05-14-2017, 09:43 AM | #5301 |
Re: What did you do to your truck today? Chapter II
I like this pic, it all looks like it came that way but, 2 inch bed raise, 2 inch wheel mini tubs, cantilevered tailgate, sunken spare, respaced composite deck boards and all screw down bed from the top.
05-14-2017, 09:45 AM | #5302 |
I've been there.
05-15-2017, 08:59 AM | #5303 |
Have you thought about 5 inch springs and 2 inch blocks? That's what I did to prevent me from having to C notch and still get to 7 total drop. A lot easier than cutting the frame.
05-15-2017, 09:46 AM | #5304 |
I have 5 inch springs now and planned to do the 2 inch blocks. But I don't think it is driveable like that? How much clearance do you have? I'd love not to cut the frame.
05-15-2017, 09:54 AM | #5305 |
No issues at all. I have never hit anything. The 20's keep it up.
05-15-2017, 10:10 AM | #5306 |
05-15-2017, 11:09 AM | #5307 |
This weekend I put the big CPP sway bar kit on my 65, I also upgraded the lower control arm U-bolts to 5/8"(quite a jump from the factory 3/8") then installed a set of Monroe Magnum shocks.
The ride quality is off the chart. Far and away the biggest change I have ever "felt" in the 4 plus decades I have had this truck. |
05-15-2017, 07:35 PM | #5308 |
05-15-2017, 09:45 PM | #5309 |
05-16-2017, 06:29 AM | #5310 |
replaced the 1 1/4 spacers on my rear axle with 2 inch. looks much better. wasn't sure 3/4 of an inch would make much difference, but it did. I have '07 18 in. Tahoe wheels on my '67 so I needed spacers for clearance but the rear looked tucked in compared to the front. the new spacers put them out where I wanted them.
05-16-2017, 11:38 PM | #5311 |
I took the wheels & tires off the truck tonight to give them a good clean and to inspect the brakes. Man am I ever glad I did! Found a cracked spoke on my 2 year old US Mags. Disaster averted! Now need to talk to the tire shop tomorrow to see if it's covered under warranty. Here's a pic of the back side of the wheel, the crack is just becoming visible on the front side.
1967 C10 SWB Small Window |
05-17-2017, 12:42 AM | #5312 |
laying low
Oh man. Is that a large diameter wheel by chance? That is what I am surprised doesn't happen more often with them. Sure glad you caught it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-17-2017, 09:23 AM | #5313 |
Felt the temp sending probe cut loose as I was installing my new gauge.
While snuggling it down,thought I had stripped the threads till I put a eye on it. Nope just twisted off the hex on the fitting. I don't have any ez outs this big so I found a alternative use for a torx socket. The fitting has only been in for a year so it came out pretty easy. Afterwards i took the dumper for a few mile jaunt. I'm pretty sure that was the longest drive it's had since around 1991. There is some noise in the drive line, only while accelerating or decelerating in 4th gear. while rolling in forth it don't happen. It was dark when I got back so investigation starts today.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
05-17-2017, 10:03 AM | #5314 | |
Glenn 1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca 1929 Ford Model A Roadster - traditional pre-war banger hot rod |
05-17-2017, 10:33 AM | #5315 | |
05-17-2017, 12:36 PM | #5316 |
Glad you found that. That could have made for a very bad incident indeed if you were at speed when it let go.
Surely that wheel was subject to something unmovable and very hard in the recent past? Maybe the PO did it? Scary, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
05-17-2017, 01:11 PM | #5317 | |
That is the thing about doing these trucks, A lot of stuff out there and you end up with something completely opposite of what the intended purpose is. I have a beef with any auto parts places wants to sell me bad parts. |
05-17-2017, 03:01 PM | #5318 |
Very scary. Best case scenario the truck would have seen some damage. Worst case, I or even worse, someone else could have been killed. I don't think the wheel has seen any prior damage, the PO only had the new wheels and tires on the truck for 2 months (and 50 miles) before I bought it. With such a low profile tire, 255/35r20, i think there would be some other damage visible. But other than the crack, the wheel looks like new.
05-17-2017, 09:09 PM | #5319 |
Glad you inspected the rims, best outcome, now just the warranty if any.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
05-17-2017, 09:26 PM | #5320 | |
05-20-2017, 06:59 AM | #5321 |
Hey Gonepostal. I have a 1970 C20 and am looking into replacing my factory bench seat with some '01 era Cadillac Deville power seats... Could you PM me so I can pick your brain about the fabrication/fit aspect?
05-20-2017, 07:21 PM | #5322 |
Swapped out the 45 series for some 35 series my buddy had to get some clearance with the 5 in front drop. Sometimes you do stuff that you feel really stupid for. I bought these wheels and tires used a couple weeks ago. 195 rear tires, I thought I adjusted my panhard bar evenly when I had my old 235 tires on. I noticed a squeal every so often when I turned my wheel. Thought it was my ps belt, tried adjusting it but it wouldn't go away. My buddy was in his car and saw smoke coming from my right rear tire thinking I was doing a burnout lol. Turned out with the new tires I was rubbing the Mess out of it on the inside tub. Thankfully that tire was bald anyway and needs replacing.
05-20-2017, 07:23 PM | #5323 |
Finally new tires! Nothing special low budget 31/10.50-15. Oil and filter-cleaned and painted wheel wells and some suspension. Installed new axle housing seals and felts. Inspected undercarriage. No surprises! Ahh The smell of new RUBBER!
05-20-2017, 07:49 PM | #5324 |
Paul, very nice truck .
05-20-2017, 07:51 PM | #5325 |
relocated the battery tray.
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
