drilled in the radiator core support for the refrigerant lines to the condenser.
GO GO!!!
Old 03-23-2016, 08:57 PM   #516
swamp rat
swamp rat's Avatar
What engine is the serpentine setup of of?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-24-2016, 12:46 AM   #517
First c10
First c10's Avatar
Its all stock 2008 truck belt system that came with the engine/trans package I bought except for the Allen grove #14-140R AC compressor mount that came with the Old Air Products AC system.
GO GO!!!
Old 03-26-2016, 09:44 PM   #518
First c10
First c10's Avatar
Well I was able to get my son to help me today. We added all the gear oil to the front and rear diff's and ATF in the transfer case.
We also swapped brake pads from the D52's to the D153 must be 30% more pad surface. I figured that the Hulk could use it. I planned on taking a picture of the pad difference but forget. I just need to get the cab over to the body guy so he can sling some mud.... the roller is about as far as I can go with out sheet metal.
GO GO!!!
Old 03-27-2016, 03:39 AM   #519
swamp rat
swamp rat's Avatar
At least somebody got something done! LOL! I actually have a 3 day weekend and all i did was buy a couple items and some 2X2's to hopefully start building a little paint booth, and its not raining.....
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-30-2016, 12:30 AM   #520
First c10
First c10's Avatar
Hey Mike I was trying to get a few things done before I left as this week I am on a college road trip. Tour of 4 colleges with my son. We flew to Denver and rented a SUV and are driving through Wyoming then Idaho to Montana and then Back to California. Will be Home this Sunday.
GO GO!!!
Old 03-30-2016, 12:37 AM   #521
swamp rat
swamp rat's Avatar
Family first!!!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 04-20-2016, 12:43 PM   #522
lowrodderchev
lowrodderchev's Avatar
any updates? this is a killer build with a lot of info that's helping me
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 04-20-2016, 12:49 PM   #523
First c10
First c10's Avatar
Hey Lowrodderchev, glad this is helping you out.... but I have been working on the other truck my other son will be taking to college in Montana(Hulk Jr). This truck has been pushed back till I get the other done, hopefully in a couple weeks I will have it up and running. What I need to do is finalize the color so I can take to the body shop.
GO GO!!!
Old 04-20-2016, 12:56 PM   #524
lowrodderchev
sweet cant wait to see the finish product.
Old 09-05-2016, 10:58 PM   #525
swamp rat
swamp rat's Avatar
Any updates? its been a while.. Question, are the rear calipers caddy calipers? do you recall the part numbers? I want to dicument them and the control cables place you got the cables from. Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
