#5251 |
Nothin wrong with a hat rack either... nor the cb mounts I had. At least, not back in the day... now it's all getting cleaned and smoothed up.
Bryan (Redneck) '66 Chevy Longbed Fleetside '12 Dodge Ram 3500 '08 BigDog Pitbull '11 Cargomate Trailer (Toy Hauler) |
#5252 |
Re: What did you do to your truck today?
#5253 |
While I am waiting for my new rad to arrive did some cleaning, and de-greasing under the hood. Also cleaned up and painted the hood latch and top rad brackets and alternator bracket.
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#5254 |
Got the throttle cable and assembly installed. Had to use the throttle assembly from the 61 and use it on the 63 linkage to make it work. The 235 and the 230 had different linkage. Just have to drill the hole and mount the cable on the dash now.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#5255 |
Getting ready for my p/s install. Rebuilt the pump, cleaned and painted everything.
![]() ![]() ![]() Posted via Mobile Device
BaBaBooey BaBaBooey ![]() GO SPURS GO!!! |
#5256 |
Last weekend I worked on the interior. Finished the sound mat and installed the carpet and seat belts and finally the seat. Starting to see the finished product. I am motivated to finish this thing!
Sorry for the bad cell phone pics. |
#5257 |
Got the odometer rolled to all Zeros and the speedo needle painted...
#5258 |
Called chromer to see where my parts was at.... omg.. they miss placed it... it has been 4mo.s not chromed yet... good thing i dont live closer, they would have to call 911...
Posted via Mobile Device |
#5259 |
i installed porta walls. i sanded, cleaned primed and painted my frame and inner fender wells. waiting for hub cap clips to come in so i can mount my 52 chevy hub caps.
If you used to be...then i guess you never were. |
#5260 |
![]() Join Date: Mar 2011
I replaced my center crossmember with a new dropped one from CPP.
#5261 |
I just had a 700R4, Ididit column shift column, and power disc brakes put on. Its like a brand new truck. Took it by the alignment shop and had the wheels balanced also. I can now cruise at 75-80 with no problems. Worth every penny....
#5262 |
bobbylast how do the porta walls hold up on them tires. Ive seen them on VWs with the thinner tires. I heard they make noises at high speeds..is that true..
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#5263 |
That dash and steering wheel/column are are a converted touchdown sir!
#5264 |
Did that steering wheel come with the column?
#5265 |
#5266 |
Is it the black steering wheel that they offer on LMC, Classic Parts etc?
#5267 |
#5268 |
How do you put/apply portawalls?
#5269 |
Lookup porta walls on youtube there is a video from a VW bug resto shop that goes into detail.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#5270 |
Got my new floor rubber, seat belts , seat and shift knob back in today.
#5271 |
I just got home from seeing my new 383 SBC on the engine dyno at Richmond Engines here in Vancouver, B.C., Canada.
Initial pulls of around 500 HP but hoping for 525 HP after some tweaking of the timing and jetting of the carburetor. |
#5272 |
Boxed in the drip rail.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#5273 |
![]() Join Date: Sep 2006
I went to the shop to get a tow dolly. I have been getting the truck ready to tow to the shop for painting. I have been button up this and that to get ready for it tomorrow and I line the dolly up and my wheels are too wide.. Now I have to go up to the shop and get stock wheels so it will fit on the dolly.. That is 120 mile round trip.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#5274 |
I Got it BAD!
I've been working on the interior... Finished the steering column (Chromed Original Column), Factory A/C controlls and some other odd's and end's. What do you guys think?
Build Thread: http://www.chevyguys.com Last edited by chevyguys; 05-09-2012 at 08:43 PM. Reason: wrong pic |
#5275 |
That looks sick chevyguy
