Old 12-09-2025, 03:32 PM   #501
clay68c10
clay68c10's Avatar
Re: ClusterTruck; because that’s what it is
Now it was time to hang the fenders so they could get painted along with the doors and cab corners.
It’s really starting to look like something at this point!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-09-2025, 03:35 PM   #502
clay68c10
clay68c10's Avatar
Meanwhile, Dave shot the hood, cowl, and mirror arms
13 Tahoe LTZ
Old 12-09-2025, 03:39 PM   #503
clay68c10
clay68c10's Avatar
And then…..
13 Tahoe LTZ
Old 12-09-2025, 05:30 PM   #504
loudchevy
loudchevy's Avatar
Sweet action! Congrats on the milestone
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-09-2025, 05:56 PM   #505
Chevys4life
Starting to come together very nicely!!!
Chevys4life is online now   Reply With Quote
Old 12-10-2025, 07:21 PM   #506
clay68c10
clay68c10's Avatar
Thanks! It’s definitely been exciting.
13 Tahoe LTZ
Old 12-10-2025, 07:29 PM   #507
clay68c10
clay68c10's Avatar
Now it was time to get it assembled enough to trailer home.
And maybe take a quick zip around the shop with Dave.
It’s such a cool and bright color, I’m pumped to have it together-ish.
13 Tahoe LTZ
Old 12-10-2025, 08:26 PM   #508
SCOTI
SCOTI's Avatar
Panels looking great on consistency.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-11-2025, 07:27 AM   #509
MellowYellow70
Coming together extremely well, looking awesome so far
MellowYellow70 is offline   Reply With Quote
Old 12-11-2025, 09:43 AM   #510
Chevys4life
Looks good for sure!!!
Old 12-11-2025, 12:49 PM   #511
clay68c10
clay68c10's Avatar
Thanks, it's been a challenging color. We decided to paint the orange over white to give it more pop. The formula says to put it over gray. We're thinking that the white base is what's made it so sensitive. So much light reflects back thru it that you can see any variation. In the direct sun, you can definitely notice a difference depending on the angle of the panel surface. An open door looks a slight shade different than the fender it's next to because of the light angle going thru the color. Conveniently that works out to where the interior color looks fine. The distance and varying shapes of the jambs disguise it pretty well. The soft touch matte clear interior also helps.
Dave says it paints and looks like a candy, just minus the metallic solids.
To turn back the clock, we would have probably chosen a gray base, but it all worked out in the end.
Thanks, it'll be a good winter project to get it gapped and fitted. Spring will be color sand and polish as well as bed liner.
Thanks, it has that fresh paint scent also.
13 Tahoe LTZ
Old 01-18-2026, 11:46 PM   #512
clay68c10
clay68c10's Avatar
The weather here has been decent for the past few weeks so I got some trim installed.
The grille hoops went on ok, but the repop is definitely not as robust as the original.
The front bumper is an old original I got from Sergio, who got it from a neighbor. It’s in ok condition and will definitely do for now.
The rear is repop, and not anywhere near as thick. Just bolting in the license mount bowed it slightly. I guess that’s just how it goes.
13 Tahoe LTZ
Old 01-18-2026, 11:56 PM   #513
clay68c10
clay68c10's Avatar
I have been driving it a bit. I’ve done some initial adjustments on the tune to build in a rich biased safety margin. I increased the whole VE table by 5% and everything above 3k rpm by more. So far I haven’t seen any lean conditions in my logs yet, but I haven’t gone much over 4k or 75% throttle. I will need to get my wideband in before I can get close to WOT safely.
That said, the power is definitely there and I’ve enjoyed just driving it around.
It’s got about 150 miles on it now.
13 Tahoe LTZ
Old 01-19-2026, 12:14 AM   #514
clay68c10
clay68c10's Avatar
Each time I drive, I take a peek and check for leaks. At about 140 miles I saw some drips from the speedometer cable area.
It was the ford to GM cable drive adapter. The TKO uses one of these and I think the TKX does too.
I didn’t know there was a good one and a crappy one. Seems I bought the crappy one. It doesn’t have a seal of any sort on the output shaft. Makes no sense to me and I’m surprised it didn’t leak sooner.
I got the good one as a replacement and will keep an eye on it. It has 2 o-rings on the body and a seal on the output.
The first 2 pics are the old, the next 2 are the new.
13 Tahoe LTZ
Old 03-12-2026, 10:28 AM   #515
clay68c10
clay68c10's Avatar
I've been doing some more cruising as weather and clean road conditions permit. I've adjusted some of my VE table off of long term trims and it has gone well. The LS pcm is definitely more capable than the TBI systems. The adjustments are much closer and happen faster. I've briefly ventured into WOT under 5k and it's not gone lean on me yet.
One thing I have noticed is my factory temp gauge doesn't read high enough with the F body 3 pin sensor. I was looking thru LockDoc's build and saw his solution. I gave it a try with some jumper wires and various resistors and now my gauge is at the mid point at 200deg.
https://67-72chevytrucks.com/vboard/...&postcount=570
Thanks to LockDoc for the solution. I tried different resistors in the other terminals where the factory 90ohm resistor lives, but the results weren't great. The 150ohm bridging the sensor and ground terminals looks like the fix.
Unfortunately now I'll have to pull the cluster again. Oh well, it keeps me busy.
13 Tahoe LTZ
Old 03-12-2026, 12:45 PM   #516
SCOTI
SCOTI's Avatar
Sounds like some great/steady/forward progress!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
